  • 5 months later...
Hi all
Recently have a problem with the car
When the car is idle, it would sometimes shudder/shake for about 1/2 second
This can occur randomly at idle and makes no sounds
Any suggestions at what it could be ?
Thanks
Eric
Got the same problem with my 34 GTT. It only seem to show when car is warmed up. When the oil temperture pass 90 degree and sitting idle the random shake and you can hear spluttering sound from the exhaust.
https://www.sau.com.au/forums/topic/73847-shudder-at-idle/#findComment-1649392
have had this shutter too for about 2.5years
only appears when the engine is warm, and is worse when the engine is hot
...but doesn't seem to be so bad when its a cold day
tried to change:
- afm
- spark plugs
- all coils
- ignitor
- fuel filter
- tried fiddling with wires to see if its an electrical problem - no luck
- had injectors cleaned about a year and a half ago
also tried cleaning IAC, fiddling with throttle switch, and cleaning the intake manifold with some carby cleaner all with no luck
if you find what it is, then i will have sex with a monkey
Waz.
https://www.sau.com.au/forums/topic/73847-shudder-at-idle/#findComment-1653257
tried to change:
- spark plugs
- all coils
Waz.
hmm. bugger. so changing the coil didn't fix the problem. I was seriously thinking of picking up a 6 pack splitfire coil n replace them all and hoping for problem solved. But I guess I will have to look else where.
Anyone else got the same problem and had it sort it out?
https://www.sau.com.au/forums/topic/73847-shudder-at-idle/#findComment-1662449
Mine has started doing it in the last week or two... Just a quick shudder and a gurgle from the stock exhaust system. Only when warm.
Interesting! I thought I was due for new spark plugs, cause it sounds like an occasional miss.
Do 34's have the ignitor in the ECU or engine bay?
https://www.sau.com.au/forums/topic/73847-shudder-at-idle/#findComment-1666968
Hmm.. and it is the same on my series 2 R33.. Wondering if it is getting too hot where it is and not igniting properly sometimes? Anyone with a series 1 R33 experiencing the idle shudder?
Also, Ed... does that free ipod thing actually work? I've seen the same scheme for car head units. =-]
https://www.sau.com.au/forums/topic/73847-shudder-at-idle/#findComment-1669617
I have an R33 S1 and it's also affecting me. It only used to happen a poofteenth before I got my atmo BOV and now it does it pretty hardcore. Unless I leave it for 4 hours between drives. If I warm up the car for 5 mins in the morning I'm fine. It's when I stop and start the car (like doing grocery shopping or something) that it happens most
has anyone used the the eletronic idle stabiliser?
Clicky
Does it work?
Someone mentioned that another result of shutter is also loss fuel economy... Will this also fix that ? I
https://www.sau.com.au/forums/topic/73847-shudder-at-idle/#findComment-1670156
I was going to have a guess and say; since my O2 sensor doesn't appear to be working properly, and the ECU is running richer at idle/low revs, that possibly it is backfiring on too much fuel?
I hope this is not just an uneducated guess, and i'll soon see when my NGK O2 sensor arrives.
Incidentally, i'm also running an aftermarket BOV. How's your fuel economy, Kennedy?
https://www.sau.com.au/forums/topic/73847-shudder-at-idle/#findComment-1670302
Well my fuel gauge doesn't work so I can't be sure. (Gotta fix that). I fill up every 200KM anyway coz I believe cars in general run more efficiently on a full tank. By my rough calculations...since the BOV intall by I can only get about 400KM rather than 450KM to a tank. It is a 65L tank isn't it?
https://www.sau.com.au/forums/topic/73847-shudder-at-idle/#findComment-1670436
    • Just planning to have the wiring neat and hide as much as possible.
    • The sodium acetate, mixed with citric acid, doesn't actually buffer each other. Interestingly though, if you used Sodium Acetate, and acetic acid, THAT becomes a buffer solution. Additionally, a weak acid that can attack a metal, is still a weak acid that can attack a metal. If you don't neutralise it, and wash it off, it's going to be able to keep attacking. It works the same way when battery acid dries, get that stuff somewhere, and then it gets wet, and off it goes again breaking things down. There's a reason why people prefer a weak acid, and it's because they want TIME to be able to be on their side. IE, DIY guys are happy to leave some mild steel in vinegar for 24 hours to get mill scale off. However, if you want to do it chemically in industry, you grab the muriatic acid. If you want to do it quicker at home, go for the acetic acid if you don't want muriatic around. At the end of the day, look at the above thumbnail, as it proves what I said in the earlier post, you can clean that fuel tank up all you want with the solution, but the rust that has now been removed was once the metal of the fuel tank. So how thin in spots is your fuel tank getting? If the magazine on the left, is the actual same magazine as on the right, you'll notice it even introduces more holes... Well, rust removal in general actually does that. The fuel tank isn't very thick. So, I'll state again, look to replace the tank, replace the fuel hanger, and pump, work out how the rust and shit is making it past the fuel filter, and getting into the injectors. That is the real problem. If the fuel filter were doing its job, the injectors wouldn't be blocked.
    • Despite having minimal clothing because of the hot weather right now, I did have rubber gloves and safety glasses on just in-case for most of the time. Yes, I was scrubbing with my gloves on before, but brushing with a brush removes the remaining rust. To neutralize, I was thinking distilled water and baking soda, or do you think that would be overkill?
    • You can probably scrub the rust with a toothbrush or something. After you get the rust off flush well with water to neutralize and you will probably want to also use a fuel tank sealer to keep it from rusting again.
    • The sodium citrate solution is designed to buffer the citric acid to keep it from attacking metal quite so much, the guy that came up with that recipe did a ton of testing on how much metal loss occurs over time and it's nothing crazy unless you forget about it for months:
