According to their website, if you're applying METALCOAT to bare metal surfaces (ie. you wire brushed your calipers first), your meant to use " CP-199 Adhesion Promoter".  If the surface is pre-painted, you use the METALCOAT Groundcoat. See here: http://www.duplicolor.com/solutions/faq.html#anchor17
Lucien.
well i didnt, and mine have stuck for 3 weeks, and survive the weekly high preasure hose blast at close range from my local car was (sparkles in midland) hahaha but you cant just buy the blue paint and spray it, ya need the primer also it is the primer that alowes the anodized effect the blue just adds the color, the pain i think was around 35 bucks or somethin from auto1
  • Replies 182
I emailed Duplicolor asking about the durability of Metalcast for brake applications, and to check if applying a clearcoat for further protection was necessary/recommended. Here's their answer:
Lucien,
Thank you for taking the time to contact us.  There is no problem with using the Metalcast on brake calipers.  The Metalcast is resistant up to 500 degrees F.  We do not recommend applying a clear coat over Metalcast.  Applying a clear coating will alter the overall appearance of the Metalcast paint.  Generally a clear coat will dull and mute the color and metallic cast of the paint film.  The Metalcast coating does not require a clear coat - Metalcast is a durable, high gloss finish on its own.
Good luck with your project.
Regards,
Ray
L.
I finally got my calipers off, and after going to 5 different shops finally found someone who sold the MetalCast paint:D Will give it a go tommorow:D
nice mate nice, be sure to let me know of how they turn out and snap a few pics to hey, see if i loose my brake caliper painting title belt ahhaah
  • 4 weeks later...
Does anyone know where i can get this MetalCast and ground Coat?..I've been  asking a few Auto1 stores in Sydney and they never heard of it.
cheers,
Maybe try the manufacturer for recommendations?
http://www.honeywell.com.au/contacts/consu...er/default.html
Lucien.
Shmiddy, After suffering a few minor hassles, I finally got my calipers sorted, and I'm very happy with them. Will be doing my wheel nuts next:D
got any pics mate, what color did you go with and how did you find the paint, good find wasnt it, ahahha, mine are still like the day i painted them, another little thing i did was since on my grill i have no badge i painted the bonnet latch with the paint to, looks pritty good, doin my engine cover to, but waitin till i get new intercooler pipes so i dont have to rip em of again, but post up some pics if ya can
    • You know, that is exactly the thing that I was thinking a coupe of hours ago. I even had a plan for a meme, involving one big one, another big one, and the Old El Paso girl saying "¿por que no los dos?"
    • NoS, 2 of the big ones.
    • Oh, that's grim. Something bad has been happening there.
    • Put an endoscope down the hole and saw this. Not quite all around the bore but a good 60% at least. Chin to the chest and towards further disappointments I guess.
    • 2 does "sort of" applies, maybe......but looking at what parts would be needed for the swap to get engineered, registered, and insured, and basically that's everything under the car, the modifications the make it legal would be problematic and horrendously expensive, all for a street car that just cruises around and hits a few twisty roads on the weekends Also, from looking at the NSW rules and Regs, with all modifications that is required just to make the car safe and not twist itself to pieces, and then actually get registered for street use, may still be impossible nowadays As for 1, when you add in a fresh engine, fresh transmission, rear cradle and diff, tailshaft, suspension, brakes, cooling, and all the other fabrication required, your probably looking at up to $100k to do it right, all for a 20 year old MX5 that is over engineered and you would never be able to actually use the power it has on the street, much like your beastie, which I love, but you actually track that thing and can use all of its powers in anger, in a safe environment  Hell, the old Bogan Cruise Ship had more power than I could use on the street, and in hindsight, I went a bit silly on that thing, it didn't really need the 500hp it had for what I actually used the car for, it was fun, but basically unusable on the street if you value your licence  As for cams, yeah, I'll probably book it in for them to get installed and tuned soonish, like next month after MX5 Mania are back at work....... and yes, I've already sent a email to bin the turbo quote and quote instead to install cams and a new Fluidampr balancer that will suit the 2.5 better than the OEM 2.0 balancer that is swapped over for the 2.5 install, as the balancer needs to get pulled to time the cams it's a while your in there sort of thing I did think a bit about flex fuel for a laugh, but being na, and no where really around locally anymore to get E85, I've binned that idea, so no sweet sweet corn smells are set for the car I wish E85 was more of a standard fuel, it's better for the environment, better for tuning, plus that sweet sweet smell we all love As for fitting in the family, that's not needed, as everyone in the family already owns a car that can seat 5 humans comfortably enough, the MX5 is "my toy" As for buying a car that is already built, nah, I would rather pick and choose my parts, I enjoy the process, and in the big picture, the additional cost is well worth the enjoyment, and the occasional frustration, I get out of doing it, albeit with other people spinning the spanners, and me, just paying the invoice 🤣
