BRAND SPANKING NEW IN OEM PACKAGING
Tomei Cams/Spec B Valve Spring Retainers and Solid Lightweight Lifters
Cams intake 290deg exhaust 252 deg Tomei PROCAM
Spec B Valve Springs and Retainers ~ 11.5mm MAX lift
and Solid lightweight lifters....
Its sitting here doing nothing and i want to get rid of it...
im asking for the whole lot now $1600 at this price im practically giving it away...
PM if your interested, if you dont intend to buy please don't waste my time
Update
Items are now SOLD thanks for the interest
]']this include cams as well?
for what car?
32,33? or 34?
yes the cams are included... the exhaust cam is only compatible with the R34 RB26DETT but the 290deg Intake can be used on any RB26DETT you could sell the cam on its own, they retail for $600 ex gst on their own...
Heres some more information
The Exhaust CAM is designed for R34 RB26DETT however the Intake cam 290deg 11.5mm lift + valve springs and lifters will work on all RB26DETT motors. BTW These are Tomei PROCAM series not PONCAM's they require the use of upgraded springs
The R34 RB25DETT Exhaust cam is designed differently, it appears for the R34 the Exhaust cam is only avaliable in 252deg and 260deg configuration...
The retail price of each part is as follows:
Tomei Solid Valve Lifters $607.20 ex GST
Tomei B Spec Springs and Retainers $902.70 ex GST
Tomei 290deg 11.5mm lift Intake PROCAM $633.30 ex GST
Tomei 252deg 9.15mm lift R34 Exhaust PROCAM $640.30 ex GST
Total Price of $2783.50 ex GST
$3061 inc GST
(Price from HiOctane Racing)
I dont think anyone would sell what i have for the price i have now, so ppl that who are offering ridiculous prices for an already cheap package :bs!:
Look. Im not here to try and force you to sell the above mentioned items serperately. However, if you dont find someone to buy the whole set... PM me and i will purchase everything less the cams. I offered you a price and by the looks of it it was way out. So give me a ball park figure to work from and we will take it from there. (Thats if you change your mind about seperating ofcourse)
    • Should add all mods on the car are done in my ownership. The car was a 1 owner in Japan and I'm first owner in Aus.
    • Thanks GTSBoy. Did BC's so not Japanese coilovers. I've already done all the other points you mentioned besides the seat, I like the factory seats and want to keep original look. Done all the fluids and comp tests etc and all consistent and clean. Well and truly used to the power and car as I've been driving it for a few years as it is now. Contemplating next steps mainly. Preference to remain twins too. @Murray_Calavera Paying for labour.
    • Hmm. I don't think it is possible. As soon as you start, you will be on the hook for all the money. $5-10k is enough to make it fragile. Here's the list of things you need to do to make it nice, and driveable. If Japanese coilovers, get them measured and tested, then decide if you're keeping them or replacing them. If low rate springs, then consider big ARBs. If high rate springs, then probably leave stock ARBs. Either way, ad decent end links. Replace and/or upgrade all suspension bushes. That's LCAs front and rear, UCAs & traction arms at rear, caster rods at front. I highly recommend GKTech FUCAs, although the step to spherical joints is a step too far for some people. Rebuild brakes front and rear. This means making sure the calipers are healthy, discs are up to thickness, hoses are replaced with braided. Add good pads and fluid. Investigate wheel bearings all the way around, tie rod ends all the way around, upright bearings at the front, balljoints everywhere. Any of these that are still original are likely to be a bit wibbly nowadays. Bride or Recaro driver's seat, with fairly deep sides. Nice tyres. Street performance wheel alignment. Or track focused, if you're not going to use it on the road. Fluids everywhere if not known to be fresh. Now, learn to drive the car as hard as it will go, before trying to add any power. Save up big $$. $5k is the minimum cost for putting a decent ECU into it. A big single, with manifold, new exhaust, injectors, fuel system upgrade, ignition upgrade, triggering upgrade, etc, is >>$10k. None of that (except the ECU) is a good idea on an old RB. You really should put head studs in it, investigate engine health (compression and leak down, real oil pressure at revs, coolant condition, etc) before even considering adding power. There's nothing sadder than the "I added boost then it shat the bed" thread.
    • Are you doing the work yourself or are you paying for labour?
