Alot of guys have recommended Autronic SMC. I had a second hand ECU and loom etc lined up but it looks like that may have fallen though. Brand new Autronic seems pretty expensive. (and I don't need Anti-lag)
I would prefer to buy an Australian product and at the moment I am leaning towards Microtech (my mechanic also specicalizes in Microtech). Price is also an issue.
Microtech also seems like pretty good value which it good because I don't want to send more than $2000 approx.
But I have also seen a lot of guys with haltech,EMS, Wolf3d.
Has anyone had the chance to witness some of these different setups in action?
Can you point out the pros and cons of each. Is it just a matter of your tuner knowing what they are doing.
Is it just same sh%t different bucket.
I don't know much but I am learning.
Cheers
https://www.sau.com.au/forums/topic/73776-aftermarket-ecus-for-fj20/
the autronics and motecs are definetly more advanced ecus , but may offer features you dont need . Good results have been had from the ecus you mentioned . If you have a mechanic who you trust and he specialises in microtech and he can show you past results similar to what you want then go for it .
you can find 2nd hand autronics from time to time if you search
I'm about to fit up a MoTec M48 Clubman. Originally bought for my Z (which is currently running a Haltech E6A), I'm going to wire-up the DR & then buy a second loom for the Z. All up it was about $2600 with loom & sensors, but should do the trick nicely. I would use my E6A but it doesn't talk to Nissan optical pickups...
There are people around doing laser cut optical disks for the FJ20 CAS . I opted for Autronic SMC because the software is better charge temperature wise and the Haltech people dont seem to understand the importance of sequential injection .
My SMC is for sale , complete with late style FJ20 CAS laser cut disc . Includes coil ignitor TPS relays loom etc . PM for details .
Discopotato, is that you Adrian? It's Glyn from FJ20.com If it is I am still keen to buy your setup.
If it's not Adrian, how much do you want for your setup?
Cheers
  • 3 weeks later...
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
