Hi,
There is about 99 000 kms on my clock at the moment and my car was due for a service at 98 000.
I am going to get the major service done pretty soon, and want to know what is the BEST way to go about it without burning a hole in my pocket.
I have been quoted approx $1000 from 2 workshops for a major service.
Can you guys please let me know exactly what I should have done and what I should expect to pay. The car is running like a dream at the moment and has a 3 inch turbo back exhaust and air filter with heat partition. Spark plugs were changed on my last service.
I am thinking about getting my injectors cleaned too.
Also need to install a boost gauge but have no idea how to do any of this stuff....
Anywhere you guys can recommend?
https://www.sau.com.au/forums/topic/7410-100-000km-service-time/
Sounds like you're on the right track. I can't give you a suggestion of a workshop, but if you are handy with a socket set you could do most/all of the service yourself.
1.Your timing belt will HAVE to be changed, ask around about the horror stories if you don't.
2. You should have your water pump replaced as well.
3. Good synthetic oil/filter
4. Fuel filter code Z200
5. Check you plugs, if in good nick leave them be, if they are looking a bit worse for wear, cough up for decent platinums.
6. Getting you injectors cleaned/tested would be a good idea as they have been known to cause problems sometime (usually due to bad maintenance)
You really should be able to do all this yourself very easily except for the timing belt and water pump. The reason your costs are so high is the labour involved in replacing these parts.
If you can do it yourself, or even ask some guys on the forum for help (offer 'em a steak and a carton).
All up should cost you max $500 including everything - so $500-700 goes on labour.
Hope this helps. Someone else may have something to add?
Cheers,
Tim
Guest too quick
Originally posted by MR R32
THanks for your reply Tim.
Can anyone tell me where they have had a major service done and how much they have paid.
Is there anyone in here that lives aroung the Castle Hill area in Sydney that would be handy with a socket set?
Hey,
let us know how you go - about to move back to Sydney for a while and want to work on my own car too and I'm going to be living out near the Castle Hill area - my old turf... can't wait to do some work on the car!
Maria
This is what I would do.
1. Replace Cam Belt ~ $103
2. Replace Waterpump!!! ~ $75
3. Replace Thermostat!!! ~ $24.95
4. Gasket Paper for the Thermostat Housing $4 and the goo stuff $5 maybe.. But it is cheap.
5. Get the Block Powerflushed and the Radiator Rodded. ~$120-$185
DIY obviously.
The reason why i say the last few (cooling system) is I've just blowen a head gasket due to the temperature getting up to 3/4 and having to hit boost up flagstaff hill to get up there. EDIT: No It was a air lock.. No CO2 in the Coolant... :(
Get the cooling system done...
When I had the twin Thermo's fitted I had no overheating problems. To be on the safe side I had my radiator Rodded at the same time.
BUT.. It didn't work, Obviously there was crap in the block as this summer hits and it starts to overheat.
I ran Mukout in the car for the last 2 days and flushed the motor/block my self and it has fixed the overheating problem.
Only ever so slightly though. It doesn't use water YET and there is no water in the oil, it idles smooth but there are tiny bubbles in the radiator.
Cooling system is a priority!!!!
Also Flush your brakes and Mastercyclinder!
Guys a major service dosnt just meen under the bonnet e.g:
diff oil
gearbox oil & filter (if auto)
handbreak adjustment
break fluid flush mechine disks and new pads (if ness)
air filter
air line hoses
radiator and heater hoses
full wheel bearing and bush lube
cv joints re packed
uni joints greesed
door hinges and locks lubed
as well as the jobs mentioned in other posts above
prob more that I cant think of atm
a full diag of the engine management sys (reg proper diag equipment that not many mechnics have! (even tho most say they do),(they plug the car into a computer at the fuse box under the dash and can tell anything about the car and how its running).easy way to get ripped off by mechnics that dont do what they say or dont have the equipment to do the job properly)
a major service should include a go over the whole car!
Regards
Damqik
At this stage, I will be having the car done by Rev Rite Performance in Silverwater. They are honest guys, and do a lot of Jap Imports - just waiting on an approximate price, and a holder for my Autometer boost gauge, and then she will be done.
The fitted my turbo back exhaust and did a service for me about 2 months ago. I highly recommend them.
Will post the results in the new year.
  • 3 weeks later...
Guest GodFather
MR R32
So Rev Rite are pretty good huh?
I have 130,000 or so on my R33 and as far as I can tell (have had it for 10,000 or so) I don't think it's had the belts and stuff changed.
Wanted to get a servicer who knows their Skylines and can do a decent service as well a tune on the whole shell.
So if this guys know their stuff, are trustworthy and well priced hand over their details.
Cheers mate.
The service is done now!
It was done by RevRite Performance in silverwater for $760.00
Got it back today, they got broken into last night, but only went for the GTR that was being rebuilt and walked straight past mine - they knew what they were after.
The timing on my car was off, and has now been fixed. Much more responsive now. A bit of an animal......
On the way home, I pulled up next to a VT Series 1 SS on Silverwater Rd (late xmas present). Burnt him badly - at the next set of lights, he asked me to wind down my window, and said Thanks mate that sounded awesome. He was actually pretty good about it all. He was about 35-40. Tried to blame his auto box.
Told him I just had a major service done - and he just said have fun!
I strongly reccommend REVRITE PERFORMANCE in Silverwater.
heheh I burnt a Maloo Manual 255LS1 red ute with custom number plates this morning.
Same thing 40year old bloke & he started it.
I really expected it to be quicker. Had 2 runs with him one from 50kays (big mistake right in my peak torque & wheel spun through second as I was on a real slight bend when I planted it) and another from a set of lights. I launched with wheel spin in first (crappy Baraum tyres) 1/2 a car length behind by the end of second I catched him nose to nose chirped third and pulled passed him quite easily.
Basically it felt like I could have backed off then played with him a little.
Yer those VT SS Auto's are a little sluggish (stock).
    • No worries, everything worked out in the end. I just wanted to make the point that it doesn't matter where it comes from (I.E Australia), it can be broken or improperly built. I would still purchase from these companies in the future. B2R - Not certain how that finished, this was on a car I wired a few things and street tuned. I know the owner ended up shipping the motor back to Australia for investigation. Hopefully some of it is covered under warranty.  Turbosmart - I always pressure test everything that goes on my car. It's a habit from my career in oil and gas. I run two 40mm's and both had major leaks from the actuator to exhaust portion through the shaft. I returned both, they shipped me back two and one was leaking and the other had a 38mm top (40mm gate with 38mm actuator cap, no idea how that happens). Eventually after a lot of back and forth I found myself with two non-leaking gates. I believe this happens a lot more then people would like to believe but you would never know if you don't pressure test them prior to installation. Crank Motorsport - Issued a full refund and let me keep the seat rails. I turned them into scrap metal for other projects. GKTech - Shipped me out a replacement and asked that I modify it as per my idea and that they would do the same for a future revision. ATP - Can just needed a large shim to bolt up properly.  Haltech - They started an actual proper Beta channel for firmware's a few months back and stopped using the general public for testing. I'm now much happier.  Speedtek - f**k Speedtek. I would love to watch them burn.
    • I've got a Turbosmart wastegate, ATP catch can, many GK Tech parts and Haltech everything. Everything's been perfect, sorry to hear your experience wasn't the same
    • The only high-power RB I've personally seen go pop after running for all of an hour on a dyno was built by B2R, while being remotely tuned by B2R. The only wastegates I've ever had leak like a sieve, return, still leak, return and get shipped back the wrong ones were from Turbosmart. The only final drive that I've ever purchased that were unusable, twice... were from Speedtek. The only seat mounts that I've ever purchased that placed the seats in the door frame were from Crank Motorsport. The only poorly designed parts that I had the manufacturer confirm should have been designed as per what I mentioned were from GKTech. The only ECU I've had firmware updates consistently break things are Haltech. The only catch can I've purchased that didn't fit in its advertised spot was from ATP. So forth and so on... Moral of the story, doesn't matter where it's from. Do your research beforehand and stick with products and companies you've trusted in the past.    @joshuaho96 If you want it done right, do it yourself.
    • Something coarse-ish. 180 is good.
    • I was surprised to see all the quick Jack models at the same prices on there. But yeah, grabbing one at 20% off would be great.
