As you all know i have been plaged with lots of little problems that are really starting to shit me, now my question to you guys is should i just piss it off and upgrade to an r34 gt t
sell and upgrade
no keep it and stop bitching
https://www.sau.com.au/forums/topic/74086-should-i-sell-and-upgrade-to-r34/
Yeah Andrew's got a point
If you've replaced near on everything on your car, then you could ber confident that it's all good now.
However if you want to upgrade, an R34 would be tops, I know that's what I'm getting next (Kinda sorta got one now already :D)
It's up to you, if you feel like a change, then go for it. If you feel like sticking to what you know, the go for it.
better the devil you know than the devil you dont know.
i love your car snooze. if you bought an R34, what would you want to do to it? wheels, kit, and all the other mods your current car has, right? how much would that all cost from scratch? sh*t loads. you've already got all that, why start again?
if you have the money i would :D i like my 33 but 34's are just as sexy + not as many around well at least for another year or two. PS buy the one off the guy at newgel he was selling last i heard its got some nice little mods and the paintwork is awesome BUY IT!!!
i am at a loss as what to buy next too either 34 or wrx who knows but i wont be selling for a good 2 - 3 years still
HOW DARE you say that "W" word leigh...
This is a skyline fourm..
Subarus are still nice Erica!! :stupid:
Yea, true waht most say... Why start again, you will end up loosing alot of money.
Newer car yes... but you already have a sweat looking car.
Manual 34s are not really coming down in price at all. Basic one in good condition are still ~35k. Another point is that many of the parts are actually interchangeable so you could possibly return yours to stock? eg Front Mount and piping for 33 will fit a 34.
I love my 34, I still look forward to the start and end of the day when I get to drive to/from work.
I really don't understand the no wing look on the 34s, can't say I'm a fan at all.
you should sell it and get like a VL cause they is sick n shit. 1st mod you will need to do b4 you drive it anywhere is put a monsta tacho on. Even if its stock and auto. 2nd you will need to put a 4X4 lift kit in the front and remove the springs from the back and trim the bump stops so your exhaust just clears the ground. 3rd mod is the numba pl8ts. They need to be DISNEYLAND. lol
Im bored and cant sleep.
*SIGH*
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
    • Silly question, as I bet you've checked already, but the motor turns over by hand yes? I suspect Neil has a spare starter, though if not, I believe I have a spare R33 (or two) starter.
    • Yeah just run one of those posts to the Link like GTSBoy said. From google it looks like a "mishimoto boost controller" is a manual boost controller. Since you already have the link just buy any MAC valve and plumb it in where the mishimoto is now. Wires to the solenoid should come from the Link's / standard loom boost control wiring (I guess you have an r32, not sure if it is gtst or gtr, if it is GTR where is a 2 pin connector near the engine bay fuse box/injector resistor for that purpose, assuming the standard boost controller is gone)
    • No. The ECU's hose is for a connetcion between the plenum (assuming single throttle body, not ITBs) and the ECU's internal MAP sensor. This is the primary load measurement of the ECU - so you need to get this one right. This has NOTHING to do with the boost contol. The wastegate also needs to see a boost signal - but it is actually far better for it NOT TO COME FROM THE PLENUM (again, assuming single TB, and not ITBs). This should come from the turbo's compressor housing (assuming there is a nipple on there, which there might well not be), or on the boost pipe somewhere between the turbo and the TB. On the pipe from the turbo to the intercooler is usually most convenient. The boost controller is then located between that boost source and the wastegate, ACCORDING TO THE CORRECT PLUMBING DRAWING FOR THAT BOOST CONTROLLER. There is no general diagram or instruction that will be correct for every case. Then the other ports on the plenum are for purposes such as Duncan described. If the boost controller has an internal MAP sensor, for a boost display, etc, then it will want to be hooked up there, alongside the ECU and the FPR.
