Hey Guys
I know this has been asked 1000 times (i've searched and searched :P ) but i installed my 'Go fast bits - Atomic' manual boost controller. I disconnected the old boost solenoid thing, and hooked up one end of the boost controller to the air intake pipe, and the other end into the actuator pipe (this went into the top plug in the stock controller). The little tube thing goes back into the throttle body?? (it used to sit on the bottom plug on the stock controller..) i plugged that hose up with a screw. A followed a few howto's from the archives and I think ive got it hooked up right. Problem is when I adjust the boost it lower it works.. stays at like 5psi.. but when i try make it higher it doesnt seem to change from when i had the stock solenoid on.. stays at like 8-9psi.. Alltho with the stock solenoid on i'd sometimes see it at 12psi for a little bit.. Im also usin an aftermarker boost guage to check the results.
Anyone have any ideas ??? Or am i missing something.. like i need something else.. to make the car make more turbo goodness ?? hmmm.. ???
my cars a r33 series 2 gtst btw.. 3" exhaust, fmic, safc2 etc..
thanks heaps
https://www.sau.com.au/forums/topic/73629-atomic-manual-boost-controller/
a took a pic just now.. u cant realy see it.. but it may help :P
Also i was looking in the little manual that came with it.. it said if my problem occurs ive got it wrong around the wrong way. It ses make sure the arrows are pointing towards the actuator thingy.. I double checked though and it definetly is.
I just checked it again with the thing fully closed, it doesnt seem to make a differance if its open or closed i thought it did before.... keeps going to like 7-8...
i want 10-12 or something :~(!!!
thanks heaps for that :P
It looks like its setup the same as mine.. arrows points towards actuator etc..
That pipe that goes to the top plug on the stock solenoid thingy where does that go back to ? Down to some bigger black plastic tube, and then into the intake pipe right ?
and not the actuator ? I plugged mine with a screw..hmm but that shouldnt make a diff ?
thanks again
grr ok i hooked it all up to the stock stuff... and connected the 2 pipes that go into the soilnoid into the boost controller.. i tried it with it both ways around... and its still sitting at like 7-8. its fully closed.. maybe im understanding/testing it wrong.. if its set to be at like 5psi or something... it should never realy get past 5psi right..
I dont wana have to pay for someone to get this going for me grrr !
I have the same bleed valve as you.
Here was my problem. Car would boost up to about 10psi, and then gradually creep up to about 14psi by 7000rpm. Keep in mind this is with aftermarket computer/turbo/cooler etc.
The thing was, I wanted 16psi right from the start. None of this gradual increase crap. What I managed to find out was that someone had fully closed the valve between when it got tuned (at 16psi) and then I picked the car up.
So with NO valve (valve closed), my car was running the minimum boost which was 10psi at 4000rpm up to 14psi at 7000. I opened the valve 1 turn, nothing... 3 turns, nothing... 10 turns, instant 12psi and 15 turns... 16psi at 4000rpm. By turns I could be meaning half turns cause I can't remember but the point is, you really have to wind that thing out many turns before you will notice an increase in boost over stock.
Also as far as I know, the valve does not let you lower your boost. You can't make it run less boost than stock. However, winding it out (if nothing happens just keep winding) should increase your boost to where you want it.
Also, for the GFB Atomic, you need an ALLEN KEY to open it up. Make sure you using one :thumbsup:
I think you might be right Dee..
Last night i took out the pipe that connects to the T/air intake originaly (like i should have 3 days ago grr) and it had a bloody restrictor in it.. so i've replaced that cable now.. and had it closed and it didnt seem to go over 8psi.. im going to try the unscrewing it 50 times trick now and see what happens.
I'll unplug the electrical connector going in the stock solenoid first to see if that does anything as well ? I thought that *just* opens it at 4500rpm ?
ooh im so excited, one of these ideas has got to work :D
thanks heaps
yay thanks heaps Dee!
i turned it back heaps and heaps and it went to like 15-18 for the split second b4 i nearly had a heartattack.. So its definetly working. Gonna take me ages to work out how many turns she needs to get what im after but its working atleast :D
    • But, do I have to? 😬
    • While doing my tailgate struts I found some rust. Also replaced my bonnet struts. Such a cool satisfaction with that job.
    • So I removed as much as I could from both sides. The shop vac did a great job of clearing 99% of it. I got it all as clean as I could and then absolutely drenched the whole lot in the rust converter. Tonight or tomorrow I'll hammer it again. The cavity must be close to 400mm in length and surprisingly I was able to get it right to the back.  I'll quickly reassemble and then pretend I never saw it. I'll post pics (for me to ignore later) soon.
    • Yea she is a hoot to drive
    • I have always resisted the urge to go silly. 8" wide wheels and street friendly spring rates? Check. (Let's not talk about the steadily increasing spread of spherical joints across my suspension!!) Stock turbo, run at 12 psi? Check. Lasted for~?10 years before it died. Highflow put on rather than seizing the opportunity to go G45. You don't need 300 rwkW, let alone the more massive numbers that seem to be essential these days, to have a car that is already way too powerful and fast for a streeter. ~250rwkW is fine. I've never exceeded 200, although I will sneak up above it if and when I manage to get my finger out and do what needs to be done to use the highflow's capacity. You don't need $10k worth of CF bits glued onto the outside. You don't need razor sharp ankle cutting front splitters. You don't need the car to be 2" off the ground. You don't need flawless paint, mirror finished wheels, brand new indicator lenses, etc etc. All these things just make the car impractical and will cause you pain when they get damaged, which is inevitable for a street car. A few nice additions are good. Good seats are good. A nice stereo is good. A/C is good! (46° on the road yesterday and my A/C is degassed again. Was moderately traumatic driving home!) The main reason I stick with a mildly modified old Skyline is that I have had it for >25 years, the mods are the rolling result of 25 years of things dying and being upgraded opportunistically, coupled with a few "just 'coz" ones. And I hate almost all modern cars. If I was a young buck starting out now.... I wouldn't bother. Cars have a few years left where there is any possibility of interest or fun. Thereafter there will be no such thing allowed or possible. Any time, money and effort spent now on a project would just be a waste.
