Hi All
Have a bit of a question... i went in to get a wheel alignment today at a reputable and highly recommended shop here in Brisbane, and before they did the wheel alignment, they gave the car a free suspension inspection etc... Now, they've came back to me with a quote for nearly $2000 in parts needed! Below is a copy of the quote that they gave me, what are your thoughts on the prices etc? (Note: The bushes that have been quoted are 'Super Pro' urethane bushings, which apparently have a stiffness rating of 80/90 compared to standard rubber which is apparently 30/40)
Bit of background information:
I'm looking at possibly doing some road-rally type events next year (Dutton Rally, Coastal Challenge, etc) and am going to be performing a brake upgrade, and want to do something with the suspension (Stiffen up the chassis further, and new spring/shock combo or coilovers, stuff like that) (I am open to suggestions, but bear in mind that i'm not made of money, so i can't afford a 1 million dollar unobtanium rollcage etc...)
Anyway, i was wondering if its beneficial to switch ALL of the bushes on the underside to polyurethane, to help with reduced movement etc, or are there some bushes that make no difference as to whether they are standard rubber or urethane?
Does anyone know any companies that make Bushing kits for R32 GTS-t's?
Front:
Front Lower Control Arm Bushes x 1 Kit - $171.03
Strut Bar Bushes x 1 Kit - $83.25
Steering Rack Mount Bush Kit x 1 Kit - $43.54
Reconditioned Power Steering Rack x 1 Ea - $514.55
B/S Genuine Tie Rod Ends x 2 Ea - $305.14
Labour x 3.5 Ea - $346.50
Front Wheel Alignment x 1 Ea - $49.50
Power Steering Fluid x 2 Ea - $22.00
Wheel Balance x 4 Ea - $30.80
Rear:
Rear Lower Control Arm Bushes x 1 Kit - $103.64
Labour x 2 Ea - $198.00
Rear Wheel Alignment x 1 Ea - $49.50
Consumables x 1 Ea - $5.50
Total - $1922.95
Now before i agree to the above, i want to research my options a bit, as to if there is a product more suited to what i'm intending to use the car for, for possibly only a little bit more or something? there's no point in buying something that is only going to be replaced down the track a little with something better!
i advise you to do a search on alot of those individual items as alot are very easy to install,
there are hundreds of dollars you can save there if you bought and installed stuff yourself
but then again if you not one for the job i guess you got to fit the bill.
talk to whiteline for bushing kits
hi, if you're unsure try getting a 2nd opinion.
renewing your suspension components, including tierods and bushes ect could easily cost in vicinity of $4k.
p.s. is your power steering rack leaking? I presume it must be for it too require a rebuild.
if you can do some of the stuff yourself or with a friend you can save yourself a fair bit. There are labour costs that are hard to avoid for bush pressings etc. that can still add upto a fair bit.
e.g. fit castor rod bushes $40, fit rear hub bushes $200-$300, fit new bushes to all 6 rear links $300, 4 wheel align $100, and it goes on...
Hi All
Front:
Rear:
Total - $1922.95
From the Whiteline catalogue;
Skyline
90-93 R32 GTS GTS-4 GTR
F Strut tower brace - alloy adj KSB505 1 1 Q
F Caster adj - Radius rod bush KCA331 1 2 +/- 0.75 deg - GTS
F Caster adj - Radius rod bush KCA332 1 2 +/- 0.75 deg - GTS-4 & GTR
F Camber adj kit - uppr c/arm KCA336 1 4 +/- 0.5 deg
R Strut tower brace - alloy adj KSB513 1 1
R Camber adj kit - uppr c/arm KCA347 1 4 +/- 0.75 deg. 2 kits allows +/- 1.5 deg
R Control arm upper bush kit W0579 1 4 H/duty poly-suit inner and outer
R Radius arm bush kit W0579 1 4 H/duty poly-suit inner and outer
R Sub-frame align & lock kit KCA349 1 6 allows diff angle change & subframe lock
www.whiteline.com.au
:D
Thanks for that guys...
as for doing it myself, i know some of the things i could do easily enough, but others i might leave to the pros to do, as i don't have the time/tools to do them really (i really only get sundays off, and am in a townhouse complex, so no driveway/garage space to do it)
Thanks for that info sydneykid, i found it about an hour before your post and was getting prices etc as i hit refresh on this thread :D
Some of those items are looking as a better alternative to the super-pro ones, however, they don't have all the bushes unfortunately... are there any other suppliers out there that do these? (Been told to steer clear of Nolathane and Noltec for some reason... any idea why this would be?)
Thanks for the help so far! Muchly appreciated
Jason
Hey jason watch these guys fark there tryen to rip you off in a BIG WAY it should be only around 60-70 dollars for a full W/alignment not $100 god damn
give you a idea on how much there trying to get out of you on the power steer rack $ I got my rack recoed (I took it out & took it to "Drive Line Services" in archerfeild & payed $300, put it this way just out of intrest I did some checking on how much it was going to cost to have my car fixed & then just for me to get parts & do it all my self ...... bottem line $1500 saved & cars all fixed
I say do what you can & let the pros do the stuff you don't think you can handle thats my 2 cents
Jason
Hi Jason, a bit of histrory. Greg Nolan and his brother Alan used to own Nolathane, they sold it some years ago. They did a lot of the leading work on polyurethane, not just in Australia but world wide. When they left a lot of the leading edge development stopped. Nolathane has many applications and it is heavily biased towards replacement parts for standard rubber bushes.
Greg and his son David now have a business called Noltec, they have taken the applications a little further. They are doing more performance oriented designs.
http://www.noltec.com.au/
I see no reason for not dealing with Noltec, other than they don't have all parts in stock all of the time. But they do make them to order, so I get them pretty fast.
I am not sure what bushes it is that Whiteline don't have. The listing I posted is for the alignment (adjustable) bushes, they do have others that are simply replacements. I suggest you give them a call.
:stupid:
Ah, thanks for clearing that up Sydneykid... i mean, i scoured whitelines online catalogue, and the bushes that you listed are the only ones i could find... i didn't realise they had other ones that weren't listed :stupid:
Thanks, i'll give them a call, along with Noltec. The place that quoted me these prices is the one that said they refused to deal with/use/install Noltec or Nolathane as it was crap and doesn't last blah blah blah... i found it a bit sus at the time, hence asking if there's any reason for it. Sounds like they just don't like competition ::headspin:
This is a very similar scenario to a trip to Peddars a while ago. My steering wasn't self centring properly so I got it checkerd.
They said I needed new bushes on the front and a new power steering rack. Almost a grand in parts and labour.
Turns out the bearings in the column were dry :P - $5 bucks for grease.
Saved myself a lot of needless cash.
Be wary.
It is hard though, especially with suspension. Nearly everthing is worn in some respect after some 10-15 years, but it's a matter of what is really important - and what you can afford. A place will usually always give you a big list. Also, whilst some bushes are doable yourself, some require the proper equipment to squeeze them in or set them up. And you can't really do the alignment or anything yourself. So even though I like to try and do as much as possible myself, I had to leave my stuff for somebody else.
I was faced with same scenario just last week.. and similar list of replacement parts for mine (not exact same). Cost was up around the same, so I don't think its too unreasonable. In the end, it hurt, but the car is handling a lot better, I can drive stupidly, and I know those parts should be good for a few years now.
Only thing I'd be wary about would be the steering rack.. unless there is obvious signs that it is rooted (e.g. leaking everywhere), I'd be leaving that one
ok, i gave whiteline a call today, and they said that the only bushes that they sell, are listed in their online catalogue (i.e. the ones that Sydneykid listed above), and any other bushes that are required, they use the super-pro bushes that i was quoted on originally. Now, they also said that the shop who did the quote is supposed to be one of the distributors for whiteline products, yet when i asked them about whiteline, they said they don't really deal with them, just the odd swaybar etc and then went on to try and sell me more of their stuff.... whiteline was rather interested by this fact when i mentioned it to them on the phone today, so i don't know what the go is there?
The rack is leaking (though not as bad as they made it out to be... it is slightly damp around one of the boots) so it does need replacing sometime, and i was going to do the bushes at some stage anyway, but i want to do it once, and properly the first time, hence wanting to know a bit more information so i can make a more informed decision come time to buy.
Thanks for all your help so far people :cheers:
jas will be more than happy to help u with your suspension. if anyone needs any bushes pressed out and back in i can do these at my work for $10 a bush. i do this all day on coaches and some bushes need 20 tonne to remove them. i have plenty of experence and will help any one that needs a hand. just pm me.
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
    • How complicated is PID boost control? To me it really doesn't seem that difficult. I'm not disputing the core assertion (specialization can be better than general purpose solutions), I'm just saying we're 30+ years removed from the days when transistor budgets were in the thousands and we had to hem and haw about whether there's enough ECC DRAM or enough clock cycles or the interrupt handler can respond fast enough to handle another task. I really struggle to see how a Greddy Profec or an HKS EVC7 or whatever else is somehow a far superior solution to what you get in a Haltech Nexus/Elite ECU. I don't see OEMs spending time on dedicated boost control modules in any car I've ever touched. Is there value to separating out a motor controller or engine controller vs an infotainment module? Of course, those are two completely different tasks with highly divergent requirements. The reason why I cite data sheets, service manuals, etc is because as you have clearly suggested I don't know what I'm doing, can't learn how to do anything correctly, and have never actually done anything myself. So when I do offer advice to people I like to use sources that are not just based off of taking my word for it and can be independently verified by others so it's not just my misinterpretation of a primary source.
    • That's awesome, well done! Love all these older Datsun / Nissans so rare now
    • As I said, there's trade offs to jamming EVERYTHING in. Timing, resources etc, being the huge ones. Calling out the factory ECU has nothing to do with it, as it doesn't do any form of fancy boost control. It's all open loop boost control. You mention the Haltech Nexus, that's effectively two separate devices jammed into one box. What you quote about it, is proof for that. So now you've lost flexibility as a product too...   A product designed to do one thing really well, will always beat other products doing multiple things. Also, I wouldn't knock COTS stuff, you'd be surprised how many things are using it, that you're probably totally in love with As for the SpaceX comment that we're working directly with them, it's about the type of stuff we're doing. We're doing design work, and breaking world firsts. If you can't understand that I have real world hands on experience, including in very modern tech, and actually understand this stuff, then to avoid useless debates where you just won't accept fact and experience, from here on, it seems you'd be be happy I (and possibly anyone with knowledge really) not reply to your questions, or input, no matter how much help you could be given to help you, or let you learn. It seems you're happy reading your data sheets, factory service manuals, and only want people to reinforce your thoughts and points of view.
    • I don't really understand because clearly it's possible. The factory ECU is running on like a 4 MHz 16-bit processor. Modern GDI ECUs have like 200 MHz superscalar cores with floating point units too. The Haltech Nexus has two 240 MHz CPU cores. The Elite 2500 is a single 80 MHz core. Surely 20x the compute means adding some PID boost control logic isn't that complicated. I'm not saying clock speed is everything, but the requirements to add boost control to a port injection 6 cylinder ECU are really not that difficult. More I/O, more interrupt handlers, more working memory, etc isn't that crazy to figure out. SpaceX if anything shows just how far you can get arguably doing things the "wrong" way, ie x86 COTS running C++ on Linux. That is about as far away from the "correct" architecture as it gets for a real time system, but it works anyways.
