what does it take to flush a radiator properly
do they need it out of the car
can it be done at home, but not the type where the fluid just gets dumped like they presurise it or something i dont know
and wheres the best place to do it, i live in vermont melb
natrad do it but just wondering if its better and cheaper anywhere else
https://www.sau.com.au/forums/topic/73978-radiator-flush/
To answer your questions:
* It involves sticking the radiator in a water tank and having an air hose stuck in the bottom outlet. Air is then pumped through (in the reverse direction) at high pressure.
* Yup, unless you would prefer to submerge the car :stupid:
* Removing the radiator is very easy: probably a 5 minute job for someone who has done it before. Putting it back and replenishing the coolant is far more time consuming (but very easy to do) because you have to cycle the car, then wait for it to cool.
* No idea on the "best" place: its bread and butter type stuff for radiator shops, so just ring around for a good price.
My write up is here:
http://www.skylinesaustralia.com/forums/sh...ead.php?t=67730
Lucien.
https://www.sau.com.au/forums/topic/73978-radiator-flush/#findComment-1362785
Lucien
An extremely good write up!
Not a criticism, but a question of effort vs benefit: given that you didn't "power flush" the block (i.e just drain it), why go through all the hassle of removing the engine drain plug? Since distilled water is very cheap (or often free if you know someone in an industry that uses copious quantities of it such as a laboratory or manufacturing plant etc), I would think that multiple flushing with distilled water and draining (from the already flushed radiator) would essentially do the same thing. This is particularly so if you know what the engine block cooling water capacity is and just deduct this proportion from the dilution water that you would otherwise finally add to the system.
As I said - not meant to knock a very informative and useful DYI thread, but just an idea to save a lot of extra hassles.
Cheers
Gav
https://www.sau.com.au/forums/topic/73978-radiator-flush/#findComment-1362942
Gav,
I was not aware that there was a block "power flush": how exactly does that work? Most times I have seen power flushed referred to in regards to radiators and the cooling system it has meant the end caps being taken off the radiator, and some sort of cleaning device inserted into the radiator.
As for why I drained from the block plug rather than cycling water: well, I had never tried to drop the coolant from the block before so I didn't know how hard it would be :P Having done it once, I think I could probably do it much faster a second time.
Lucien.
https://www.sau.com.au/forums/topic/73978-radiator-flush/#findComment-1363430
    • I'm firmly on the "zero compliance is good compliance" for FUCAs. I'd be looking to solid metal joints even if the primary reason for having them is because they facilitate the twist in the arm. I have never been more happy with the way the front suspension behaves than I have since I got rid of the FUCA bushes. Even the thin little (short lived) poly bushes in the Whiteline adjustables have too much compliance for my liking. It probably won't be long before I have sphericals nearly everywhere, probably including both top and bottom arms in the rear, and I'll start complaining about the increased costs for dental work. But I will be enjoying the driving more, I'm sure.
    • Plus, you'll get great experience in bedding in pads!
    • I have offset Nismo brackets so the fact the gktechs can pivot is less important to me. I have 170mm JIC arms with bushings - but they provide no adjustment and I'm not sure whiteline eccentric bushings will fit them (I don't want to ruin the bushings currently in them to find out). Ideally I want something with bushings + adjustment; hence why I'd like to find a pair of these. Unfortunately they aren't easy to find.
    • @Vee37 How much do you really care about finding these pads again? If your pads are quiet, work well and produce minimal dust, really isn't that enough? If you are set on finding the exact pads again, I suppose I'd do something like this -  Visit your local Jax, find out what brand of pads they carry. If the Jax workshop you previously went to had the pads on the shelf, then you can almost guarantee it will be of said brand.   I'm guessing you don't have the receipt for the previous work and pads. Can you visit a Jax workshop and see if they can look up your previous job to see what pads were fitted?  Still no luck? Put your stalker hat on, find the staff that used to work at the Jax store and ask them. Talk to local workshops, try to find out where the mechanics went to. Talk to Jax workshops, maybe they relocated to another workshop. When it comes to mechanics, its a small world. You'd be surprised how easy it is to track someone down. If these ideas don't work, shit will start getting crazy very quickly.... You could find out every brand and model of pad that fits that car... and try them individually ticking each off the list if it wasn't the one you were looking for.... If you go down this path your going to want to learn how to swap pads yourself, it is very easy, takes minimal tools and space. If you have room to park the car you have room to swap the pads. Plus you have the advantage of making sure all the brake hardware goes back in so they won't squeal!
    • You miss spelled bearings...
