Hey guys,
got a little query and was wondering if someone knew or could help me out.
Are gtr bonnets a direct fit with gtst on the r33?? If not, what are the variations? Is it the width that varies or the bonnet latch doesnt line up etc???
Ill be picking up a carbon bonnet on sunday, and just soughta need to know incase it was meant for a gtr, but pretty sure its for a gtst???
Any ideas???
https://www.sau.com.au/forums/topic/74150-r33-gtr-bonnet-same-as-gtst/
  Al said:
I beleive that the R33 GTR bonnets are a little longer (from the windsreen to the grill) than the GTS.
Thanks for the info, ill get some measurements off the seller before I pop round... Kinda hard to take your car there to fit it up on the spot, dont really think u can drive without a bonnet :D
LOL
  raz0r$harP said:
Please post when you check it out. For 32s at least the GTR bonnet is significantly lighter than the GTST one, and would be a neat way to save some weight.
Rang the seller and hes not too sure whether its for a gtr or gtst... So the results I get tomorrow, not too sure... However, hopefully the bonnet fits :) (Carbon fibre, supposedly non gtr)
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
    • Sorry for reviving an old post, but I'm having the same hot idle tick issue. Did anyone ever find out what it was?  I have checked/ replaced Injectors Coils checked Lifter clerance (is at zero) Checked Cam lobes Replaced exhaust gasket and studs Would appreciate any advice this is driving me nuts
    • There's a huge reason manufacturers are tuning in dead flat torque curves... Make them reliable (and more drive able)
