  • Replies 182
Bump.
I just bought a can of that Dupli-colour metalcast paint in the red. Will 1 can be enough? they only had one can left.
I was thinking of using Septone Automotive's Brake Caliper & Drum Paint for the primer as I already have a few cans of the stuff lying around my garage. Anybody know if this would be okay to use with the dupli-colour?
Also, anybody tried just taping up the surrounding area than applying the paint? Or would it be better off in the long run to pry the Calipers off & paint them.
Cheers
Oh & schmiddy, excellent job. If it wasn't for this thread I wouldn't even have considered doing this for myself :)
hahaha no wories mate glad to be an insperation ahahah, man i would ge the proper primer, just incase, for the sake of it, cos it would be a shame to have them on a week and the paint not take proply or something, and yeah i took the whole caliper of, not to hard a job just brake line and 2 bolts, turns out awsome that way, one warning, bleed your barakes once there back on as takin the lines of gets them full of air, and watch reaplying the caliper that brake fluid doesnt get on the newly painted caliped, that shit chews the paint straight off, good luck mate
Awesome Thanks for that Shmiddy I should be getting around to it soon. I'm going to take a few test sprays on some old brake pads I've got lying around to get an idea of the finish with the primer I'm going to use.
Cheers again buddy :(
For those guys still looking for Duplicolor Metalcast, the Australian distributor is Hoits/Hoyts (damn forgotten the spelling already) and they are on 1800 021 106.
AutoOne stock Duplicolor (the normal range) but can definitely order Metalcast for you. If the storeman gives you a funny look, get them to ring Nationals or ring Hoits themselves on the 1800 number.
Cheers!
I just taped/masked mine up around the disks and they came up fine. The slight overspray on the discs disappears after about 5 minutes of driving! Taking the discs and brake lines off is a pita.
i havent seen this product(or read the complete thread) but am tipping its just a candy ..would i be right in saying its put over the top of a silver?It will also be an acrylic system which will just wash off with any type of solvent.... Another way of doing it is strip the paint off the calipers then spray etch primer on them then paint them in a silver ground coat and get a product called SEM candy concentrate in what ever colour candy you want....add the concentrate in some 2K clear and thats it....Its certainly a better way of doing it and will last as long as your paint on your car and will have to use paint stripper to get it off....To answer shans question,this system has been used for 20 odd years and we have painted complete cars/motorcycles with it...I am sure that people are aware that this is not anodising...its just an anodise look....cast cannot be anodized properly
Hi Troy
From their website, it is an enamel that you prep the surface with their pressure pack "Adhesion Promoter" for bare metal then paint with just the one type of paint.
And yep, I'm pretty sure everyone understands that it is paint and not anodizing. Still looks a treat for old calipers.
Mark
Hi mark...acrylic/single pack enamels both have the same characteristic's altho enamel will go over anything and not play up where as acrylic over single pack enamel fry's up...so having said that once you paint anything in single pack enamel your stuck with it untill you bare metal it.....both still wash off with solvent tho,which would concern me with using this product as some wheel cleaners may strip it off....
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
