Make sure you get a dyno run, and check your fuel pump is flowing enough juice in it's current form, and the car is making the power it should. I'd personally upgrade the fuel pump as one of your first mods. For a couple of hundred dollars, it could help prevent the car lean out, and will provide enough juice to support the mods you want to install.
I'd then do (in the following order):
- Turbo back exhaust (3inch - will be above the legal limit, but it's impossible to get a sports exhaust below the legal limit.. even stock WRXs are 89DB, the noise limit is 90DB). Go to your local exhaust shop for this. $1000 - $1500 depending on what you get
- Replacement air filter in standard airbox. You can order this online, or get your local Repco etc to order one in for your skyline. $100
- Front Mount inc piping. You can order this online. Price depends on what brand you want. Estimate about $1000 or so.
- Boost controller (turn it up to 12psi, on a dyno, to make sure it's running ok). Buy from most performance workshops, or order online. $100 for a T Piece mechanical controller.
- ECU (PowerFC). You can order this online from Japan to save some money, or just buy one second hand. You could just get a SAFC or something similar if you are on a budget. $1k for the PFC + ~$500 for tuning
Also invest in some good tyres to get traction.
This is too open ended of a question, you really need to specify a budget if you want exact answers and recommendations.
i wanna beat my mates silvia with sr20 inside. It has the exhaust and intercooler as mentioned above, and hks pod filter, its pretty darn fast. Dont mind spending, as long as i see him in the rear view, and 110% LEGAL.
LOL
this will end in tears!
if you want it legal.. dont change a thing. Even an engineers report will not stop you copping issues from the police.
You can try the obvious things first..
A. 10psi
B. Front Mount Intercooler
C. Full Exhaust
D. Aftermarket ECU
E. DRIVER TRAINING!
I dont know where you plan on racing your mate, if its at the track then you should get some training as its worth alot more than mods when it comes to a cars speed.
also learn how to launch properly, i mean its a bit hard to but u may snap a driveshaft who knows, launch like the japs put all pressure on the clutch and then let go, dont rev up and just pop the clutch, puts too much strain on the shaft, bring the clutch up to friction point before pop'n it :thumbsup:
u can chop his sr20 with just a few mods but uve got like 200kg more weight or so... but doubt with the mods he has he wont be able to pull more than 160rwkw but if u do it right for sure around 200rwkw just depends on tuning etc
LOL
A. 10psi
C. Full Exhaust
D. Aftermarket ECU
E. DRIVER TRAINING!
Thanks 4 ur reply, much appreciated....
where would u get these from brand new ?
On my old car I had a custom 3inch front/dump/cat with a 3inch Nismo cat-back and a 4inch nismo tip. I had my exhaust tested probably 10x in the 2.5yrs I had the car and never had an issue.
* K&N Panel Filter
* Turbo-back 3" Exhaust
* Bleed valve @ 10psi
* FMIC
* PowerFC
Cya in $5k's time.
