Went to my mechanics @ Bezerkly Automotive today to get ready for this weekend's Drag Combat event and what do I see? 4 other RB's (3 Skylines, 1 VL) in the workshop getting the treatment :D
Took a look around and snapped some shots then wandered into their new retail shop and nearly emptied my wallet instantly. :headspin:
rbplenum.jpgrbplenumbottom.jpgrbrail.jpgrb25vl.jpgvlhimount.jpgworkshop1.jpgworkshop2.jpgbellmouths.jpgrb30plenum.jpgrb25plenum.jpg80mmbillet.jpgfamilyphoto.jpg
And some blatant self-promotion:
Awesome stuff!!
Adrian
https://www.sau.com.au/forums/topic/73751-bezerkly-automotive-skyline-gurus/
I did the nitrous setup myself and it cost just under $1000. The plenum looks sexy as hell in person with ridiculous hours having gone into the design of it.
I wish I had the talent and patience that Paul has. Incredible stuff.
Adrian
Guest two.06l
Adrian
Was that "twoogle" visiting?? i thought that there was a few more kays on her when i got home from work today!
geez that engine bay of yours sure says " I've got nitrous " :) . I noticed you still have a little bit of line between the solenoids and the fogger, the way I had mine setup I stuck the solenoids right up hard against the fogger as it eliminates any delay and surge, although it's a bitch to fit it. On top of that I had tried to hide it all with a 'polution' disguise. Using polution style rubber hose over the top of the braided lines (cut it down one side and press it on).
geez that engine bay of yours sure says " I've got nitrous " :P . I noticed you still have a little bit of line between the solenoids and the fogger,  the way I had mine setup I stuck the solenoids right up hard against the fogger as it eliminates any delay and surge, although it's a bitch to fit it. On top of that I had tried to hide it all with a 'polution' disguise. Using polution style rubber hose over the top of the braided lines (cut it down one side and press it on).
I've got nothing to hide :) The tiny amount of line from the solenoid to the fogger makes sfa difference. Until very recently I had all 3 solenoids hanging off the back of the fogger but it became more trouble than it was worth. i.e. the weight on the back of the fogger made it forever loose in the inlet pipe, the jets were a prick to change (which we're doing more often now) and getting to the plugs and coils is much easier now too. I'm a natural born poser so I don't want crappy looking black hose everywhere. :kick:
do they make a few of those plenums? do you know what they retail for?
They make and sell a few of them. There were 2 cars getting them fitted while I was there and they have them on the shelf. I think they're about $1500.00
Adrian
    • God I love shiny engine parts 🥰 Are you looking for more horsetorques in the mid range? (Smaller cam) Or just more horsetorques every where? (Big heads and bigger revs) Assumption: they were not bought late night shopping on the interwebs after drinking too many beers, which is typically how I pull pins on things......🤣 The evolution of your car is coming along nicely, I sometimes wish I didn't get bored with my cars and keep flipping them, maybe the MX5 will be different
    • I got the hazards working! Turned out it was disconnected! Indicator stock still isn’t working. I took the steering shroud off and there seems to be a third connection missing I see two small white connectors but they don’t fit the indicator switch unless they need a short lead to convert the connector type. Can someone point me in the direction of the wiring diagram for the indicator switch?   https://share.icloud.com/photos/0e8ReiFSLBVJsTPUKKfA_1IdQ
    • All of your suspension bushes/bolts etc, should also only ever be tightened when the car is sitting with full weight too.   IE, jack it back up, shove a heap of stuff down so you can lower the wheels onto so the car is "on the ground" but you have room to get under it.   It's why when properly done, you should be able to remove the shock and spring, but the arms won't go to 100% droop. If you don't do the above, you'll destroy your bushes.
    • We have some more genuine Japanese legally decommissioned car number plates in stock 🙂, as well as the plain white 40mm hole cover: Tama 400 No 12-41: https://www.oemsoko.co.jp/products/genuine-decommissioned-japanese-vehicle-number-plate-set-no-1241 Morioka 300 Te 43-58: https://www.oemsoko.co.jp/products/genuine-decommissioned-japanese-vehicle-number-plate-set-te-4358 Plain White 40mm Hole Cover: https://www.oemsoko.co.jp/products/genuine-japanese-vehicle-number-plate-40mm-hole-cover-white There's also a yellow plate for Kei cars with the corresponding yellow 40mm hole cover sold as a set: Tsukuba 581 Ii 64-66: https://www.oemsoko.co.jp/products/genuine-decommissioned-japanese-vehicle-single-number-plate-ii-6466 Also some Skyline 1/43 scale models: 1989 BNR32 Nissan Skyline GT-R (Silver): https://www.oemsoko.co.jp/products/rare-ebbro-oldies-2006-release-bnr32-nissan-skyline-gtr-silver 1989 HCR32 Nissan Skyline GTS-t Type M (Red): https://www.oemsoko.co.jp/products/kyosho-original-1-43-hcr32-nissan-skyline-gts-t-type-m-red
