It will most likely be easier to have a custom fuel rail made. What most places do is buy a piece of extruded aluminum from a company over east and then bore the hole for the injectors where they are needed, add the fuel in and return lines and your done.
If the 13B injectors are side feed then I'm not sure what is the best option, I am going for top feed, they are cheaper and are many more varieties available.
See'ya:burnout:
    • Ah yes, fair enough! I was purely thinking about cleaning the spokes and front of the wheel with the mitt. For the barrel the rag on a stick makes more sense. I've tried cleaning the barrels on mine and gave up in frustration. Between brakes being in the way or spokes being in the way and limited space to constantly move the car front and back it was just too annoying. The barrel being as shiny as the rest of the wheel sounds amazing though. At this point I'm not even sure if they have the same surface finish on mine. But I feel inspired now to find out.
    • I have a wheel cleaner pokie thing which is a glorified microfibre rag on a stick, and there is not sufficient clearance between the caliper and the barrel to clean that section. I just roll the car forward 500mm and have another shot at each wheel.
    • The "rag on a stick" is a easy way to fit in between the wheel spokes into all of the barrel Albeit I do have 10 spokes on the MX5 which limits the access to actually jam my hand in to clean the barrel, but it was also makes much easier to clean the 5 spokes on the Dunnydoore with it as well, as you don't have to worry theΒ  caliper getting in the way if you have at least about 15mm space between the caliper and barrel This of course depends if you actually have the clearance between the barrel and caliper, and the amount of OCD you have to get the barrels as clean and shiny as the face of the wheel The thing is bendy as well so you can actually shape it to conform to the inner lip of the barrel Β
    • FWIW, as well as a basic immobiliser/remote unlock (all basic units give you those 2 things), I would also install a 4g tracker in any car I cared about. Just hide it anywhere that won't be found in a rushed look and preferably get something with a built in battery backup so it stays online for a while when the battery is removed or flat While its not a car, when our car trailer was stolen in that den of crime Sydney about a decade ago, the cops were watching from the bloke's neighbour's lawn within about 2 hours until he started swapping the plates and putting up the gumtree ad.Β Β  Obviously it is still not undefeatable (eg parking it up for a few days somewhere without sky sight) but it greatly improves your chances of getting it back quickly and with less damage
    • Instead of magic keyphrases I wonder if something can be done with auto complete. Similar to how user names are handled already. When you type '@' and follow with letters, it'll search across all usernames. It might work to have the same for forum topics. Some key to trigger it and then text search across all thread names and it'll insert the name and URL when pressing enter.
Γ—
Γ—
