well thats what im aiming for....sounds cool to me....is it hard to fit???
They are relatively easy to fit.
Just take you time when doing it and always reference the manual if in doubt.
Ive installed one in my car and a safc 2 in a mates r32.
A bit off soldering here and there. :rofl: And you'll be fine.
https://www.sau.com.au/forums/topic/73873-safc-s1/#findComment-1357479
If you can stretch your budget a bit you can get a Digital Fuel Adjuster and hand controller kits from Jaycar for about $120. Works in the same way as blue screen SAFCs.
Just have to build it yourself, not that hard.
https://www.sau.com.au/forums/topic/73873-safc-s1/#findComment-1358550
    • On the compressor side it looks like the best, if your head setup will support doing 100-110lb/min at 30psi-ish boost.   The G45-1350 compressor looks ideally better if you need closer to 40psi for it, given both the G40 1150 and G42 1200 look like they'll be around the 100lb/min mark at 35psi and dropping from there.   Bear in mind the turbine sides are all different between those three turbos, so that COULD be an influencing factor for how they all perform in the real world as well.   Not sure if you've made a conscious decision to only look at Garrett or not, but at least on paper the XRE7169S matches or beats those other three at everything from 30psi up and just going from wheel size alone likely to be at least as responsive as the G40 1150 and seem to behave closer to G42s in terms of turbine flow.
    • @Lithium  looking for a turbo for my Rb30. Want to make sure I understand this correctly.   If I want to stay 40psi or under my best choice of these 3 is actually the smaller G40-1150 ?
    • Massive ups for MTHire also. Could not have done the subframe bushings job without hiring the tool from them. Process was super easy and cost me around 25% of the cost of the tool. If you need a tool to do a one-time job, check them out. (Paid for the rental myself, no sponsorship here.)
    • I'd suggest calling Unigroup, they have a lot of experience with these, access to reliable fabricators etc. Of course it will cost but at least you can trust what they tell you
