Hey guys,
recently crashed my 220rwkw 180sx and am selling the parts to pay for my next car, which I hope will be a 4 door import Nissan.
Idealy I would like a near stock Cefiro, maybe just with catback, lowered springs, wheels and a very mild kit. I have around $10-11K to spend. Plenty around for $12-15K but they are all quite modified or have RB25s, etc.
Will consider Laurel or similar.
Please PM, email [email protected], or ring 0422 531 992 if you can help.
Looking to buy within 2-4 weeks.
Cheers,
Michael
ask nissaner (john) if he wants to sell his car...if you wanna pursuade him, just remind him of his 33 gtr and how good it was...oh and remind him that if he sells his car, it'll be a step closer to his 34gtr dream :P:rofl: :rofl:
Hmmm speak to 'someonestolecc' and you wont buy a car from meggala !
I believe that someone on this site is selling their rb25 ceffy but I think its a bit too expensive for you. Head on over the ns.com cuz I know theres a thread there in the 'cars for sale section'
Yes, well i've imported a car via meggala and have been very happy with the service. Plus know of plenty other people who have only positive things to say so i think we will leave that issue alone (someonestolecc's issue has been discussed enough in another thead). By the way, the laurel has since been sold as i spoke to meggala today.
Anyway back to topic, yes i'd agree with you konect that there are some potential cars been going lately (well last time i checked) on NS that are worth checking out.
hey skypy on your link there under the hybrid pictures...there's a white and zebra 32 with cef nose...i see it's in australia (or is it in NZ?) i like the front bar on that...you know what i is or where i could look to find it? i tried to look for workshop X but nothing came up.
Yeah from memory, they are both the same car at different stages, actually a Cefline (ceffy front on r32) and yes in NZ. I found them awhile on the net. Can't remember which site they are from.... Sorry dude.
 Share
    • Much less twat-tastic. CF wheels are too garish for civilised use.
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
