right so being a student im limited to $$ , and need to get this skyline up to D1 spec.
basically ive got a budget of a grand to do this (as far as engine mods go)
ive thought up this plan; but bare in mind ive never worked on rb's before, just turboing b16a's/b18cs 4agtes etc.
VG30 turbo or rx7 in gtst exhaust housing(which i already have) or RB25turbo:
does anyone have the a/r's for the VG30's off the SOHC 3L engines?
3" exhaust bla bla
stock ecu with a safc:
now does anyone here actually have their safc tunned to run higher boost. and if so, what settings is it at, as they **** around with the timing abit.
we used to chuck 450cc's in the hondas and wind it back to around -40% but itd advance the timing mega so had to retard at dizzy = rough...
chuck a evo cooler on it or something with 2.5" pipes or 3"(to big?)
lastly, what would be a good suspension setup for CHEAP that would be sufficient for track work.. i know coilovers are best and i will probly have to save for that anyway, but is there anyother way around that option (other than choppies)
ill be doing all the work myself so no labour worries, and car parts over here (NZ) are quite abit cheaper than over there :boobies2:
any other suggestions?
cheers guys
https://www.sau.com.au/forums/topic/73860-budget-rb20det-upgrades/
Fuel pump would be pretty important, particularly with the bigger injectors.
With the turbos you have listed i'd say you'll be aiming for a bit under 200rwkw which the stock injectors could stretch to with a rising rate reg. You could then use the safc to tune the on boost area only and not have to worry about the bottom end.
R32's generally maintain decent A/F ratios with the stock ecu at higher boost, they are nowhere near as bad as 33's.
2.5 inch piping would be fine, the stock piping is only slightly smaller than 2.5 anyway.
I'd be leaning toward the rb25 turbo but as it has ceramic exhaust wheels it may not last too long in a drifter.
The biggest improvements i found with my 20 were a s2 rb25 turbo and getting a re-mapped ecu which was done by dr drift i think. The ecu netted the biggest overall gain tho, mid-range and throttle response were greatly increased, as were fuel economy and top end power, but wouldnt've been such a good upgrade with out the 25 turbo.
I think value for money you'd be better off buying a re-mapped ecu in trade for your stock one rather than the safc...
What about a gtr cooler?
Im sure if you did a search you could find the VG30 A/R's
A $1,000 budget, hmmmmm....this is what I would do
1. Jaycar IEBC, DFA and Hand Controller $200
2. Used Jap 3" exhaust, $300
3. R34GTT Intercooler $150
4. R33GTST turbo $350
There is your $1,000 spent, you have to tunre it of course, but 160 rwkw should be achieveable.
As for suspension, I would get a pair of Whiteline adjustable stabiliser bars, 27mm for the front and 24 mm for the rear. For drifting, set the front on soft and the rear of hard and get into it. Add a set of caster bushes and you have change from $600. Best bang for buck suspension mod ever.
Hope that was of some hlep:cheers:
get an RB25 turbo instead of the VG30, on a RB20 the VG30 will be an absolute dog off boost.
You can get the ECU remapped by Dr Drift, from memory the boost is up to 1 bar.
Use a GTR cooler rather than an EVO cooler, not sure why you would want to use an EVO one on a Skyline...
You'll be very VERY lucky to do all this with only $1K. You'll need to change your fuel pump too if you want your engine to last.
If it were me I'd focus on handles rather than power. RB20's suck for power, ain't that right Roy? ;)
cheers guys.. yeh ive actually gotta EP-ROM burner here at the moment, but doubt Dr Drift would just chuck me the map for me to burn meself.. side note; what octane gas you guys use ? no doubt tho that chipping the ecu's is the best way to go as i upgraded to that on the hondas after the safc's and the difference was amazing for a 15$ chip and only on a basemap.
what did you end up paying for the chipping and was that him socketing the ECU and burning the chip, or just giving you the chip.
ill look out for a rb25 turbo then, but might chuck the rx7 turbo on to see what sorta gains that provides over the stock one just as a reference for people.
GTR coolers are quite expensive, and can score evo 4-6 cooler for 300$.
cheers for the info aye; helps alot .
Hey Sydkid,
what would be the best setup with the whiteline sway bars on an r32 for street??? both on soft???? I just bought a pair from a group buy and am about to fit them. What do u think?
Thanks
George
    • I think this is just a product of how the US market works for this stuff. Shops are expensive and there's no real way of knowing what kind of results you're going to get, people don't really have the institutional knowledge. I have heard too much at this point to really put faith in anybody "full service" except maybe DSport and they aren't really a full service kind of shop. If you go to the right place I have no doubt they'll get it right for you. Some locals have set it up right but the cost really is nuts and even now they're still fighting issues. And you know I'm a crazy person who thinks things like twin scroll, relatively short low-mount cast headers, PCV recirc to intake, recirculating BOV, right-sized for ~400 whp, MAF load, validating all of that to a standard comparable to OEM test programs, etc are relevant. For what it's worth, multiple local owners at this point have been stuck in a perpetual cycle of blowing a motor -> getting someone to rebuild it -> some missed detail causes the bearings to wipe and spin just outside of break-in mileage or drop valves or some other catastrophe -> cycle repeats. I usually only find out about this because I'm perpetually helping random friends with diagnosing car troubles, Skyline or otherwise. The single turbo stuff if I'm honest is mostly secondary, it just doesn't seem to achieve the numbers in the ~2000-3000 rpm region that I would expect given the results I've seen here or in Motive's videos. I don't really know what we're missing here in the US to be causing this. Lots of people like to emphasize the necessity of finishing the project first and foremost, but I'm not made of money and I can't afford to be trashing a 15k+ USD engine build with any regularity. Or spending my relatively limited garage time these days unable to triangulate problems because too much was changed all at once. Also, even if it isn't a catastrophic failure I would consider spending the cost of single turbo conversion with nothing to show for it to be pretty bad.
    • The water pump is know to leak as well. So if the coolant is low checking that first as well as hoses.
    • Reading your posts Josh, sometimes I feel like I've gone in a time machine back to the 90's when everyone was doe-eyed and figuring things out for the first time.  I've lost track of how many single turbo GTR's I've seen on track that haven't burnt down lol. Everything has been figured out a long time ago. These things are at the point now where its essentially turn-key to go single turbo.
    • Among other things yes. Making sure to either use an oil pressure regulator or the right restrictor size for your oil pump/range of oil viscosities you intend to run, making sure you plumb the lines correctly, turbo should be placed such that it siphons properly even when the water pump isn't turning so you don't boil coolant in the turbo after shutdown, oil return should be low resistance and also preferably picking the one that is most likely to return to the pickup as opposed to some other irrelevant part of the pan. It's far from impossible to figure this out but I have seen people really, really struggle and if that's the case it's easier to just take the path of least resistance. To me, bolt-on twin turbos are a fixed cost whereas single turbo is almost unbounded.
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
