Hi Guys,
Quick question,
I'm just about to buy either an K&N air filter or an Apexi air filter(second hand) for $150 bucks and $250 (respectivelty), the K&N doesn't have the adaptor kit to suit the gts-t R33.
I have attached a pic of the K&N.
Anybody know how much this piece would be and where I can get it from? (Adaptor)
Or
I might buy the Apexi Air filter for $250 (second hand),
Firstly does any one have any photo's of what it looks like - Apexi in the engine bay (or out), this one comes with the adaption kit but is it worth $250 bucks???
Thanks for your help.
Rob
https://www.sau.com.au/forums/topic/737-apexi-kn-air-filters/
the apexi one looks similiar to that k&n one expect it's got red in it.
from what i've read and heard the apexi is the way to go. it is meant to have the best performance increase out of all the filters on the market.
i will be looking to get and apexi one within the next couple of weeks. does anybody know where you can buy these with the adaptor kits?
https://www.sau.com.au/forums/topic/737-apexi-kn-air-filters/#findComment-16720
I got an Apexi Power intake kit for my GTR, and i wouldn't hesitate to recommend them to everyone.. The instructions (although in japanese, thankgod for pictures) are easy to follow and it comes with all required brackets and moulded steel adaptors.. Much much better than my previous experiences with australian made air filters in which you have to make your own brackets etc..
took me about 1hr to fit, which included pulling the factory box out, working out instructions and hooking it all up (mind you i had to deal with 2 pods though the fit and brackets where spot on!)
Also realise that for any actual improvement you may want to build a cold air induction box as well, to keep the hot air out from the engine bay. i havn't gotten around to that yet, and you can significantly feel the loss of power and response when the engine bay gets hot.. the turbo sounds awesome though and it makes the stock BOV's louder too (bonus! :-)
so make sure you get all the included adaptors and instructions...
https://www.sau.com.au/forums/topic/737-apexi-kn-air-filters/#findComment-16838
I've noticed the K&N revs out more freely than the restrictive
stock air box..
I got mine for $146 including bracket at American Auto Spares
Anything is better than the stock air box.... :devil2:
the induction noise....
the minute blow off noise u get...
ehaheah as u can see i'm obsessed.... cause thats the only
mod i got!!! :hellpisse
https://www.sau.com.au/forums/topic/737-apexi-kn-air-filters/#findComment-17062
Thanks for your replys.
Hey Macka,
how long does it take (roughly) to order and have it shipped to Sydney??? (sounds good)
XrSiSt,
Does that shop you mentioned (American Auto's I think) sell the bracket to attach the K&N to the AFM sell them seperately??
If so how much and where is the shop?
https://www.sau.com.au/forums/topic/737-apexi-kn-air-filters/#findComment-17074
Yeah they do sell it seperately, they charged me only $30 but I
bought the air filter also so i'm not sure how much they go for
individually.
The majority of car accessory shops sell them.
American Auto Spares is in Beverly Hills which may be a bit far
for you, so it may be just worth paying a bit more somewhere
else thats more local.
This is how mine looks
:burnout:
https://www.sau.com.au/forums/topic/737-apexi-kn-air-filters/#findComment-17078
Takakaira is pretty good with delivery 5 days to 3 weeks depending on availibility of parts..
Yes im sure the APEXI filter comes with the brackets it says that on the site check it out
Anyone want to buy my HKS Powerflow pod for R33 with brackets? The filter itself is in good nik.
It was on the car when i bought it and ive had the car for 2 months $100 cheap cheap :burnout:
Im in perth
https://www.sau.com.au/forums/topic/737-apexi-kn-air-filters/#findComment-17110
I have the same filter as Robo and GrimGTST
there rated to flow enough air for 260hp so with 215hp at the wheels i'm pretty close to that 260 at the flywheel. the bigger K&N want fit in there :P
What power is the apexi suppose to be good for? and do u need a special oil like the K&N to clean it?
https://www.sau.com.au/forums/topic/737-apexi-kn-air-filters/#findComment-17272
yeh K&N and Apexi are the best two pod filters you can buy
K&N's are legal, not sure about apexi, if that makes any difference to your choice.
i have a K&N and a mate has an Apexi power one and they both seem very similar in noise and performance increase, just remember to take advantage of a pod filter you have to get cold air to it, so remember that when installing it etc cos you will in the end either enclose it or run a pipe from underneath it etc.
https://www.sau.com.au/forums/topic/737-apexi-kn-air-filters/#findComment-17769
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
