As far as im aware, injectors are a must as it helps the fuel flow better, a few people have done it without them, but then realised once starting to come on boost they run out of go and they end up swapping to the rb25det injectors, there is a few threads on the board about it, 666DAN did it go to his thread and see what he has to say about it.. they're not to expencive anyway
Hope this helped.
Dayne
u need ecu, or get urs remapped, injectors, fuel pump, its better to buy a half cut as it has everything, but if you dont want to do that, you can get a rb25det block and fit your NA head on, or buy the two seperately, either way you will need bigger injectors. It is better to have proper DET parts, as the compression is lower and you will have the oil squirters in the block.
Another way that you can do it is turbo you NA motor, it is possible, but the max boost you can run is 6psi and the motor is very torque as boost comes in at 2500rpm.
If you have any other questions let me know, i am able to tell you the parts you may need depending on which way you want to go.
cheers
I have all ready brought a heap of parts so i wont be buying an 1/2 cut.
I have:
*Exhast Manifold + Turbo (no lines) + Dump + Frontpipe
*Stock intercooler with piping (:thumbsup:)
..a few picutes might help me with the assembly :)
*GTST ECU
So do i just need injectors/ turbo oil and water line now?
Ive been suggest - replacing the head gasket with a thicker one to lower compression... reckon its a good idea?
brand name ones are available from japan but there super expensive, ive got a number for a place in melbourne that does the very cheap ill try track it down for you.
Sweet thanks NA_R33... i reckon! an 1.6mm HKS $632, 2mm HKS $690.. Looks like i will be sticking to high compression / low boost :P
Keep the high compression!!!!111!11one!
VW are running some very respectable boost in the new GTi...with 10.8:1 compression...like me you'd have 10:1
Now I've got the front mount on it feels like I could easily throw a few more psi into the engine with no issues.
High compression is your friend ;)
also you do realize you will need someone to bore holes in your block/sump etc etc for the oil/water lines to/from the turbo....
yeah i know. ... :rofl: and its gonna cost $$$!! to do so.
Any idea what the stock RB25DE injectors CC value, there smaller but by how much??
"RB25 uses side feed high impedance injectors 370cc"
"N/A engines I have not included these but are generally smaller"
http://www.meggala.com/injectors.htm
    • In a few years from now, you'll regret that. It'll eat away at you, knowing the truth of the ugly hiding beneath the beautiful exterior... 😛
    • I don't think the G2 profile is particularly dangerous for the engine per se, more just are you actually ok with the turbo lag trade-offs? If the answer is yes then go for it. I personally don't think I'd be ok with it because I spend so much time at lower RPMs and I really enjoy the feeling of being able to stay in 5th gear on the highway and just roll into the throttle to get boost. Or staying in 3rd gear on "gentle canyon cruises" without feeling the turbo lag too badly. The 525 pump should be able to run flat out on factory lines but I would bet the pressure drop from pump to regulator is quite impressive. I don't know how much it would be exactly but I've seen figures like 30 psi thrown around.
    • It's interesting seeing everyone talk about what level of risk they are happy to tolerate.  Building a GTR always has a level of risk, you could be that lucky guy that drops 20k on the engine build alone and still has the thing go pop on the dyno. Life is fun like that.  The way I see it, the thing is a toy to be enjoyed. I'd be happy to turn up the power on stock motor and limit the risk with sensible tuning and engine protection. If it still goes pop, it is what it is. The car isn't a daily driver so it can happily sit while a plan is made to sort it out.  Given this thing will be a street car only, I really feel it's worth the (relatively small if managed well) risk to turn the power up to around 350KW on e85.  I don't think anyone getting into the skyline game now is doing it out of logic. Surely it is a purely emotional decision so I'm not sure how important it is to think about the engine build logically. The heart wants what it wants.  @joshuaho96 little note for Josh, I run my 525 pump flat out all the time and through the factory lines without any issues. (excluding the melting connectors, that's sorted now. we'll pretend it never happened lol)
    • But the Nexus S3 is very expensive and won't be as purpose-built for the application as a separate electronic boost controller :^) More seriously my pet issue here would be that the Walbro 525 running at 100% duty cycle is going to require more FPR than the stock setup can handle. I'm also pretty sure from what I've seen elsewhere you might want to slow down the pump regardless unless you're going to come up with some way of upsizing the fuel lines coming from the fuel tank. Factory 8mm fuel line doesn't actually flow very much if you want to keep pressure drop down between the fuel pump outlet and FPR. If you really want to "keep it simple" I would run only as much pump as you need and source a fuel pump controller to slow down the pump in the vain hope of being able to run stock-style FPRs which are pretty dinky. Or just use the HICAS lines and it should be mostly fine. OP should also really think hard about what profile they'd want out of the turbo. My pet choice here would be the G1 profile rather than anything higher power but YMMV. I already think ~stock turbo lag is pretty bad so I don't want to make it worse. In "gentle canyon cruising" I found that I spent a lot of time around 4-4.5k RPM. I also recommend DIYing labor if you're detail-oriented enough. Costs are high for labor + if you do it yourself you can be your own quality control.
    • GTSBoy is again on the money. My actual advice? Sell the car. (really). For what it's worth as is, you can sidegrade into something much better. If you care about function then this is the actual move. If you want a Skyline to perform, set aside about $100K to do it. This is NOT a typo. You will see right away these are two very different mindsets. Realistically we're talking full restomod for any Skyline still kicking around. Have an honest think about which one you are.. and what you want to do, and how much you want to invest in this (with no return).
