I have noticed on my R33 that once I am over around 90k's the steering is very heavy, even on gradual bends. I am running 235's on the front, but while stationary the power steering is light.
I assume the R33 has speed sensitive steering, does anyone know if its programmable? It just seems WAAAY too heavy around 90-110 for high speed cornering ( I guess its calibarated for skinnier tyres really).
Ta
Conrad
https://www.sau.com.au/forums/topic/7413-power-steering-speed-sensitive/
I thought at about 60km/hr the HICAS should kick in and cause the rear wheel to act in sympathy with the front, providing a 4WS situation. After checking alignment etc, check you have sufficient power steering fluid, not enough will make it feel heavy, but you would expect this to be all of the time.
See'ya:burnout:
but is the steering speed sensitive (eg reduces the power steering assistance as you speed up so its not too light at freeway speeds) ?
Slayer,
Yes, I believe that it works this way, otherwise it would be too flighty at high speed. Have you driven any other GTS-t's to compare it to. Your steering may be heavier all of the time, but it might be more noticable at high speed. I'd still suggest checking alignment and power steering fluid.
See'ya :burnout:
I just got Bridgestone Potenza G3's put on all 4, and I was getting the alignment done and they said there is a problem with the alignment in the passenger side rear, they had to keep it on a slight negative camber... He said it may have been bumped into a curb in Japan or something, and this could inturn affect high speed cornering. He recommended the best thing for me to do was speak to whiteline about a bush kit which may fix the problem up a bit...dunno, will c
Paul Paul
    • @soviet_merlin Thanks mate!  Nothing too major but will hold me up for a while. I've got lymphomas to get taken off the back of my neck and the middle of my spine which always conjures scary thoughts!  It sounds worse than it is. Yeah great, conjuring more rabbit hole deepening , just what I need! 🤣
    • I'd argue the F50 kit I got is very good value. For ~2k I got the calipers (refurbed condition), adapters, pads, brake lines, rotors, and top hats. I think you'd be pretty hard to get Evo/GTR/350z brembos + the additional hardware for similar money. Used market for a pair of front calipers alone I've seen tend to run anywhere from $1500-2000 depending on condition.    That said, something like a GTR or 350z brembo is a lot easier to adapt to the Silvia.
    • Is there a significant price difference between the Evo/gtr/350z brembos vs the F50? Looks amazing.
    • I was actually being a tightarse at the time LOL... My OCD is tickling me into running a 2nd 8AN Teflon hose all the way down and removing the 2x OEM hardlines. My other side of my brain is telling me to run 2x hardlines front to back (also acts as a fuel cooler, so win win).
    • As I mentioned in an earlier post, I had some trouble with the Silvia's brakes dragging back in 2023. I managed to sort it out then, but the same problem came back to bite me late last year. Just take a look at the picture – I had a feeling the handbrake was acting up again, and I was right. Anyway, I'd been wanting to upgrade to bigger brakes for a while. Not that the Silvia's brakes were bad, but it was more of a "want" than a "need", you know? It was funny, though – at the time, I couldn't find any Evo Brembos, 350Z Brembos, or GTR Brembos for a decent price (of course, tons of them popped up online after I already bought my kit!). I ended up going with an F50 Brembo kit, which came with adapters, brake lines, 330mm rotors, and top hats. The F50 Brembo caliper was used in a few other cars too, like the FPV. I also decided this was the perfect opportunity to ditch the Silvia's ridiculous rear brakes and that awful handbrake (some of you were definitely right about that!). I picked up some R33 calipers and all the necessary bits – rear drums, backing plates, and new hardware to refurbish the calipers. Of course, it wouldn't be a project without a few hiccups. Turns out the brake master cylinder was playing up and basically (to put it simply) keeping the brakes engaged. I had it overhauled, and after some adjustments, everything was working again. The whole process took a while, as you can imagine. To top it off, the front right wheel bearings were shot and needed replacing too. This is a rare occasion where I'm posting an update while it's all still fresh! These pictures were taken just this afternoon.
