hey all
just replaced my exhaust manifold gasket, put it back together and now the thing wont idle and is producing a crap load of black smoke. the thing is last nite after it was all back together i started it up and it ran fine, but when came to moving it this morn it wont run. i also had a flat battery this morn so when trying to kick it over could it of damaged the ecu in any way?
ive pulled all the pipes off again checking if they were restricted but they were clear. do airflow sensors just pack it in? as this is the only other thing i can think of.
any help would be much appreciated
https://www.sau.com.au/forums/topic/73624-a-lot-of-black-smoke/
Is it black, or grey? Where is it coming from: exhaust tip or engine bay?
When I replaced the exahust manifold, turbo-to-dump, turbo-to-manfold, and dump-to-front gaskets my R32 GT-R was pumping grey smoke like something was on fire :P After about 30 minutes of idleing, the gaskets finally started to seal and the smoke disappeared.
The idle was a bit high, but was fine otherwise. I had to replace my sparkies the next day as they became fouled, I assume from a combination of (normally) rich running plus screwed A/F ratios due to the exhaust leak, and the 30 minutes it took for things to seal up.
Lucien.
Black smoke and not running probably means you didn't connect up a cooler pipe properly when putting everything back together.
AFM sees lots of air so gives the engine lots of fuel. Engine sees little air so pumps the fuel out the back in the form of black smoke and backfires until it floods and stalls.
cheers for all the replies. its all sweet now though. went through and reconnected everything( intercooler pipes, pod assembly) and the thing was still running rough, but after a bout an hour of trying it started, ran rough for bout a min then just kicked in, although it has a bit of a miss now though. time for a full tune me thinks.
    • I haven’t taken them out of the cases yet    inside the box is this packaging which is pretty much like a massive blister pack
    • Purchased a NC MX5 a while ago Basic suspension mods done, BC coils and Whiteline sway bars  New DBA calipers, discs and pads Added some 17 x 8 Konig Decagrams with 215/45 17 PS5's Added some typical NA bolt on's, i.e. full exhaust and intake  Added 0.5ltrs with a MZR2.5 swap, nice bump in torques  Found a detachable hard top which is locked in for a colour match with my local paint shop in Feb 25, this also includes some PDR as it has received a few love taps from parking in the local shops when in the hands of my Minister for War and Finances, me, I park nowhere near other cars and typically park on the street The little thing is awesome, I drive it everywhere, it handles like a dream whether I'm up it or just cruising  But now,  because I'm a idiot, I keep looking at turbo kits....... did I mention I'm a idiot Why is dose so appealing  All of the NA 2.5 glory, well.......until sometime in 2025 anyway....🤪
    • I would not be surprised if you are the only person on earth that has the interest/desire to do that lol.  The Haltech base map is a really good starting point, the car will fire easily and drive very well, even on mild boost levels. To me, following your advice sounds like some sort of ancient Chinese water torcher lol (this is not an insult Josh, never change <3)
    • Those car show concepts from the 2000's and 2010's like the Floria and IDx were brilliant and should've gone ahead, at least one of them. But neither Honda nor Nissan are thinking about affordable performance any more, which is truly sad.  Even if Toyota's liquid hydrogen ICE development reaches the point where it's commercially viable and the infrastructure to support it, Honda/Nissan would have to wait until Toyota allow fee access to their patents to offer it with any smaller performance models they released to take advantage of it.
    • A sporty manual RWD coupe with a IL4 Honda engine would only be a good thing I assume we won't see anything released for a few years though, unless informal talks and designs have been going on for a few years,  and due to the current, and future, emmisions and safety requirements, I assume anything "sporty" they would do would be at least some hybrid thingie And hopefully anything they are thinking of has nice lines, without lots of plastic and fake bits hanging off it like that horrendous FK8 that looked like it was designed by a 13 year old The other issue of course in the current market is cost, currently the type R is around $70k, a twin is around $50k Meh, I'm old and grumpy and would rather buy a older model car and waste my coin on that than buying anything currently available new
