Originally posted by meggala
and you need to change 2 diffs not one.
look for mods else where
Do you know what happen if I convert to manual n did not change my auto diff to a proper manual diff?
Is there any difference between R33 diff from cars with ABS and cars without ABS?
https://www.sau.com.au/forums/topic/7400-better-ratio-diff/#findComment-108777
Thx for the info Meggala... I can then keep my diff, no point spending $$ on a manual diff then. That would not throw my
speedo accuracy away, isn't it??? Cause speed sensor is
not taken from the rear wheels?
MrMayhem, if the ABS sensor IS on the nose of the diff, then I might as well keep my diff as sourcing a 2nd hand manual diff I might end up getting a non ABS one. But I think ABS sensor should be on the 4 wheels, coz on the diff doesn't make sense to me, as a good ABS system should be able to apply different brake pressure to different wheels depending which one is locking.
https://www.sau.com.au/forums/topic/7400-better-ratio-diff/#findComment-108883
Basically, if we do the maths....
4.3/4.1=1.049 (4.9% increase)
So if a manual skylines doing +/- 2500rpm at 100km/h,
then with a 4.3 diff it should be doing 2622rpm at
the same speed...
Also means top speed will be reduced by 5%...
But at 250 or 270km/h @ 7000rpm, anyone would be mad to
try that
https://www.sau.com.au/forums/topic/7400-better-ratio-diff/#findComment-108964
    • I agree on doing some better than factory pistons, rods, and oil pump. For anyone using the vehicle on the road, I don't get why everyone wants big cams. The stock cam profile, with some more lift would be mint for road usage. Everyone going big cams and then wondering why it isn't as responsive in traffic, when they've shifted the torque curve upwards an additional 1000RPM. Make torque, at lower RPM. Sure it's not as cool as claiming "500KW" and revving it to 8,0000RPM, but that same torque 2,000RPM earlier... Then you don't need the extremely high end pistons and rods, and blah blah blah.
    • Personal experience. Those f**kers burn. And are actually a PITA to put out. Next time I walk down the back, I'll snap a photo of what the inside of the bonnet looks like when that thing ignites. PS, powder fire extinguishers are useless on that stuff too as it's fibrous and when it ignites, it starts to pull apart. And you end up just blowing powder through a sieve effectively.   Like the big thing is, if it's fire resistant, it's job is to stop what burning? The METAL above it? It's just to try keep heat off the bonnet paint work.
    • Oh man, sorry, $60.00000000... 😛
    • That's more or less what he meant. What it really means is that you do not have to go full crazy on the build. Don't need the best oil pump, expensive rods & pistons, big cams, etc. You can upgrade whatever you want instead of using stock level items, but you don't have to. Having said that - any time an RB is opened up, if anything is getting replaced, I think the opportunity should be taken to do all the sensible upgrades. Pistons, rods, pump, etc.
    • February update 🙂 We managed to get the very last 1/18th "Extra Scale" cars stock available from bookstores in Kyoto. These are actually the last ones and will not be restocked again! Hachette Collections Japan have not decided on a release date for these or other models in the series, so for the time being these are all there are available new.  These are showing up on Yahoo auctions at inflated prices already (especially the Celica and NSX) so get yours now at a very reasonable price before they disappear! Stock quantities: NA1 Honda NSX - 1 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1990-na1-honda-nsx 1973 Toyota Celica LB 2000GT - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1973-toyota-celica-lb-2000gt 1968 Mazda Cosmo Sport - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1968-mazda-cosmo-sport 1970 KPGC10 Nissan Skyline 2000GT-R - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1970-kpgc10-nissan-skyline-2000gt-r
