Im selling my 180SX due to financial reasons... Lost my job and can longer afford my loan repayments so shes got to go so i can repay my loan and credit card :)
Heres the info:
Nissan 180SX with an RB20DET Conversion.
72 XXX on the clock 4X XXX on motor when purchases as halfcut
5 speed Manual (gears are very tight and smooth)
Serviced every 5000ks with Fully synthetic oil.
4 good tyres
NSW registered
Totally immaculate inside and out.
OUTSIDE
-Complete respray in R34 GTR Bayside Blue with 2 coloured pearls and a metalic flip - Spray includes enginebay and door sills etc.
-Cwest front bar, vertex side skirts and rear bar
-Spoiler removed and holes filled
-Vented Fibre glass bonnet
-Electric Gandor Aero Mirros
-Clear side indicators and front indicators
-18" HP Design rims in Gunmetal (only about 3 weeks old)
-Very dark window tint
INSIDE
-Roof, Door Trims, Glovebox, retrimmed in Blue
-Monza Reclinable front seats (blue and black)
-Centre consol and guage surround sprayed in silver
-Custom febreglass centre consol with 3 Autometer guages - Boost, Oil pressure, Air/fuel
-Nardi Leather steering wheel
-Leather gear knob
-Chrome & black hand brake
-Autometer 5" Moster Tacho with blue shift light
-Relocated aircon/heater in custom setup in center arm rest with turbo timer as well.
-VDO CD Player
-Alpine 6X9s in the front doors
-Brant 6 Point keypad immobeliser and alarm, Under bonnet and incabin siren, motion sensors etc top of the range.
ENGINE
-RB20DET motor conversion
-RB20 gear box
-GTR 1.5way LSD
-RB20 Radiator with twin thermo fans
-Rebuilt Motor
-50thou over pistons o-ringed
-Copper head gasket
-Brass Button Clutch
-Custom Plenuim
-Custom Garrett GT28-40
-Turbosmart PROGATE 45 external wastegate with screemer pipe
-R32 GTR Injectors
-EMS stand alone computer
-DNA FMIC 600X300X75 with custom pipe work
-DNA Pod in custom alloy airbox
-DNA Boost controller
-Boche Fuel Pump
-Rising fuel pressure regulator with fuel pressure guage
-Surge tank
-Oil catch can with breather
-3" Turbo back zorst with screemer pipe off wastegate, Hi flow cat etc
-5Ziggen Muffler
-Aftermarket earthing kit
-Big boshe battery
-Nismo Oil Cap
BRAKES & SUSPENSION
-5 stud conversion with Skyline 4 spot calipers painted blue
-Tien front coilovers, Height & Dampner adjustable
-Tien adjustable camber tops
-Custom rear coilovers, Height adjustable
-Adjustable Castor/Radius rods
-Rear strut brace
-New Bendex brake pads
-Braided brake lines
THE CAR COMES WITH ENGINEER PAPERS FOR JUST ABOUT ALL MODIFICATIONS
Im sure there are more modifications which i have not remembered.
This car is very quick and handels like a go kart.
This car has nothing more to spend on it and is ready to take to the show or track.
Had $22000ono on the car but due to looseing my job i have lowered the price to $19500firm as rego is due JULY9th and i dont have the money to re-register it so im really wanting to sell it before then. I have no doubts the car would pass rego with out hassels... The only thing which i think would be picked on would be the window tint being dark but this is an easy fix. Other then that everything is engineered and would pass easily :rofl:
Im looseing lots of money but what can you do when your in this sort of situation :rofl:
Call Troy on 0402 756 302 .... or email [email protected]
could consider swap with WRX or Skyline just have to see pictures etc...
Im going to just go give it a wash and take some pics now so ill post them up later.
Cheers
hey mate....
Are you the guy who has been sending my MMS but they havent been comeing through?
I can put my sim in my old phone and get you to send them again and try again...
    • I mean he could post them to imgur or the like and create a link. But yeah, spam bots absolutely will post pictures in their first posts.
    • Ah ok, reason I asked was for the sake of not having to upgrade everything if the turbo couldn't be capped.
    • pffft! My alignments are starting to take 3-4 weeks each. Bugger overnight - that would be a dream! Overnight is when I leave it on stands with the rear suspension in pieces, hoping I can remember where I was at when I come back to it. I have to set the car up on a level surface so I can get decent camber measurements, then try to set the RUCAs to the right length to get that right. Then I have to put the car somewhere else where I have enough room to set up the bumpsteer gauge (laser, paper, mirror), so I can dial out that. Then I need to go measure camber again because changing the tension arm length affects that also. Then I need to measure toe, and I can't do that to my own satisfaction at home, so I have to put it on an actual aligner. Then I have to go back and fix the camber again, and if that took more than a half a turn, decide if I want to set up the bumpsteer measurements again. I previously had the bumpsteer almost completely banished and then I started changing things again! And that's only the rear end. Not even gotten to talking about the front yet. And this has been going on in the context of me discovering a seized bolt in the LHR FUCA bush at the upright, hence needing total disassembly to replace that bush and the others that were not far away from the same outcome, replacing sphericals in the front end and making a mistake that resulted in needing to do it again, which is only half done right now. It's a selfmade nightmare. Only have self to blame, etc etc. But regardless, I am so complelely unable to utilise the services of a normal wheel aligner that I have no choice. I haven't found a shop in my city that does "race" alignments - and by that I don't mean I want my car to be set up for racing, but the set of adjustments that I have available and that need to be used to do the alignment are the same as you'd find on a race car. I haven't looked everywhere, but there doesn't appear to be the equivalent of the motorsport focused shops that are present in Sydney and Melbourne. And such an alignment would cost $300, and you only want to do it once in a while, and you don't want to find out that you have to replace bushes and bearings and such while you are spending that $300 so you have to come back and spend it again a week later. So I stay living in my self made nightmare for the moment.
    • Well, yeah, obviously. But then you have a turbo with 270kW "design", meaning it will have the higher boost threshold and lag of a bigger turbo, but only doing the work of a smaller turbo. That's the suck. That's actually exactly where I am right now, because my stocker exploded and I got Tao to do a highflow for me. I got a low pressure actuator on it and don't push it past ~10 psi or so, where the stocker was being run at ~12 psi. it makes a little more power than the stocker did, but it lags like a bitch. But, if I run any more boost it starts to ping and the ECU goes into panic mode, which cuts all the fun, so it clearly needs to be tuned. But, until such time as I (which is not I, it's my bro-in-law) can actually get the dyno working again, and get some injectors, and do all the swap over of those and the R35 AFM, I can't attempt to use the turbo the way it really deserves to. So what I have now is something that drives worse than what it did before it filled the cat with little pieces of turbine. I will tune it eventually, and probably only push it up to ~250-270 rwkW, which is pretty close to the max for that highflow anyway. I would imagine that by getting the tune right, and with newer betterrer injectors, we can probably make the boost come on a little earlier than it does now.** And if I do not think that the top end reward is worth the low end sacrifice, I will sell it off and convert to a G30, because the smaller ones of those come on boost very nicely on a 25 and make more power than I realistically need or want. The only reason I didn't do it at the time the turbo blew up is that I wasn't ready to sink a lot of money into an Artec manifold, reverse rotation turbo, the AFM and injector upgrade that would have been immediately compulsory, and the dyno was being problematic.*** It was easier and faster to just put the highflow on. And then, as I mentioned in an earlier post, even that is not "easy", because Tao's highflows use a shorter core than the Hitachi, so the compressor housing moves backwards in the bay, necessitating that all of the pipework had to get modded. ** And maybe just maybe, check the valve clearances and put new shims through, because I have recently seen firsthand on another motor that sloppy clearances on the shims can cost a lot of effective timing and lift and really slow an engine down. 3S-GTE in a Caldina got new shims, closing the clearances from just above the max to right down near the minimum, and it is a massively different car to drive. On boost the better part of 1000 rpm earlier!
    • ooooooh so this is where they get posted  Was at a wedding that day anyway, but the next one I will be there for SURE.
