I 'think' the GTR console uses a wierd size gauges. Somehting like 44mm or something. The smallest I know of is 52mm, so you might have problems finding gauges to actually fit (that's if your going to replace them.
Would look nice though.
A bloke on SDU made up a 3 x 52mm holder that sits under the stereo and it looked great. It was a very tight sqeeze to get all three to fit, and he even andled them towards the driver.
Anyone keen to make them up :P :bahaha:
  • 16 years later...
Hi guys, sorry to bump such an old thread, I’ve got the car at the auto elec at the minute for a ton of little jobs one of which is obviously fitting some r32 gtr triple gauges in my r32 gtst, I’m hoping to hear from someone who’s done it or an electrician/ mechanic
in terms of oil temp have you drilled the sump, used a simp plug or using an oil filter sandwich plate? Any links to anything you can purchase off the shelf etc
the boost gauge have people just tapped into the existing manifold pressure sensor on the fire wall? Added an additional similar manifold pressure sensor ?
Thankyou very much Guys or girls
I can't see the point of using the GTR gauges. Is one of them not a torque gauge for the AWD?
Just get a triple gauge plate and fit 3 gauges of your choice - boost, oil pressure and water temp.
Each gauge should come with its own fittings or you just follow the instructions. You may be able to T off the oil pressure warning switch for the pressure.
These are available on Ebay -
Triple Gauge Holder Din Bracket 3 x 52mm or 2 1/16
or you may be able to adapt the GTR holder if you have one.
R32 GTR torque gauge is in the main cluster, displacing the GTSt's boost gauge to the triple cluster in the console.
So, not pointless, but stupid, because why have 2x Nissan boost gauges (the original in the dash and the GTR one in the console) when you can have a better boost gauge? And while doing what everyone else has recommended (aftermarket gauges), why not put in something useful? Like EGT? Who the hell needs a bloody voltmeter?
Hey guys Thankyou for your feedback it’s just the look I want to go for, I understand having 2 boost gauges is abit of waste and a volt meter gauge is old school but as I said that’s the look I’m going for? So again does anyone have any experience or answers to my questions 2 posts up?
The only obvious answer to "it's just for looks" is to not bother to hook them up to anything except the lighting circuit.
If you have to hook the oil pressure gauge up....then a sandwich plate is the only option that makes sense.
And obviously the boost gauge is driven the boost sensor. The only question is....will hooking two gauges up to the same sensor cause them both to read wrong? Try it and let us know? But wait! How will you know?
You could always put in a redundant second boost sensor to go with your redundant second gauge.
Do
May I suggest looking in to VDO gauges. I took this route a few years ago with my old 32 GTS-t as I always wanted a stock OEM look. (I hate the space ship bright light cheap gauges)
VDO are a quality brand and easy to find. Sensors come with the gauge, you'll just need to pick up a single din slot 52mm gauge holder (Anywhere online/ebay) and wire you're selected gauges in accordinly.
From memory the stock gtr 3 gauge cluster harness runs with the dash loom. Massive pain in the ass to disect and install in to 32 GTS-t considering volt and another boost gauge would be pretty useless.
  • Like 3
    • I'd be looking at the mentioned EFR kit, room to turn it up if decide on e85 (which we know you will) and be super responsive and fun on the street. OR https://v8roadsters.com/product-category/engine-conversions/engine-conversion-lsx/engine-conversion-lsx-nc/?srsltid=AfmBOorrJa2S76JR5ekXprxBOtU44a1UProbe64YaiVi9zTVp1Lj814w And add whooshy noise for extra fun C5 corvette prices are coming down locally here and a mate has a manual one and is a heap of fun on the street and track.
    • I have an Elite 2500, honestly most of this has been a lot of smaller tasks chasing little details and a whole lot of life getting in the way of bigger projects. I don't mind too much looking at a spectrograph vs having audio knock ears.
    • Nah nah nah nah. Don't do it. It's not all about the full throttle power delivery. The main "street fun" and drivability gains from smaller rear (in this case) is how you will have boost available from a low rpm when yo just roll onto the throttle. Think jinking in and out of traffic, coming out of roundabouts, etc etc, where you just want to roll onto the throttle a little and have the spooly noise from ~2000rpm and a swell of torque. More of what you've already achieved by going to 2.5. And then, towards the tail end of 2025 you can pull the turbo 4 out and put in a V8 like we originally suggested. :P
    • Cheers for the info mate, I'm old too, 60 years old next May, so a more linear delivery of the 0.86 would be better as baking tyres and snapping heads isn't on the cards for me or the car I assume a more linear power delivery would be better for engine and drivetrain reliability as well, IRT the torque load at lower RPM???, as well as lower EGT's???, if my understanding of that is correct, have I got that right??? I've only got a really basic understanding of turbo sizing and all there characteristics  Cheers for the useful information
