This is an age old debet, my persnal experance is that i have ran my 95 r33 with remaped ECU (32), fmic, turbo back exst, HKS pod filter, bleed valve on 10, 12 and up to 14 all day every day for 2 years I normaly leave it at about 10 or 12, 14 when racing and had the dyno
run that other SAU's from canberra saw running on 12 well .7 bar, it always spikes to .9 bar then drops back. Stock turbo
i thought the stock turb's could only handle 10-11 psi?
thats the safest zone to run them in 10-12psi they will run 14psi some even higher but dont expect them to last
cubes ran his rb20 turbo at 16psi on his rb20 it still running 9psi on his rb30det even though its seriously restricting power on the big boy..lol
stock turbos generally wont give you an increase in power much at all over 10psi going to 12psi.
you might get a little... but its nothing worthwhile and only shortens the turbo life.
some people have freak turbos that seem to take it, but most dont
1 bar = 14.7 psi
0.9 bar = 13.2 psi
0.8 bar = 11.8 psi
0.7 bar = 10.3 psi
etc
I run the Stagea turbo at 0.7 bar, because we have killed (ceramic in the cat disease) 4 turbos at 12 psi on other Skylines. We found almost ZERO power increase running the standard turbo past 12 psi, they just heat up the air.:stupid:
hi guys just an update got it dynoed today very shit tuner sugest you dont ever go to incar performance at wethiril park sydney but still got decent power 234rwkw standard turbo standard injectors 14 psi for power run than to 12psi for street quite happy with the result but told by jem (just engine management) more could be done with the map and it was a shitty tune
    • I believe there was a similar one posted by @duggyphresh. They were re-routing their battery positive cable in the way I am also trying to achieve. Sorry, I’m new to this forum, so was a bit late to the party by a few months and so reignited the old thread, as I wanted to know how they got on with doing it.
    • Wasn't there a thread on this very subject just a few weeks ago?
    • Hi all! Looking to relocate the battery to the trunk of an R34 GTT. I want to do it using as many stock GTR components as I can (including the harness protectors from the 34 GTR that run underneath along the chassis to the engine bay). So far I’ve purchased the battery tray from a 33 GTR, as the captive weld nuts are already there just asking to be used. There is also the slight issue of now having to relocate the ABS/TC/Fuel Pump Control ECU, which in GTT’s sits right above where the battery will then sit on the tray. Has anyone already achieved this, and if you have any pics that you wouldn’t mind sharing? It would be great to see how others have done it and where you put them, as there are countless holes in the parcel shelf panel to potentially use. Just trying to get some ideas bounced around, and to help uncover any potential problems I may encounter by  my choice of location. TIA for any help!
    • Brand was ard.   I also threw a brand new battery at it and beefed up the wire from the alternator to battery and added an extra earthing point from the battery
    • Evening all,       I'm replacing some bolts on my RB25 with probolt Australia bolts.       Does anyone know the following, m5 m6 etc 10mm 20mm etc       Coil cover   Cam covers   Plazamaman fuel rail   Front cover (timing cover)   Etc   Any help would be awesome   Or any lists anywhere
