  • Replies 54
LOL!!!
I think my car has a stalker!!!!
Ur a crack up Ni!!!! :headspin:
damn right it does ;)
one day u will slip up and leave the keys with it running outside of work... just u watch... one day!
Dammit i was sick in bed.
Whos cars this? Interesting looking intake
Great cruise guys, even though I had to let that Torana embarrass me as I could not rev over three grand off from the lights. Have to pull the RB20 down now.
He must have thought the rest of you would be easy pickins as well :Oops:
Hope someone educated him! :(
hope not... thats generally the kind of thing that should be avoided on official cruises.
SORRY, your right! :Oops:
One of the things that struck me about this cruise was that everyone was so well behaved and even though my car is stuffed and I cant rev past 3000RPM I was able to keep up with everyone.
I was sure I would get left behind as soon as everyone was underway.
I love my R32 but I have to admit a few well setup R33's in a row, looking up the road ahead sure looks the goods. :wassup:
Hi Greg,
That intake manifold sure looks original!
What brand of plenum is that and where did you get it from?
It sure looks like it frees some of the space up that the cooler pipes would normally take up :)
Guys I actually designed it, but had some pros cut and weld the aluminium to my specs. Unfortunately it was a bit expensive around $1000 after all the stuffing around and pro coating.
The look was worth it but I am unable to tell if it made any performance improvement over standard as I modded the turbo at the same time.
If your interested, more info on it hereGTS4 Intake buildup
I just read the manifold story, i have to say you did a good job and it does look professional :cheers:
Hows the throttle response now with the shorter ic piping?
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
    • To be fair - you see the same thing for every clutch. There's always someone making an installation error.
