hey
im realli new to this site so it might have been talked about before but i was wondering if anybody might be able to help me out in the area of pricing... from experience or quotes or whatever! ive got a 95 r33 gts-t.... its my first car and i love it!!! (finally after driving mums 96 civic for 6mths!) i wanted to do some cheap mods to it to get it running into the 13s... similar to the other thread about getting a stock R33 into the 13s.... how much would it cost to get a 3inch cat-back exhaust?? and how much for a dump pipe?? is it really necessary to get one? this is the first turbo car ive had so i dont really know all that much but im enjoying learning from other posts... any help on other cheap mods would be greatly appreciated!!!!
thanks alot
fat
https://www.sau.com.au/forums/topic/73920-gts-t-mods/
front pipe / dump pipe / hiflow cat / 3" turbo back probably $1400 ish?
the dump pipe and hiflow will give a good power upgrade as the stock system is pretty restrictive. other cheap mods,
apexi safc $400 untuned
cold air intake kit $200
some wider tyres 245's 255's. $400 each
pineapple kit $150
pod filter with cold air intake $80 pod only
boost controller (bleed or electronic). - bleed $50 - elec $250
https://www.sau.com.au/forums/topic/73920-gts-t-mods/#findComment-1357864
hey guys
thanks alot for the help, it should come in handy when i have the resources! as for the handling part of it.... what would you recommend i do there?? i have no ideas at all!!!
and yeah its true that things can get ugly quickly... i want it to be quick but know that it is.... not show it off to everyone if you know what i mean.... i want to be able to take it out to the strip every now and then..... so yeah! but it is an awesome car and im loving it!!!
https://www.sau.com.au/forums/topic/73920-gts-t-mods/#findComment-1360278
see any good local suspension shop, pedders, whiteline, i know bowers down here in newy all do good work
suss out some local guys, also if u intend to mod up nicely in the future find a good local workshop and STICK WITH THEM, theres nothing more valuable then having a good workshop which will help u out when u r in need.
https://www.sau.com.au/forums/topic/73920-gts-t-mods/#findComment-1360797
yeah sounds good to me
does anyone happen to know of any good workshops in the hornsby area?? once again ive got no clue!! haha im kinda getting used to that fact!! and what would i be getting done to improve the handling? i dont wanna rock up to a suspension shop and get ripped off or sound like a tool...
https://www.sau.com.au/forums/topic/73920-gts-t-mods/#findComment-1361939
    • In a few years from now, you'll regret that. It'll eat away at you, knowing the truth of the ugly hiding beneath the beautiful exterior... 😛
    • I don't think the G2 profile is particularly dangerous for the engine per se, more just are you actually ok with the turbo lag trade-offs? If the answer is yes then go for it. I personally don't think I'd be ok with it because I spend so much time at lower RPMs and I really enjoy the feeling of being able to stay in 5th gear on the highway and just roll into the throttle to get boost. Or staying in 3rd gear on "gentle canyon cruises" without feeling the turbo lag too badly. The 525 pump should be able to run flat out on factory lines but I would bet the pressure drop from pump to regulator is quite impressive. I don't know how much it would be exactly but I've seen figures like 30 psi thrown around.
    • It's interesting seeing everyone talk about what level of risk they are happy to tolerate.  Building a GTR always has a level of risk, you could be that lucky guy that drops 20k on the engine build alone and still has the thing go pop on the dyno. Life is fun like that.  The way I see it, the thing is a toy to be enjoyed. I'd be happy to turn up the power on stock motor and limit the risk with sensible tuning and engine protection. If it still goes pop, it is what it is. The car isn't a daily driver so it can happily sit while a plan is made to sort it out.  Given this thing will be a street car only, I really feel it's worth the (relatively small if managed well) risk to turn the power up to around 350KW on e85.  I don't think anyone getting into the skyline game now is doing it out of logic. Surely it is a purely emotional decision so I'm not sure how important it is to think about the engine build logically. The heart wants what it wants.  @joshuaho96 little note for Josh, I run my 525 pump flat out all the time and through the factory lines without any issues. (excluding the melting connectors, that's sorted now. we'll pretend it never happened lol)
    • But the Nexus S3 is very expensive and won't be as purpose-built for the application as a separate electronic boost controller :^) More seriously my pet issue here would be that the Walbro 525 running at 100% duty cycle is going to require more FPR than the stock setup can handle. I'm also pretty sure from what I've seen elsewhere you might want to slow down the pump regardless unless you're going to come up with some way of upsizing the fuel lines coming from the fuel tank. Factory 8mm fuel line doesn't actually flow very much if you want to keep pressure drop down between the fuel pump outlet and FPR. If you really want to "keep it simple" I would run only as much pump as you need and source a fuel pump controller to slow down the pump in the vain hope of being able to run stock-style FPRs which are pretty dinky. Or just use the HICAS lines and it should be mostly fine. OP should also really think hard about what profile they'd want out of the turbo. My pet choice here would be the G1 profile rather than anything higher power but YMMV. I already think ~stock turbo lag is pretty bad so I don't want to make it worse. In "gentle canyon cruising" I found that I spent a lot of time around 4-4.5k RPM. I also recommend DIYing labor if you're detail-oriented enough. Costs are high for labor + if you do it yourself you can be your own quality control.
    • GTSBoy is again on the money. My actual advice? Sell the car. (really). For what it's worth as is, you can sidegrade into something much better. If you care about function then this is the actual move. If you want a Skyline to perform, set aside about $100K to do it. This is NOT a typo. You will see right away these are two very different mindsets. Realistically we're talking full restomod for any Skyline still kicking around. Have an honest think about which one you are.. and what you want to do, and how much you want to invest in this (with no return).
