  • Replies 42
what gts-t vspec said :D
what do you do if you buy splitfire coilpacks cos stock coilpacks fry with a wolf, and then the wolf fries the splitfire coilpacks?
pls explain?
i have a wolf in mine, so far the only issue is the lack of tuners.
if its going to be cooking my coilpacks then that might explain my engine troubles atm...
I've had stock coil packs and split-fires running with my Wolf with no issues, as have most, seems that the tuner forgot to set the dwell time properly which has caused the issue. I do feel sorry for you, but it's not the products fault, its the person who set it up.
i wouldnt recommend getting a wolf in the first place they are completely not worth it.
Spoken like a true fool. Present facts b4 spinning 5hit. I have used this ecu in my car for the last 2.5yrs without any issues, apart from tune tweeks.
Yeah if you ask Lumpy (hyperdrive) nicely he may do it for u, just dont say who told u that he does a good job on them :)
I also agree the dwell time on the spark will make the coils crack along with a few other combinations but the wolf3d standard r33 ignition program is pretty well on the money, mes betting u may have a faulty loom.
Congratulations!! Your nomination for "Nob-end of the Month" has been accepted!
:kick:
I still use the Wolf with Great Results, on stock coils & splitfires! It now controls my 26 auto , using a 25 harness & stock 26 CAS....
Ewen , as for where to get it tuned , go to whoever your Happy with...just remember that no-one can tune out mechanical flaws like udersized exhaust housings , dodgy injectors etc...
Cheers
    • 49719 is the cooler loop. Right at the front, LHS of that diagram. Return line from rack (LP side) goes to cooler loop on RHS front of car, then back under engine and returns to bottom of tank. 49717M is feed from tank to pump. HP line out of pump is thick rubber, followed by the hard line that runs down to crossmember and runs in parallel (but opposite flow direction) to the LP return line. Nothing goes anywhere near the firewall or interior of car. The closest they get to that is the connections on the rack.
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
    • Don't worry about. Just don't try to drive hard enough to make boost and you'll be fine.
    • Yes. This has already been said. It is a loop of hardline in front of the radiator. Because.... the pump is on the LHS and the steering rack hydraulic connections are where they always are on a RHD steering rack....on the RHS. The high pressure line goes down under the engine, along the crossmember, like it does on all Skylines. Don't just throw expensive braided hoses/other kits at it. Work out what is wrong and fix that.
    • Still got the afm on the intake, clamps are shut tight, only loose hose is the one that goes from the j pipe towards the IACV, since it's next to impossible to find a factory hose and the barbs are different sizes (I'm still using clamps on this hose to try and help it seal on the iacv side) I've ordered parts to make up the hotside of the intercooler pipes, I'll plumb it in and see what happens in a few days I suppose The turbo's internally gated, can I just unscrew the tension rod to let the gate open?
