okay, first stage mods are in and i'm very happy with the way the car is driving. its responsive and it has top end.
list of mods are:
-trust dd cat back exhaust
-hks dump and front pipe
-apexi super intake
-hks front mount intercooler
-powerfc
dyno chart is as attached. a gain of around 20rwkw was had after installing the front and dump pipe and powerfc. the blue line is before the powerfc tune. this is running stock boost...
that brings me up to about 160rwkw.
IS THIS LOW? i was expecting close to 180-190rwkw with this set of mods? what power have you guys got and what mods?
cheers,
https://www.sau.com.au/forums/topic/7389-r34-power-figures-is-this-right/
how much is stock boost on an r34 with out boost you cant expect much power you a/f could be a bit leaner to get a better power figure but where they have been set is good all round.
the standard turbo only just supports 180-190 rwkw @ around 1 bar If you want power fit a bigger turbo and use more boost.
but when you do that your engine does wear faster cause it is making more power than it was designed for
meggala
stock boost is about 0.7bar. i want to run 1.1bar but the nylon wheel on the exhaust wheel will just disintegrate on 0.85bar (the HPI GTT did anyways).
looking for a 2nd hand GT2540 or GT2530...GTR fuel pump and injectors....will R34 GTR injectors slot into an RB25DET NEO?
    • This was a huge help.  We followed the steps,  although shifting into 2nd was actually into 3rd for us,  and 1st was into 2nd ( steps 9 and 11) .  The long flash was the 4th flash.  So shift solenoid A is possibly the culprit.  Is this inside the transmission itself? Or is it accessible by just front the pan? Or is it bolted to the outside of the transmission?  Thanos for your help everyone
    • Can you enlighten me on your best practice regarding these hoses? I don't wanna make the same mistake if you already got a better solution.
    • I have some silicon hoses already, for example engine to watercooler. But yeah, I get the sentiment. The lower intercooler silicon hose is drippy too, despite not being very old. Does anyone except Nismo make these same lines out of rubber? Long term I think they'd be the better replacement, especially since the car won't live as hard a life anymore as in the past nor be driven as often.
    • I know most issues are just age related. But for example the turbo oil drains, there is dash adapters for these and you can just make a braided teflon line for them and (probably) never have them leak again. Also not terribly expensive. Can you even get the factory hardlines from new? Or are they repairable if they break?
    • I know it'd be much much easier with the tool. I hope I can find one that won't take 3 weeks to get to me an isn't a "Asian models kit" that has tons of (to me) useless adapters for a load of cash.   It's a summer project/fun car. I do wanna enjoy it, without endless downtime over and over. So yeah I would even go and buy an engine crane + stand to save myself the trouble of hard to reach or unreachable places going bad later on. Would also be a good opportunity to put on a Fluidamper, renew the mains seals and stuff like that. I have some money on the side that I can use for that, what I wouldn't want to or be able to do is let everything be done by a shop or have my engine completely rebuild right now. I intend to do most of the "doable" jobs myself. Pulling an engine can't be that hard, can it?
