rb20 and rb25 afm are same size and same calibration.
Rule of thumb for Air Flow meters RWKW & Engine BHP
------ ---- OD ---- RWKW ---- RWKW ---- BHP ------ BHP
No of AFM's ---- ------- 1 -------- 2 -------- 1 -------- 2
RB26 ------ 65 ------ 149 ------ 299 ------ 271 ------ 474
RB20/25 --- 80 ------ 226 ------ 453 ------ 376 ------ 683
Z32 ------- 80 ------ 255 ------ 511 ------ 415 ------ 763
Q45 ------- 90 ------ 302 ------ 605 ------ 479 ------ 890
OK the rb20/25afms are a good upgrade for the gtr rb26 with a pfc as the afms will plug straight into existing harness and can be selected from a menu in the setting of the pfc ,the only thing is, it normally requires some customising of the pipe work to the turbos from the afms (the same as would be required for the z32) and the best advantage over nismo units is price and less restriction to flow (80mm over 62mm) PLUS i remend de-screening them as the mash covers about 33% of the cross sectional area of the afm and the turbulence would be significant (just make sure you run good filters).
PS. if you are aiming over 540rwhp i would go the Z32 as my rb20/25 were reading 5.03volts(5.13 is max out) at around the 529rwhp mark, my z32 now read in the low 4volt range for the same hp.
cheers
Aftermarket piping is beneficial however it isnt required so to speak. If you dont have the funds they do sqeeze into the factory rubber piping. I did this with mine!
Piping is expensive. The Greddy suction kit is $1,100 odd delivered from nengun!
I have removed the rear screen on my afms. Not the front as I've heard conflicting rumours.
How accurate are these figues?
Need to get a resonable guess to get me started as i am soon upgradeing my RB20 afm to z32 using the stock ecu.
rb20/25 afm's are the same . I have rb25 afm's on my GTR if you have custom pods then they will probably not bolt up to the 80mm afm's like I found with my blitz pods. I just bought two gts-t pod adapters and mounted new filters . The rubber turbo intake pipes just squeeze over the back of the 80mm afm's help to heat them up they slip on easier. Have a look in my gallery have a pic of the my engine bay with rb25 afm's .
in my opinion if your looking to replace the std afms it means you are looking over 400rwhp as i believe that about where the std afms start to run out of head room, and that be so you are starting to look at serious power levels.
So concider this while people go full on with big exhausts and plenums and coolers to etc etc why would you run a resistive intake where the air has to be drone in (not pumped etc)
so the choice of good filters and intake piping and large not resistive afms are very important as this is the first link in the chain
(as what air you are trying to pump through the rest of the system must pass through here first and must do so under no pressure only by the vacuvm of the turbo intake)
eg why put a ~2"x2(ID)grilled afm on the intake and a twin 3" exhaust or 4"intercooler
the grill takes up about 33% of the cross sectional area of the afm and serve no purpose but to add resistion to air flow(i believe the only reason the grills are there is to stop objects touch the afm elements).So if you run good filters and dont go putting tools or fingers into them the grill is redundant.
my 2c
I made a post a while ago about running the AFM inline as well as increasing the ID of the pipe the AFM is installed into to allow more power before maxing out etc.. I got no responce..
I will be trying this on my own setup though. The AFM probe is simply O-ringed into the pipe. I think if I run a single GTS-T 80mm AFM inside a 4" pipe, this will have the same flow as 2 x 3" pipes, saving a lot of space :(
e.g a 80mm GTS-T afm in a 4" pipe should in theory allow 453rwkw. I'm not sure how this would effect the resolution however. I was hoping an expert could shed some light..
Seems like a lot easier and cheaper way to do things if it works. I know of a few cars running AFM's inline on the pressure side of the piping. Normally after the Intercooler.
    • I started with the above in my head too, and I might be reading / thinking about what they want wrong, which is why I complicated it a bit further. Purpose I'm seeing is for the corner indicator to be on with headlights, and then if the indicator turns on it can still flash. The relay part above I can see working as required, except in the case of headlight is on, and indicator is on. The change over relay you've wired in would get signal from the indicator, and as it flashes would give power to the globe from the indicator, but as it flashes off, power comes from the headlight, which would cause the indicator to be constantly on when headlight is on, even while indicator change over is flashing. That is unless we don't care if it flashes or not if the headlight is on? I guess that's an OP clarification.
    • HI, Ive got an r34 gtt sedan A/T. The instrument cluster went out and I replaced it with another A/T everything visually looks the same and all the gauges work now with the exception of the speedometer and odometer. The speedo will stay pinned at zero until I'm going about 55kmh and then it'll say Im going about 5kmh. my odometer seems to be tracking at about a 1/10 of what it should. If I go 1km it'll say I've only gone 0.01. Appreciate any and all help. Ive tried searching through the forums reddit and a local fb group. The only info I think I've found is that some cars didnt come equipped with TCS (mind is) and the clusters may be different between those? I've also installed a brand new VSS and no joy obviously. TIA.
    • what speedo healer did you use?
    • Certainly. It is probably broken under the wire style clamp. At least that one is easier to get at than the front one.   Sounds like it isn't a major leak, I'd start with backing off the the water feed and return banjos into the turbos half a turn then tightening properly. Hardlines can still crack over time, either in the tube (particularly when turbos are changed if the banjo is siezed in the the tube) or at the brazed joins between the lines and the banjo fittings. A coolant system pressure test will reveal all. BTW you'd be able to get a sump without exchange, it will just cost more as they will have to source another stock one for the next customer. If you want to address the sump a much better option is something like this https://www.hioctanedirect.com/hi-octane-racing-sump-extension-nissan-rb26 that you weld in locally (and add the oil return fittings at the same time)
    • Pretty sure you are thinking of the throwout bearing there (which you should change when you change your clutch), when they are worn they will get quieter if you put your foot on the clutch. An input shaft bearing is turning/noisy at all times.
