  • Replies 63
PS3: Metal Gear Solid 4 'Teaser Poster'
Konami announced they have established a new development team called Kojima Productions, which is headed by Hideo Kojima. The team's first project is Metal Gear Solid 4 for PlayStation 3; Hideo Kojima will be the producer and director, Kenichiro Imaizumi will be the producer, Shuyo Murata will be the director, and Yoji Shinkawa will be the character desinger.
Here is a teaser poster of Konami's Metal Gear Solid 4 for PlayStation 3, the game will be revealed at E3 later this week.
GAMEBOY ADVANCE
- Nintendo will release a new version of GameBoy Advance later this year called GameBoy Micro, which has a dimension of 4" wide, 2" tall and 0.7" thick, small enough to fit into a pocket. The LCD screen is smaller than the GBA-SP, but quality is far better than GBA SP, GameBoy Micro also have backlit, adjustable brightness, plus a standard headphone port.
PS3: The Getaway 3
Here are some new screens of SCEE's PlayStation 3 action game The Getaway 3.
Not how good the shadowing is? This is a feature the PS3 will have over the other next generation consoles.
    • MR HAMMER has said his piece. Painted up to avoid Rusty Rusty. Actually lines up well. (i.e it lines up the same as the unmolested GTR guard). Turns out the GTR Strut brace does foul on the bonnet vents ever so slightly. May need a little bendy bendy if intended to keep using with a strut brace. So spacing it out to clear the FAST102 is not an option. Annoyingly, the bonnet vents also foul on the heater lines running over the engine. Given this engine does not EVER require a heater, a delete loop is going to be used. Don't worry, the defogger uses the AC. The heater is basically "Do not use the aircon and turn the fan on". It will still be effective, I promise.... once I get the system regassed... Will have to revisit with unvented bonnet I suppose, and suitable strut brace. There's plans to do this and other things tonight and bleed brakes (there was a weep) and put the bumper back on, and take Good Friday morning - Because troubleshooting on the side of the road limping it home at midnight tonight is ... not very smart.
    • Thank you all for you assistance. I contacted Nistune regarding the support for the RB20DE along with my ECU Code (23710-10U00). They do have a map for it and added the RB20DE as a purchasable option now as well. They also added Malta as a Billing and Delivery options as this was missing. I was honestly amazed at their quick response and action, it took less than 24 hours. I also looked again at direct fit options for injectors, just in case I were to replace them. DeatschWerks seem to use a Bosch EV14 base and makes ones that fit mine at 440cc lowest, but also have 550cc at the same price. I tried looking for other direct fit options and managed to find one (also Bosch EV14 based) which includes a plug and play adapter on ebay. Did a small test with a Noid Light on the troubled injectors and all seems good, so they are pulsing properly electrically. One weird part is that they are missing on the same two cylinders as before I got the injectors cleaned. Mechanic also found this weird as he did not label the injectors and it is unlikely to have the faulty injectors be installed in the same cylinders.
    • Nice, let me know how you find the 98 tune
    • Put a hand on an injector and see if that's what the buzzing is. You might be triggering the injectors by moving off idle command.
    • Ah, should have been clearer. Currently has a flex sensor installed all good to go.    like u mentioned, I’ve only ever known the car on e85, I might hate 98, but I have to try it out first. Everyone says the -5 turbos get pretty laggy on 98 octane tho…
