mehh... talk about a string of bad luck, first my rims got stolen and TONIGHT. Got pulled over by TMU on king st. Luckily the copper was ONE of the nicest i had to deal with. Went through my car, told me my tyres were wearing thing on the inside and he told me it was actually not roadworthy. Didnt say much, saw the bleed valve, intercooler and filter, didnt say much too.
Let me off after 5 mins. No warning and no CANARY..... now i am afraid that there will be a letter from the EPA soon. What do u guys think? TMU and no fine? no canary? Am I that lucky? Usually how long does it take to receive the letter from EPA if there is one.
https://www.sau.com.au/forums/topic/73671-am-i-in-trouble/
ive been pulled over a few times and it wasnt for car related stuff eg random breath test etc.
and they didnt even look at my car.
As they say though - "We aren't in Kansas anymore" - Melbourne is an entirely different kettle of fish to Perth in terms of vehicular "law enforcement"
https://www.sau.com.au/forums/topic/73671-am-i-in-trouble/#findComment-1353242
he means u arent in a state that uses import drivers as a source of revenue... u see we have a seperate tax here in which import drivers are told to pay every now and then and sometimes repeatedly throught out each year.
https://www.sau.com.au/forums/topic/73671-am-i-in-trouble/#findComment-1353444
That happens to me all the time.
Pulled over, basic licence and rego check, they tell me I should attention some things (usually AVCR) - then they let me go. No problem.
Again showing being polite and courteous doesn't hurt, and that it's a few overzealous officers that give the Police a bad image. The majority use this positively human trait called 'judgement'.
That said - I'm quite pleased not to have driven Golgo to Coles on Saturday night.
Being polite doesn't garner much leeway in a blitz.
https://www.sau.com.au/forums/topic/73671-am-i-in-trouble/#findComment-1353601
This is true too - I've had some very good cops pull me up.
There have been some bad ones too but unfortunately the bad ones tarnish people's perceptions rather more than good ones
https://www.sau.com.au/forums/topic/73671-am-i-in-trouble/#findComment-1353667
Yeah this cop was quite cool, obviously he knows everything abt skylines;
Nice cop: "This is a RB25DET yeah"
me: yup
Nice cop: "ooo.. bleed valve, stock turbo, original bov, shiny intercooler, your tyres are a bit worn on the inside"
me: "oh really"
NC: "yeah, they are ACTUALLY not road worthy u know"
me: "really? so am i in trouble"
NC: "No-no not now, not really... back tyres seems ok, but u got no points for cleaniness" (my car was dirty)
me: "hahaha... yeah havent got around to wash it yet"
NC: "ok... well off you go"
and Nark, my exhaust wasnt that loud, has it tested awhile back ago and was 88db.
https://www.sau.com.au/forums/topic/73671-am-i-in-trouble/#findComment-1355551
me: yup
me: "oh really"
he was a good cop and usually cops dont know shit about cars at all
https://www.sau.com.au/forums/topic/73671-am-i-in-trouble/#findComment-1357629
    • I'm not 100% how the BMW racers do it, but I know from other brands like Merc, moving, and changing the coolers is one of the things. Like getting a transcooler out from infront of the radiator to out near a wheel arch. So some of the stuff you've got crammed in the middle front, spread it out and open up where you can in the bar to get more air in to the sides.
    • Small update for the day... Turns out the intercooler and engine coolant hose kits are anything but complete....I probably should have counted better but it only really covers about half the coolant hoses in the car, it really just covers the visible stuff and pretends everything else doesn't exist (turbo water feed and returns and also heat exchanger lines through the 2 pumps and cooler) .In any case, I'm happier to have half reliable hoses than none, but a bit of a disappointment. Anyway...finger click (and 5 hours).....hoses in place, lots of spring clamps replaced with screw clamps, and engine coolant is on the pressure tester for the night.   Incidentally, upsized header tank is an Inifiniti factory option....not sure I'll ever do prod car racing in this but at least it is legal.
    • Just weld it onto the hot pipe. If you want it right after the turbo, put it right after the turbo. Or rip the comp cover off and drill and tap a hole into it.
    • hahaha glad I can rely on you two to go on a spiral at the drop of a problem! Some quick answers....the ducting is excellent top bottom and sides....everything that gets in goes through the coolers (noting the oil cooler redirects it out again, fair call if it is cooling 120o+) and the heat exchanger for the intercooler also has some scoops to pick up more than it's fair share too. I can't see going down the water spray track....no bueno for formal racing and a big risk for long rally days if you run out (plus I'm not clear if it is allowed there either yet).   Frankly, it must be possible to reliably put 400kw through a standard front end, the BMWs do it so I just need to work it out....I'm starting with reducing blockages in the way and adding some coolant capacity with a bigger header tank, flushing rad and making sure it was filled/bled properly (I didn't do the last coolant change); also taken measurements incase next step is a bigger/higher capacity custom radiator
    • wow, a completely stock GTR! I've got to admit, I have no idea from what you are describing....do you have  any idea where the "thump" comes from, and are you certain it is the HICAS light not something else like the cat overheat light?
