Well Sat... damn early start @ 8am in Attwood.
But let me tell you, i dont think i have ever spent the $135 or whatever it was any better before.
I would like to thank Pete - Bass Junky, who organised the Defensive Drivers Course with Kevin Flynn from Driver Dynamics
Was a sensational day with the perfect mis of theory and practical.
Im sure with the huge success there will be more organised.
So if you missed out i highly advise you to do this.
Learning to stop from 60km/h in under 20 meters in the wet is something i certainly couldnt do before.
Should come as a great assest a lot of the things that we learnt.
thanks again Kev and Pete :P
https://www.sau.com.au/forums/topic/73644-defensive-drivers-course/
Yeah big thanks to Pete for organising such a great day, certianly brings a few things to your attention!! main thing being how badly an uneffective your braking really is (at the start of the day:)). Certainly look forward to next driving day to be organised!, might even have some decent tyres & and brakes by then.
:P
I definatly would encourage ALL drivers to do this course, big eye opener, great day and well worth the money.
I agree..
The Honda loved the skid pan :P
Next time we should organise a bit more of an advanced course with cornering techniques and stuff. I don't know about you guys but i haven't had alot of teaching in this area especially.
We really should have taken a proper camera guys!
-Patrick
-Patrick
Here's a few that I got, spewin I didn't take any video footage, but the battery was dying as it was!
Thanks again to Pete for organising it :)
Enjoy
*oh and if anyone can show me how to post the images as thumbnails, it'd be great! There are more pics in my gallery :thumbsup:
:P
Hey guys.
Well, I think I can safely say that the Skid pan was probably the best fun I've had in my car.
What a buzz.
The drvier training was very informative and I did learn some things about braking that's for sure.
Thanks for those who participated, you have made the roads that little bit safer.
To those who didn't come, well you missed out. It was a great day, and I'm sure the advanced drivers course will be even better.
I think I feel a skid pan day coming though!!
BASS OUT
Methods of applying the brakes, pressures etc.
I have ABS and I found that there is far too much lock built into the ABS on my car. I out braked the ABS in the second session.
It does help though when turning and braking at the same time.
I was about to brake from 65 kph whilst changing lanes in the wet in about 20 meters.
Yeah ABS is fairly cool. I had my ABS fail 3 out of 4 times however (97 series 2).
The idiot light would come on and the ABS system wouldn't come on when you braked.
Will need to check it out, maybe others should check their systems too?
I just assumed mine works fine, guess it doesn't :)
was there a skid pan used, or just standard straight line or swerve. ive done the basic course before, waiting for skid pan tho.
Was a combination of all three. The following real life experiences were convered
- Stopping from 50/55/60/65km/h in wet in 20meters
- Hard break from 60km/h in wet, swerve and stop in 20 meters
- Hard break from 60km/h in wet, swerve, swerve again and clear in about 35 meters (pretty sure)
- Skid pan exercise. Loose the rear end and learn to regain control and traction
Thanks for a great day Guys.
Great group to work with (which always makes our job easier)
:rofl: Cheers from Kev, James, and Kurt.
Thank you Kev, James and Kurt for putting up with us for the day and teaching us those valuable skills... i used to think i could stop in the wet but how wrong was i...
look forward to seeing you guys in the advanced driving course..
  • 2 months later...
Certificates......
From Kevin........
Hi Pete
Just went to print up the certificates, using the names off my attendance sheet....
Boy have these guys got some bad handwriting !
I need the correct spelling of the following peoples last name.
Arman
Lee
Dave ?
Ash
Cheers Kev
So what are the Surnames......?
Cheers
BASS OUT
    • AFM looks to be a z32 The injectors maybe old Nismo 555cc The turbo tag when looked up seems to be a gt2871 , imagine it would have the bigger rear housing .82 all look like the mid 00's mods when he started building it up. Vac hose seems right but would need to see a diagram. Great work going up there and sorting it out, be a good club car for someone wanting a good reliable rig.  I know I would like to have it but no space and too many other race cars at the moment.
    • Heys guys I got a r32 gtst speedo is out by 10kph seems the faster I go the more it be out  just seeing if anyone else had to problem and knows how to fix it
    • I can't agree. If we hadn't all been brought up with the noise caused by the inefficiency of an ICE, no-one would actually ask for all that. An EV is like any other car, it just goes better.
    • 2 more things I have to work out Easy one first...can anyone describe how to pull the fuel pump and sender from a 33? I can feel there is some sort of mount and clips but don't have a manual and don't know the trick......if not I'll spend some quality time in the boot witha lighter tomorrow. Second question is harder.  He had changed the upper plenum to a plazmaman but clearly got to a point with the vacuum hoses where he said "f**k it, I'm going inside for a beer" and never came back to that job because it was a mess. Am I right to think that I need: 1. Pre throttle (16mm nipple on inlet) to AAC's main 20mm fitting as the main pre throttle feed 2. ACC has a second 13m outlet joined to that 20mm fitting which I think is the pre throttle air supply for the cold start valve? 3. Cold start valve's outlet fitting then goes to Plenum (to bypass throttle?) There is some adapter on the back of the ACC with 2 fittings (13mm and 10mm), do I run the 10mm through a 1 way valve to the Brake Booster (4) and the 13mm back to a 13mm nipple on the Plenum as the Idle control (5)? 6. Run a 6mm vacuum line from the Turbosmart BOV to the Plenum? 7. Run a 5mm vacuum line from the Fuel Pressure Reg to the Plenum? 8. Run a 5mm vacuum line from the Turbosmart Boost controller to the Plenum? (Wastegate already has a pre turbo pressure source running to the solenoid then the wastegate on the other side of the bay)  Any help appreciated, the GTR is quite different setup and while the Stagea also has FFP it is different again. (And no Dose, I'm not pissing it all off and putting a ethrottle on it....)
    • OK, onto some questions to try and speed up the process a little. Does anyone know what core this Garret is? I know it is a high flowed standard turbo but nothing else about it. Tag says OK 0169J - 446179-5032 Same question for the injectors, I don't know what they flow and ideally can work it out before it hits the dyno, they are a mustard yellow side feed
