I have used the Autospeed design boost controller (using Norgren valves) on quite a few cars and I have never EVER had a boost spike problem. We run either Datalogit or Motec dash logging on the race cars, so I would have logged it if it had occured. I do mount the 2 valves inside the heat shielding as they like to have a stable temperature. One valve gives good boost control and the other some adjustment of the boost climb rates by limiting the lowest level of boost pressure the wastegate actuator sees. Up to a pre set point (boost pressure), this controls the premature opening of the wastegate.
I have found the Jaycar IEBC to be superior in achieving stable boost, but most of all it enables a totally adjustable rate of boost climb. This is only made possible because the IEBC has the boost solenoid in series with the wastegate actuator. All other EBC's have the solenoid plumbed in parrallel with the wastegate actuator. This means the wastegate actuator always sees some boost pressure and so the solenoid is not in 100% control of the rate of boost climb ie; you get some premature opening of the wastegate.
If you can read instructions and solder components onto a circuit board then the IEBC is the best $80 you will ever spend. There is more info on my experiences (and a few other peoples) with the IEBC and DFA in the Stagea forum.
:cheers:
I've just picked my self up a cheapo ball and spring type bleeder. Its not actually a bleeder, the knob adjusts the tension held on the ball.
Should work well as I've had a similiar type before which worked really nice.
http://cgi.ebay.com.au/ws/eBayISAPI.dll?Vi...ssPageName=WDVW
hey Cubes, thats the one i am using and i hove found it very good, did you buy it after reading my thread on it here?
how is it going have you used it yet?
hmmm its interesting.. ive got one of those gfb bleed valves ive only had it working for a few days... I set it to 10psi but it was spiking to 12 or so.
I had my car serviced yesterday and they set it to 11psi for me, hasnt spiked once (done 300km so far and im realy trying now to make it spike..)
Its amazing what the professionals can do :D
    • Just don't use ChatGPT or any other artificial stupidity for the equivalent of googling. Their demonstrated inability to discriminate reality from hallucination should be enough to make them totally untrusted. LLMs don't know anything and cannot think to even the smallest extent. They are just predictors of the next word, and that should never be confused with capability.
    • I think, given the usage model described in the OP, I'd never ever experience the wonders of the 400kW upgrade. What I really need is boost from 2000rpm and probably no more than 260-270rwkW. But I suspect that the highflow is not actually the turbo for that purpose, so I may in fact need to get a G25 or 30 or something right sized and very spooly. We shall see after it is tuned. I've had to back the boost and boost ramp off to stop the thing from pinging since the highflow went on, so I've been almost living the NA life for 9 months now! Injectors are recently in hand. AFM is in hand. Dyno is fixed. Just need to clear a queue of f**king Supras out of the way (and probably fit my new gearbox). So....some time this year? Lol.
    • For what I gather is a Sunday/summer car....braided is fine. You're not going to be left without a vehicle and you have plenty of time for inspection/maintenance. Oof. I wouldn't use them that way. They can probably handle the temperature** but the internal corrugations means that their flow characteristics are a bit shit. Lots of extra friction and pressure loss. Makes them flow like the next pipe size down. ** They are stainless, and the stainless can usually be at least something like 304L, which is pretty good at higher temperatures (unlike 316L, which I would use for a wrt/corrosive environment, but not a particularly hot environment). But the welding needs to be top notch. And even then, because you usually need at least one cone-seat end on them (because you can twist the hose and do up both ends at the same time unless one of them is a union) they can be prone to coming loose with heat cycles.
    • I don't have the OEM oil feed lines though and the turbo-wraparound line is torn, only has water. My plan is to get replacements for these and just connect a braided line to there. And make sure it's leak free. Hoses like these are also sometimes used to connect external wastegates, so for an EGR I think you're good using them.
    • Alright I understand. The most likely case is probably gonna be that I just keep the OEM unit in the car as long as it works.
