Hey guys,
sorry for another post but couldn't figure out how to change the title properly:
Anyway!
R32 GTR spoiler, fibreglass, white, good cond. needs a bit of polish (wharf dross) $125
R32 GTST bonnet, Silver, couple of chips good cond, $100ono
R32 GTR Headlights, yes with grill attachments, good condition however the little park light lens is a little loose on one so if your pedantic you may wish to open them and glue it down. Has no affect on light and I can hardly notice it..... $200ono
Blitz Super SOund BOV with adapter for RB20DET pipe Used but in very good nick. - $150firm
Pics for some parts are below, others are as described.
https://www.sau.com.au/forums/topic/73931-r32-parts-bonnet-lightsspoiler-bov/
The drivers side one, you can hardly tell from the photo. its the little lens covering the park light. It has just come unstuck, not broken or anything.
Not sure what globes off hand they take but they have all globes still in them as I changed to completely different lights and needed new globes anyway.
    • The 1000ccs are side feeds but they're not currently installed, had my old factory ones in for leak testing purposes, only decided on them because front facing plenums and good top feed rail kits are out of my budget at the moment, are they really that problematic? Had a set of yellow jackets that lasted me 5 years, no real issues, only replaced them chasing this misfire issue that ended up not being ignition related 😄
    • Are those 1000cc side feeds? If so, that's part of your problem. I have 1480cc and they idle at stoich on 98RON, and all the way to E85. Also your coil packs.....
    • Update for the sake of closure   Ended up getting the intercooler piping all sorted, new plugs and yellow jacket coils, and she was idling mint until it warmed up while I was bleeding the cooling system. Found the misfire to be localised to cyl 3 by unplugging coilpacks, ran a compression test, that checked out, then decided to get a mate to check if that spark plug was firing out of the motor. Upon cranking it over, with the injectors disconnected, the car actually fired and ran on a couple cylinders and heaps of fuel came out the top of cyl 3 I'd say that injector's either spraying incorrectly or spraying far too much, which is fine as I'm planning on replacing them anyway I'm planning on making about 250kW on flex fuel, and have a set of 1000cc injectors from ozautosport, obviously overkill but I'm planning on building the motor and running more boost further down the line, do you reckon they'd be too big for a smooth idle on 98? Thanks for the replies gents, much appreciated
    • I'm confused. You said you want to "remove the clear coat from most panels" but it sounds like you are actually doing a full respray? Few random things to add -  If you chase the blistered paint with 120 grit, I can almost guarantee you'll chase it down to bare metal (that's fine). But if you paint the car from here, you'll have nice little indents where ever the blistered paint was. The new paint won't magically level out the low areas, you need to fill them. Which leads me to the main point I wanted to add, make sure the whole car is flat before you paint it. All those areas with blistered paint you sanded out, make sure to fill them and triple check they are flat with a block guide coat. I'd also check the whole car is flat with a large block and guide coat but yeah up to you if you want to go that far.
