R32 GTSt Interior, Rb25 head + Pics
Hi as it says i have R32 GTSt interior including, seats (front and rear), door trims and rear trims. Only selling coz i bought the GTR equivelant of all and converted.
Interior items are as follows, all from R32 GTSt:
*front seats, on rails (small tear on drivers side) - $300pr SOLD
*rear seat (immaculate) - $150ono
*rear trims (the bits that are either end of the back seat, with the arm rest) - $150ono SOLD
*Front door trims - $150
Will sell whole lot for $600, you pay delivery.
ONLY REAR SEAT AND DOOR TRIMS LEFT
Head sold.
Cheers
G
Edited by geordie
RB25 head, cams, and cam gears included - $400
Rb25 intake plenum, trottle body, injector wiring loom - $250
Rb25 Injector rail + stock regulator and stock injectors - $150ono
Package price for the above please, and can you organise delivery or would you prefer me to.
$650 plus what ever delivery will be, i suspect it may be to heavy for good old aus post, but yeah i will check out some prices for you if you like. Prolly through pack and send or someone similar.
Cheers
G
what condition are the door trims in?
how much will you do the entire rb25 set up for?
thanks
Same price i gave funkymonkey for rb25 stuff.
As for the door trims, they are good...BUT! the cloth part has come away on the drivers side. They also have tweeters glued to them down near the grill, as you will see in the pics) if you want pics, pm your email addy.
Cheers
G
Hey where abouts in melbourne r u? Do u still have the inside air conditioner air vents if so how much will u sell them for becos i need 2 put them in my car so it can pass a road worthy can u please call me on 0413442008 catherine after 4.40pm thanks
You havent read my post at all have you? Or my location? Its ok i wont hold it against you. Best bet if your chasing vents is to go to nissan direct. The r32 GTR was sold in australia so they can stil source parts. I last heard vents are around the 30-40 mark.
Cheers
G
geordie, price sounds good depending on freight costs, worst case scenario I'll drive up and pick it up or something with a deposit.
Can I get some high res pics of the parts I'm interested in sent to [email protected]
Cheers
Cheers
Head, plenum and injector rail are about the 50kg mark all up. So definately to much for aussie post. Even split into multiple boxes the head its self is about 25kg.
Cheers
G
hey do you have the power window switch from the drivers side door?  If so wat condition and how much?
Nope only the door trim. No switches, no handles, or vents. Just door trim, rear arm rest trim, seats. These are the only difference betwen the gtr interior and the GTS..
Cheers
G
 Share
    • Luckily I haven’t bought one yet but I’ve had several people tell me different things and was trying to find out what’s going on with my car lol apparently type m had different lover knuckles like the gtr but someone put non type m knuckles on mine Ok on another topic does anyone have a spindle for sale mine is screwed bad lmao
    • The vendor you bought from is a dickhead who can't tell the difference between AWD and RWD bearings. Their eBay listing is one of the first hits too, and is wrong. Any other hit shows the ones that are on your car. A search for GTR rear wheel bearings, unsurprisingly, finds the one you have from Shift. f**king muppets.
    • Got the flat door cards "good enough" for now. After cutting out the arm rest I removed all the stock trim material. Then filled the gap with a bit of Masonite and wrapped it in some adhesive foam to hide the  transitions as much as possible. Then I applied some black vinyl material to the panel with some spray on contact adhesive smoothing the edges as best as I could. Here is how it sits in the car with the door handle and cut down window switch mounted
    • Ok so I have a little bit of an issue. So I have a 1992 r32gtst and trying to replace the rear wheel bearing and spindle the research I’ve done shows a different style bearing than what is currently on my car. So the picture of the new bearing with the box says it’s the correct bearing as does my research but the picture shown of the old bearing is the one that came off the car. I’m a bit confused the new bearing has an ear on it that I’m assuming goes to where the top of the ebrake shoes mount as to where my old bearing does not. Any help would be awesome
    • What in the absolute mind f**k. Generally speaking, you cannot diesel a petrol engine without sparkplugs which you don't have since you're disconnecting battery.... Something is very fishy here.
