Found bendix fade a bit too much, yes the ultimates or premiums or whatever they call em now.
Really liked "Green Stuff" by EBC and hear that u cant go past race brakes RB26's which are well priced too. I think both of those pads are semi organic.
My personal favourite is Endless SS-S, low dust, great initial bite, progressive and rated to 500deg C, so not likely to fade on the street. Oh, and they wont chew the ass out of your rotors either. I have also found project Mu are pretty good, not quite the same intial bite as endless, but otherwise on a par. I have also tried bendix and greenstuff, didnt think alot of them (personally), better than stock though, but dusty and seemed to wear rotors like there is no tomorrow.
your brakes will perform ALOT better with good pads than if you upgrade and use normal pads, (I went from stock SR20 brakes with project Mu pads to stock R32 brakes, and the SR20/project Mu combo pissed on the stock R32 setup) Once I fitted endless pads it was a different story though. Good brake pads are an excellent upgrade.
I would recommend getting the best you can afford, what price your life? cheap insurance and alot more fun driving the car.
I don't think it's your Ultimates that fade. I've never experienced fade in my Skyline and that's all I've used so far. I've been to about 10 track days and as everyone around my area and on this site can attest, I drive my car hard.
there are more factors to whether or not a brake pad will fade than just the pads, tyres, driving style, how tight the track is etc.
Your pads are obviously ok for how you use them, but not in Boostzor's case. I have know other people that have had fade on ultimates (so they told me), even though I didnt get it.
Alot of variables.
Yeh if the rotors are bigder they are going to dissapate more heat, so if they are thin they fade faster. When i had them they were on a jza70 and the rotors were about half way done. After 3 hard brakes u could feel it fading.
As steve said though, EBC ab RB chew rotors good. Too bad the endless are so expensive.
I would recomend do it youself or get one of your friends to do it Erik.
Just got back from the place in Bayswater (no name)......whata bunch of cowboys.....
They frucked one of my wheel nuts and their reasoning was " who did your wheels before" and that is after they takend them off , put them back on, and took the car to do the alignment....
.....and then they had decency to tell me its ware and tare..........dick****fiths.........:cheers:
All that: for them to tellme there is nothing wrong with my car.......
Well I get to the breakes now. I ask them why is one of my brake pads bent inside after I replaced them ....... and the guy tells me we are specialists but I don't know!!!
Whata???
So after spending so much money on different barke specialists that know fruck all...
Wheel alignment specialists......same......fruck all.....
So much for pro help.....
I have decided from now on, even with not much time these days I am doing it myself.....
Read the forums guys, ask for the manual if you need one, I have one, so does Paul and few more other people. DIY!!!
Boostzor, endless may be a bit pricey, but stack up well against others when you consider the money you save in not having to replace your rotors so often - more rotor = better brakes :rofl:
Abo Bob, bigger rotors can make a difference, both in thickness and diameter, as can the design. Take for example the 'roo paw' (or whatever its bloody called) design of DBA rotors - they spent alot of time and effort trying to improve the cooling efficiency of the rotor. Then you have the material that the rotor is made of which also makes a difference.
If you have aftermarket/upgraded rotors, there could definately be a difference.
    • Yep, that was one of the things we learned fast in the past with our MX5. When you drive with the top down, you are effectively standing out in the sun, 100% of the time, and not getting in any shade (because roads aren't shaded generally!). Just like standing out in the middle of a field on a sunny 27C day is a bit of a bad plan, so is sitting in a MX5 without sun protection.
    • I also just ordered some Frankenstein bolts and side mounts to fit a hard top Just in case I do find one, basically so it doesn't need to be fixed to the car with only the front latch.......and then gaffa tape to keep it in place for the RTN journey from wherever I get it
    • If your temps are fine now, you probably won't have any issues with where your vents are as they don't look right up at the windscreens high pressure area, so any differences when giving it the beans for extended happy laps would be minimal, but, they should vent heaps when stuck in traffic  Much like how that reverse cowl on my SS let "visible" heat out when stationary, but, because it was basically at the windscreen my coolant temps on the Hwy actually raised because air was being fed into it at speed (110kph), to only come back down to around 90° when I got off the Hwy And your 100% correct about the NC currently not needing vents, but, if I was to add a turbo, and a oil cooler and intercooler in front of the condenserand radiator, and then take it to the track???? It is apparently a recommend requirement if I don't want to worry about coolant or oil temp issues, but, any of the above are possible scenarios, over time As it sits now, with the triple pass radiator and stock air conditioning system, I have absolutely no issues with either temps or air conditioning efficiency, I've been basically daily driving thie car for the last month, both on the Hwy, and peak hour, bumper to bumper traffic, but, that's pretty much expected from basically a standard engine  Talking about no issues daily driving, it was 39° the other day and I was sitting in bumper to bumper traffic on the M5 and then M7, with the top down, and with the air conditioning blowing nice cold air on my feet, balls, and face, well, there was one issue, my head and arms got pretty sun burnt Note to self: leave a hat and sunscreen in the car for such days 🤣
    • I would agree, unless you need something specific to the HV motor/battery side repaired or investigated, any mechanic will be able to perform normal services, but if you prefer, maybe look for a mechanic who regularly services/repairs Nissans, the VQ engines are pretty common in the Nissan lineup.  Sorry, I can't make any suggestions, I don't live in Vic.
    • Some of them keep working fine. 9 out of 10 of them end up causing an absolute misery bleeding the system and get thrown on the workshop floor in a tantrum and never thought about again because they were never really needed and just added crap to the car that we could have done without. Same-same with HICAS, A-LSD, and various other stupidities that over eager 10x engineers thought we had to have.
