I have 235/40 17" for front and 255/45 17" for rears.
I have a stock space saver wheel in the boot. Now I was wondering If ever I do have a flat tyre, and I use the spacer saver will it work?
I mean the current tyres are 17" and spacer saver is 16" and its very very thin..
So do I need it?
https://www.sau.com.au/forums/topic/74185-space-saver-wheel/
So do I need it?
Width is irrelevant, it is diameter that is important so the diff (and ATTESSA in 4wd's) doesn't overheat due to the rotational speed difference. A 225/50/16 is effectively the same diameters as a 205/60/15, and a 225/45/17, and a 245/40/17, and a 245/35/18, and a 235/30/19 etc
I am hoping that you have 235/45/17 on the front and 255/40/17 on the rear, otherwise you already have a diameter difference that will make it hard to carry one spare that suites both. Not an issue on the front of a 2wd, but certainly an issue all round on a 4wd and on the rear of a 2wd.
Hope that helps:cheers:
Yea I got them mixed up, 235/45/17 on the front and 255/40/17 on the rear.
Not sure what the stock spare tyre is. (Will check later).
But im completating will the spare wheel come in handly? (since the wheels are quite large compared to the space saver) or ill just remove it and put some subs/amps.
Don't believe it's legal, not to carry a spare. I'm not absolutely sure of that, check with RTA ['phone call'.] Even on the rear, it will be OK if you use care to drive s l o w l y, and a minimum distance. If necessary, stop for a bit ,say. every 1/2 to3/4 Kl. Better this than stuck completely in some place and in a Mobile dead spot. Will definately be OK if you use common sense. The diff does no more than it does when cornering, and on a track,the diff works a great deal of the time.
New BMW's don't have a spare, so it's certainly not illegal.:cheers:
hmm cool, means i can take out the spare and maybe get that welding? what is that stuff mmmgtir?
all i can say is if u have this stuff make sure that if it leaks its not going to be able to leak on anything. heat, time, and some loose heavy objects in the boot of my old car managed to make a bit of a mess.
why do you want to take the spare off for? not like you need the extra boot space.
You can put it on any side of the car you want. If its the difference between driving home at ~80kph with a slight lean to one of the corners, as opposed to paying for a flatbed to tow you home. Just leave it where it is and be glad you have a spare and use it when you get a flat. Not like it weighs that much anyway.
just out of curiosity, does anyone spare fot over their front brakes ?????
cause i ain't too keen on having a front flat then having to pull a tyre off the back and put onto the front then put the space saver on the back seems like a lot fo messing around, would a spacer solve my problem ???
People are asking silly questions.
The space-saver is designed for your car. Its designed to fit on front or the back of the car, and on either the left or the right. Yes it clears the calipers, and the rolling diameter of the wheel is unaffected, if you DO have larger back tyres with a larger diameter, its not like you will be driving down the road with one of the wheels not touching the ground because of difference in wheel sizes.
I have used the space saver on my car many times already, front and back, left and right.
For the record,
After completely shredding a 265/35/18 rear ( on my GTSt ) I travelled about 250kms from just north of Nelsons Bay to Sydney on the spacesaver. After being advised not to go above 80km/hr by the local tyre mob ( who couldnt find me a suitable replacement ) I gave the spacesaver about 36psi and headed off at a brisk 100-110km/hr down the freeway. I stopped every hour to check the condition of the tyre and ensure the pressure was holding, but it never missed a beat and got me home in a damn decent time. And honestly, I think the tyre looks better for the run. No issues with treadwear, car handled fine at the higher speeds, and I now have complete confidence that it is more than up to the job.
In short, dont underestimate the quality of the spacesaver, as said above, its designed to be used on your car ( it does look a little rediculous from behind but you get over that when you start overtaking slower cars ).
Z.
    • I totally couldn't do the whole kids taking up my life thing! 😮 I find it bad enough doing 45 hours in 4 days, and then fitting normal adulting life into the other 3 with no kids! As for my mates race cars, they're AMG C63 setup for production racing. The original is what has just been stripped and a brand new shell built. The original is then going away to have some panels straightened, then it will be put back together again. Then there's a third that will shortly head off to have a roll cage put in, then build it up too. And potentially a fourth to be built too... Oh, and he has two Renault Clio D class production cars, ha ha. And when he's not racing them in the Australians and QLD production championships, he's been racing one of Chaz Mostert's Lamborghini's in GT4. They just won GT4 at the 12 hour in the Lambo. We're pushing to finish the new AMG as it has its first round (and potentially its first shakedown/outing) in under w weeks for Round one of QPC, and that round is really the shakedown to make sure it's all good for the Bathurst 6 hour, which I'll be at too. Ha ha ha Working on my project is different to his, I slowly tinker and work ways to make things happen on a shoe string budget. Hes in a good position that he has a massive workshop full of parts and tools, ha ha. He also looks after me. When his air compressor died, he just needed it working, so bought himself a new one and gave the old to me. Sand blaster unit too, and a 20t pressing. And pretty much all the shelving in my shed too as he upgraded all of his (the stuff he gave me is the expensive black Bunnings heavy duty stuff)!   I enjoy working on his stuff. No decision paralysis, and anything that's needed parts wise is just there. Plus, then I get to be hands on at the track in real racing, not just club day stuff.
    • I know which one I'd prefer to have in my garage, and which one I'd actually drive as intended
    • Yeah mate, no probs. Just swap the email addresses?
    • I definitely agree with you there - I never click on content for cars I would never ever be able to get or compete with/against/be seen next to. Seeing a MX5 compete with a FD RX7 will make people upset though, for sure. Even in 2.5L Turbo form which is pretty grass roots. (or at least as grass roots as classic cars can be) Yes we're all classic car owners now.
    • Wonder what the cause is, but here's hoping it's nothing too serious.
