since i cant offord big flash new brakes i decided to dress up my crappy old calipers, i went and bought some dupli-color, metalcast anodized paint, i selected blue took it to the counter and the guy told me i needed the proper primer for it, i thought he was just tryin to scam me, but you do actuly need it to create the shinny reflective anodized look, i painted them and they turned out really good since my rim's have already got anodized blue in them they matched really trick, it is heat proof specificly for calipers and rocker covers ect ect, im gona do my valve cover also so ill let yas know how it turns out, but its really goot for dressin those dull parts up,
https://www.sau.com.au/forums/topic/73794-how-to-anodize-your-brake-calipers/
  • Replies 182
that looks cool! You did a gr8 job.
Im gonna do mine either gold or red one of these days.
Hopefully they'll turn out as good as urs did.
cheers man, i had them a flat blue before, but was so dull, it comes in red gold green, heaps of sick colors, all i did was give them a sand down till was smooth, then got mag cleaner to get all the brake dust of, then just prepsol, left them to dry, 4 coats of silver primer, 4 coats of blue, just one thing, make sure you get all the brake fluid out of the caliper cos it can oozz out 1/2 way through and wreck it, and also becarful the brake line is clean when reattatchin it,
should i be taking the calipers off ?? or did you just cover the brade pad thingy at the top ?
so you sprayed it with primer heaps, then the actual paint ?
How many cans did you go through to do the front 2 ?
Now the question is.. what color do i want to do em ? my cars black with white wheels.. Im not good with decisions :D
yeah u take them of completly, i went through 1 can of primer stuff, one can of blue for the frount, and still got enough for a 3rd i recon, with ya car i recon a gold would look ok, whatever ya color scheme is, i recon black and green go ok too, but dono if they will suit the white rim
sorry for being anoying :)
if the take the caliper off, is it easy to put back on.. like there wont be any alignment issues etc etc ?
na mate just 2 bolts and the brake line, then to put back on just seperate the pads, and put bolts and line bak on, that easy, then bleed ya brakes all good
They look great, they're a lot shinier than my blue calipers. When I did mine I used VHT brake paint & finshed with a glossy top coat.... but, I want yours dammit :) . I might have to try this dupli-color metalcast anodized paint when I do my rocker/ cam covers.
They look great, they're a lot shinier than my blue calipers. When I did mine I used VHT brake paint & finshed with a glossy top coat.... but, I want yours dammit :rofl: . I might have to try this dupli-color metalcast anodized paint when I do my rocker/ cam covers.
yeah its a wiked paint, they turn out soooo dope, and i think its cheaper then normal stuff, i had that cull vht crap b4 but this is the stuf ya want
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around without a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
