Im selling my 180SX due to financial reasons... Lost my job and can longer afford my loan repayments so shes got to go so i can repay my loan and credit card :)
Heres the info:
Nissan 180SX with an RB20DET Conversion.
72 XXX on the clock 4X XXX on motor when purchases as halfcut
5 speed Manual (gears are very tight and smooth)
Serviced every 5000ks with Fully synthetic oil.
4 good tyres
NSW registered
Totally immaculate inside and out.
OUTSIDE
-Complete respray in R34 GTR Bayside Blue with 2 coloured pearls and a metalic flip - Spray includes enginebay and door sills etc.
-Cwest front bar, vertex side skirts and rear bar
-Spoiler removed and holes filled
-Vented Fibre glass bonnet
-Electric Gandor Aero Mirros
-Clear side indicators and front indicators
-18" HP Design rims in Gunmetal (only about 3 weeks old)
-Very dark window tint
INSIDE
-Roof, Door Trims, Glovebox, retrimmed in Blue
-Monza Reclinable front seats (blue and black)
-Centre consol and guage surround sprayed in silver
-Custom febreglass centre consol with 3 Autometer guages - Boost, Oil pressure, Air/fuel
-Nardi Leather steering wheel
-Leather gear knob
-Chrome & black hand brake
-Autometer 5" Moster Tacho with blue shift light
-Relocated aircon/heater in custom setup in center arm rest with turbo timer as well.
-VDO CD Player
-Alpine 6X9s in the front doors
-Brant 6 Point keypad immobeliser and alarm, Under bonnet and incabin siren, motion sensors etc top of the range.
ENGINE
-RB20DET motor conversion
-RB20 gear box
-GTR 1.5way LSD
-RB20 Radiator with twin thermo fans
-Rebuilt Motor
-50thou over pistons o-ringed
-Copper head gasket
-Brass Button Clutch
-Custom Plenuim
-Custom Garrett GT28-40
-Turbosmart PROGATE 45 external wastegate with screemer pipe
-R32 GTR Injectors
-EMS stand alone computer
-DNA FMIC 600X300X75 with custom pipe work
-DNA Pod in custom alloy airbox
-DNA Boost controller
-Boche Fuel Pump
-Rising fuel pressure regulator with fuel pressure guage
-Surge tank
-Oil catch can with breather
-3" Turbo back zorst with screemer pipe off wastegate, Hi flow cat etc
-5Ziggen Muffler
-Aftermarket earthing kit
-Big boshe battery
-Nismo Oil Cap
BRAKES & SUSPENSION
-5 stud conversion with Skyline 4 spot calipers painted blue
-Tien front coilovers, Height & Dampner adjustable
-Tien adjustable camber tops
-Custom rear coilovers, Height adjustable
-Adjustable Castor/Radius rods
-Rear strut brace
-New Bendex brake pads
-Braided brake lines
THE CAR COMES WITH ENGINEER PAPERS FOR JUST ABOUT ALL MODIFICATIONS
Im sure there are more modifications which i have not remembered.
This car is very quick and handels like a go kart.
This car has nothing more to spend on it and is ready to take to the show or track.
Had $22000ono on the car but due to looseing my job i have lowered the price to $19500firm as rego is due JULY9th and i dont have the money to re-register it so im really wanting to sell it before then. I have no doubts the car would pass rego with out hassels... The only thing which i think would be picked on would be the window tint being dark but this is an easy fix. Other then that everything is engineered and would pass easily :rofl:
Im looseing lots of money but what can you do when your in this sort of situation :rofl:
Call Troy on 0402 756 302 .... or email [email protected]
could consider swap with WRX or Skyline just have to see pictures etc...
Im going to just go give it a wash and take some pics now so ill post them up later.
Cheers
hey mate....
Are you the guy who has been sending my MMS but they havent been comeing through?
I can put my sim in my old phone and get you to send them again and try again...
    • So the clockspring is responsible for the indicators cancelling on their own? I thought that was the function of that white thing in the center (any idea what it's called?)
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
    • So, the other thing I've sorted is a baseline dyno run up at Unigroup's new location. The auto trans was a little unco-operative by both shifting down when the throttle was floored on the dyno (so Mark had to ramp it up more slowly than in a manual) and also by shifting up at 6,000 even in sports mode instead of the indicated redline of 7,000 Still, on a hot day it made 240rwkw at 16psi which seems about right for 300kw (400hp) through an auto at the wheels.  The shape of the curve is not quite right because it was not full throttle to about 4,500 to stop it kicking down, but until I can get a tune on the auto trans control this was the best we could do.....full boost will be well below 5,000 once that is sorted, I'll get some data logs when I can to confirm For comparison, the R32 made 255 at 12psi (at 4,500) on the same dyno with tune, n1 turbos, cam gears, big exhaust but otherwise all standard so the v37 is likely a little better out of the box. One thing that is very clear is that the standard water to air intercoolers are not up to sustained use at full throttle in warm ambient temps. After about 5 runs (so only a few minutes full throttle), it was pulling boost and timing and dropping 10-15% power. Unfortunately I didn't get that printout and the Unigroup guys are away at the moment, will try and get hold of it on their return. So, looks like a healthy engine to start modifying and the only real area of concern is the w2a heat exchangers which the aftermarket has plenty of solutions for
    • I maintain it actually looked really nice in person. So much so that I thought "No, this is illegal" but there it was, clear as day. I think we can easily call the wing and wheels/height to be transformative. Not saying it's better than the GR Whatever, or the 86, or the WRX STI or anything of that sort (the internet says it all bolts up so you can buy best of all worlds?) but it's still at least a thing and not nearly AS bad as people say.
    • That's less offensive than the previous gen.....except for all that ugly black tupperware around the edges. Blerck!
