g'day guys,
i have a little concern about my R33. whenever my turbo comes on boost, it squeals to high heaven. nobody seems to know quite what it is. i've heard some say that its a boost leak or something from the turbo seals, but the car hasn't lost any power. am installing a boost gauge shortly, so i'll see where its boosting. got me stumped. its gradually been getting worse over the past few weeks. i dont drive my car particularly hard, but i kinda have a feeling its time for a new turbo. any ideas would be great.
cheers.
https://www.sau.com.au/forums/topic/74093-noise-bad/
ok, so installed to boost gauge on the weekend to see if its leaking, and its not. its running at spot on 7psi. doesnt roll back, it just sits a dead on 7psi. so, i took off the bov to check it all out. the gasket is a thin metal one, so im thinking of changing that. but its not leaking any boost, so this is leading me to believe that it may be an exhaust bolt or something else. am yet to check the turbo, but will try to do it soon. work is flat out atm. hhhmmmmmmm.....dont know what else to do.
https://www.sau.com.au/forums/topic/74093-noise-bad/#findComment-1369453
    • Hi. A little bit of an update. It maybe(hope not) looks like i would need a new tranny(it would be "maybe" a cheaper or better option anyway) So i need some info. I know i need a different propshaft(i can make custom one) LSD is not a problem cuz the engine will be still(for now) N/A RB20. So if i buy RB25DET NEO tranny...is there something else i need? I read something about push/pull type but i do not know if i need to "change" something or i can just plug n play onto my engine a go? Thanks for the advice
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
