  • 5 months later...
Hi all
Recently have a problem with the car
When the car is idle, it would sometimes shudder/shake for about 1/2 second
This can occur randomly at idle and makes no sounds
Any suggestions at what it could be ?
Thanks
Eric
Got the same problem with my 34 GTT. It only seem to show when car is warmed up. When the oil temperture pass 90 degree and sitting idle the random shake and you can hear spluttering sound from the exhaust.
https://www.sau.com.au/forums/topic/73847-shudder-at-idle/#findComment-1649392
have had this shutter too for about 2.5years
only appears when the engine is warm, and is worse when the engine is hot
...but doesn't seem to be so bad when its a cold day
tried to change:
- afm
- spark plugs
- all coils
- ignitor
- fuel filter
- tried fiddling with wires to see if its an electrical problem - no luck
- had injectors cleaned about a year and a half ago
also tried cleaning IAC, fiddling with throttle switch, and cleaning the intake manifold with some carby cleaner all with no luck
if you find what it is, then i will have sex with a monkey
Waz.
https://www.sau.com.au/forums/topic/73847-shudder-at-idle/#findComment-1653257
tried to change:
- spark plugs
- all coils
Waz.
hmm. bugger. so changing the coil didn't fix the problem. I was seriously thinking of picking up a 6 pack splitfire coil n replace them all and hoping for problem solved. But I guess I will have to look else where.
Anyone else got the same problem and had it sort it out?
https://www.sau.com.au/forums/topic/73847-shudder-at-idle/#findComment-1662449
Mine has started doing it in the last week or two... Just a quick shudder and a gurgle from the stock exhaust system. Only when warm.
Interesting! I thought I was due for new spark plugs, cause it sounds like an occasional miss.
Do 34's have the ignitor in the ECU or engine bay?
https://www.sau.com.au/forums/topic/73847-shudder-at-idle/#findComment-1666968
Hmm.. and it is the same on my series 2 R33.. Wondering if it is getting too hot where it is and not igniting properly sometimes? Anyone with a series 1 R33 experiencing the idle shudder?
Also, Ed... does that free ipod thing actually work? I've seen the same scheme for car head units. =-]
https://www.sau.com.au/forums/topic/73847-shudder-at-idle/#findComment-1669617
I have an R33 S1 and it's also affecting me. It only used to happen a poofteenth before I got my atmo BOV and now it does it pretty hardcore. Unless I leave it for 4 hours between drives. If I warm up the car for 5 mins in the morning I'm fine. It's when I stop and start the car (like doing grocery shopping or something) that it happens most
has anyone used the the eletronic idle stabiliser?
Clicky
Does it work?
Someone mentioned that another result of shutter is also loss fuel economy... Will this also fix that ? I
https://www.sau.com.au/forums/topic/73847-shudder-at-idle/#findComment-1670156
I was going to have a guess and say; since my O2 sensor doesn't appear to be working properly, and the ECU is running richer at idle/low revs, that possibly it is backfiring on too much fuel?
I hope this is not just an uneducated guess, and i'll soon see when my NGK O2 sensor arrives.
Incidentally, i'm also running an aftermarket BOV. How's your fuel economy, Kennedy?
https://www.sau.com.au/forums/topic/73847-shudder-at-idle/#findComment-1670302
Well my fuel gauge doesn't work so I can't be sure. (Gotta fix that). I fill up every 200KM anyway coz I believe cars in general run more efficiently on a full tank. By my rough calculations...since the BOV intall by I can only get about 400KM rather than 450KM to a tank. It is a 65L tank isn't it?
https://www.sau.com.au/forums/topic/73847-shudder-at-idle/#findComment-1670436
    • Mate you saved be from dying in the Perth summer. AC wasn't changing direction and just going into diagnostics mode fixed it. You're a legend and I would shout you a beer if I could!
    • Unfortunately effort gone to waste, you will have substantial issues with how the manifold and wastegate have been integrated. You would be so much better off with a modified stock manifold like this: https://hypergearturbos.com/product/rb25detexgatedmanifold/   OR literally just getting a off the shelf Sinco or 6Boost manifold as myself and others have mentioned.
    • Yuck. But it's kinda the same principle, moving timing around to make car run bad but sound good.... I went for a more spirited tuning drive to iron out a few things. Car no longer stalls, and it loved to dip RPM low when you clutch in. After tuning this (and the 4-5 tables that HPTuners/LS1 OEM ECU wants for idle air correction) it's now behaving somewhat normal. All expected because there's a new TB, new Intake manifold and that new TB which is 102mm vs 78... has an entirely different IAC passage which is smaller because ????? Unfortunately at this point I went to make further fine tuning changes to avoid it flaring up, you know... _tuning_ the HPTuners dongle died. Well to be more accurate - The USB cable died in a fashion that anyone who has ever charged a phone will recognize. After the app demanding I resync it 50 or so times (which all 'succeeded' but all failed) the device does not want to sync and I've logged a ticket with support to see if it's fixable. US Support said it was a 'storage issue' but after removing the SD card inside it and formatting it/fixing it the issue does persist. Unfortunately usually the fix is "Turn in your old dongle and pay $700 for the upgraded one" it's cheaper because I get some free licence credits I unfortunately don't need. However I'm 10 minutes down the road from HP Tuners AUS/VCM so at least I won't need to post it, and logged a new ticket for support over here. Definitely drives different. My SOTP dyno believes it's probably making 310-320kw instead of the 280 before.  It scrambles for traction a little now whereas it previously different. It drives like a bigger cam car up top even though the cam is smaller, likely due to the cam not being advanced 6 degrees. The timing is deliberately low and the fuel is very rich so who knows if this will improve on the dyno. It may, imperceptably. Also funny is removing the pineapples definitely makes the car squat more and axle tramp less. So this behavior of having more top end, squatting more, and scrabbling for traction more makes me think = more power. But I could have just been sitting on the threshold of that kind of behavior before. Time will tell if my butt dyno is calibrated right. I need the exhaust leaks fixed before dyno tune for obvious AFR related reasons - I repositioned the pipes but I'm not confident it's fully sealed even if it is better. At least the car does drive around while I cannot tweak/tune it for now. And I have aircon again. medium success!
    • Don't use that manifold. Please don't use that manifold. Sunk cost fallacy is not worth the later pain. None of these will be relevant to the change that will come from the different turbo and manifold. As in, the effect of the exhaust will be nil, regardless of what else is changed. And all the cam and fuel system stuff is not changing either way, so has no effect. The turbo and manifold (and to a small extent the wastegate)....big change.
