  • Replies 74
Spewin I had to work. Would love to have seen Mick run...And myself to...
Um, just checked the track times for the Sprint Track... ARe those times correct for all the categories?
Cause I've ran a fastest of 1:07.02 "DRY" street trim with SC fitted & 1:19.48 "WET" street trim and NA.
All in my humble R31 GTS1.... Surley I can't be mixing it with the turbo cars with boost and mods etc etc....I realise the "hand clicking" timing to..
Heres a easier one to read for the wet weather ones
(Wet) TRACK: Qld Raceway Sprint
GTR Class:
1:08.30, R33, jlNewton
GTS Class:
1:14.29, R33, SirSkyline
1:15.41, R32, nf.
1:16.10, R32, predator
1:16.68, R33, Toy33
1:20.30, R33, JCMarshall_Law
1:21.99, R33, Mr.R33
EVO Class:
TRACK: Qld Raceway Clubman
GTR Class:
1:14.60, R33, jlNewton
GTS Class:
1:17.46, R33, SirSkyline
1:18.58, R32, nf.
1:20.55, R33, Toy33
1:20.66, R31, predator
1:23.13, R33, JCMarshall_Law
1:23.76, R33, Mr.R33
EVO Class:
TRACK: Qld Raceway National Circuit
GTR Class:
GTS Class:
EVO Class:
Edited by SirSkyline
Thats about right. I ran consistant low 1:04s in my old GTST on the sprint layout with just a cat-back exhaust, pod filter, stock boost and Yokohama A539s 235/45 R17, in the dry of course.... Might bring the 33 sedan out for the next one too, see what it can do, That will keep me busy for the day :(
svd001: I think JCMarshall_Law meant real as in the guy hand clicking didn't make a mistake.
SirSkyline: Yea ok, you were after the result order rather than just the times. The reason I didn't do that is that "Wet" track can mean so many different things, like "constant rain" or "rained earlier but the line is drying" or "its raining so hard I cannot see".
Did all you guys collect your end of day time sheet before leaving ?
On the front page I've got Old Toy33 (GTS) and New Toy33 (GTR)
nf, if you mean the end of day sheet with all your laps, a graph of your performance and everyone else in rank order etc (the one jlnewton is referring too) , I printed them but not everyone collected them. If you want I'll post it out. Just PM me a mailing address.
Paul
AzzurrA, sorry not trying to appear to have 'l337' group, its just our times are done electronically to 1/100th sec. Whereas the normal times at Sprints are timed by hand (see posts above for full details). So the times kept in this thread are accurate results.
Paul
  • 2 months later...
    • Hey y'all, I have a completely stock 1991 R32 GTR, yesterday I took my car out and went for about a thirty minute drive. It was fine on the way there but when returning home I think the car might have gone into a limp mode. I was cruising in 5th gear around 130km/h, the hicas light came on and there was a significant loss of power. About a minute later I hear a thump, the car starts driving normal again and is fine the rest of the drive back. This is the second time its happened, same as now it was fine on the trip there. On the way back it had the hicas light on but that time I would feel the power going in and out before hearing the same thump and it being fine.  I have no idea idea what causing this, but if anyone has any ideas it would be great as a start chasing the cause of this. Also I can provide more details if needed. Thank you
    • When sanding across a convex panel, you need to sand, as much as possible, at right angles to the curve. If the panel is compound convex curved (ie curved in both directions) then you are SOL and have to use "craftsmanship" to get it right.
    • Today in Skyline arts and crafts!! I’ve made some progress.    had to put extra notes in there so I don’t stuff it up 😂
    • This sounds like me. And then why I leave shit that I had previously hobbled together broken. Lately I've changed strategies to "If I don't want to justify the money on decent stuff, I'm not going to justify hobbling it together". I'm still for DIY, but DIY it properly is more my thing. However, I am terrible on not setting up backups still... Which reminds me, I need to go backup some of my work VM machines... Oh, it's also why I've become a lover of building things into Docker Containers... Then I just need a machine that can run docker, and bam, that specific system is up and running, on the specific versions of everything I need for it to run (In the event a change in required software version breaks something else). Also, these days, my steep learning curves are spent with work related stuff, and on very varied projects, that my want to do other random projects like build a dashboard for my own car has dwindled away to "I just want the car running", which is my current PITA, as I'm getting the Landcruiser usable again, and it has just been non-stop the past 6 to 8 weeks of buying parts, and working on it. Oh, and tools that are meant to be fit for purpose... And they break, because 25 year old 4WD decides it's stronger... But by the time I have it ready to roll back out the drive way, nearly all the stuff in it will have been touched and serviced, so the damn thing better give me NO FREAKING ISSUES, for at least the next 50,000KMs! Just redone whole front of the motor, and resealed the up top stuff, replaced a bunch of things getting perished, new timing belt done, water pump, lower timing cover (Toyota diesel engine runs timing GEARS for the bottom half the motor, and a timing belt from halfway up to the top), new harmonic balancer, fix up the alternator, new thermostat, full swivel hub rebuild, new bearings and seals front and back, steering box rebuild, new battery, and today, it turns out a rear shock has let go, so four new shocks are about to go on order, and that will leave me with after the next run of work, to see if I need to order just a brake caliper re-seal, or if I'll need new pistons in them too. Oh, and I'll finish welding in the new floor sheet metal shortly too. Presently I just want it finished already... But once all the above is done, I still need to fully service diffs, gearbox, transfer, and motor. Then flush and bleed the clutch, and flush and bleed the brakes. But enough about our waffle, back to Duncan's heat problems... I think for Duncan he just gets a thermoswitch, and a manual switch to run some water misters. Thermo so it's only on above certain temps, and the manual switch so it can be turned off even if it is above certain temperatures. IE, switch on for "I'm now on track", then it doesn't need any "smart" computers that might try and do things wrong. And switch the thing off completely on the cool down lap, so when he stops in pits, there's not even a possibility of it dripping any water out to get him in trouble.
