this is my mates new car ,he just got it last friday thru imports 101
(finally after 4 months)
u cant get the real effect of the pearl paint but it is a pinky pearl with a tinge of purple on the top layer(mate calls it mauve)
it has a power fc ,
fmic, apex cams, fuel pump, ajustable suspension, shit load of gauges
18inch rims,
his old car was a holden astra so the transition to the r33 has been a good one
https://www.sau.com.au/forums/topic/74188-mates-new-car/
']we saw this car being unloaded onto the docks when it first arrived. I was trying to hatch a plan involving floating pontoons and jetskis to try and steal those rims!!! ahah
Did you see a bayside blue r34 gt-t?
its ready to clear by my import approval is still in the mail :~((( probably get here monday.
https://www.sau.com.au/forums/topic/74188-mates-new-car/#findComment-1363602
does anyone notice the missmatching bodykit colour look - it might just be my eyes but its the only thing i can focus on in those pictures
Hmm.. Looks ok to me.. Might be just the light reflecting off the bonnet that makes it look a little weird..
*Nice car dude.. :)
https://www.sau.com.au/forums/topic/74188-mates-new-car/#findComment-1365033
good eyes man ,your right the sides and front were damage
when it came off the boat ,so imports 101 organized
someone to paint it and they fudged it up
i told him to complain because they charged him $900
and there going to redo it .
the pics dont really show how bad it is but it really
brings the look of the car down
poor bloke has only had the car a week and has been riddled with problems
its got some huge tuning issues (boosting over 1.5 bar)
and imports101 dont know how to fix it
so they sent it to steve from the old sst (chriss mills)
and he said he couldnt tune without a hand controller
because he dosent know how to tune with a laptop
seems strange to me cause its a power fc , so i suggested hyperdrive and they said we can fix it no problem
indicators falling out of sockets
pipework popping off
power steering etc
everything can be fixed it just a matter of time
https://www.sau.com.au/forums/topic/74188-mates-new-car/#findComment-1365072
power steering etc
I think you will find he said is he needs a hand controller to tune it as he doesnt have the laptop software. I've seen him tune many with a laptop.
https://www.sau.com.au/forums/topic/74188-mates-new-car/#findComment-1365535
If he is having all these issues with things falling off etc - how on earth did it pass compliance... or even the pits?
your guess is as good as mine , when the car arrived it was driven of the boat not a problem ,
my mate seen and heard the car driving all was good ,
and then he tells me the head gasket was blown so imports
replaced and shaved the head ,then the car wouldnt start and ran like shit
thats when it all seemed to get real dodgy
allot of what was said to him from imports 101 didnt make
sense to me ,seems like there was a lot of stalling and bullshit going on
but i know for sure that that car would not of made it over the pits in the state it was in
https://www.sau.com.au/forums/topic/74188-mates-new-car/#findComment-1366530
Quote:
Originally Posted by crate
so they sent it to steve from the old sst (chriss mills) and he said he couldnt tune without a hand controller
are you sure?
are you sure?
the same thing happened when steve did my car he only used a controller no laptop ,
i went in with 330hp and came out with 269hp plus
1x stuffed apex solonoid
1x air con deemed useless
1x popping car with no mid range
not having a go at steve but i would have had a better tune
done if i had just driven it into a wall,shot the motor and taken it to kmart auto centre(this is my personel opinion of steves workmanship i cant vouch for the other cars he has blown up)
https://www.sau.com.au/forums/topic/74188-mates-new-car/#findComment-1366543
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
    • So, the other thing I've sorted is a baseline dyno run up at Unigroup's new location. The auto trans was a little unco-operative by both shifting down when the throttle was floored on the dyno (so Mark had to ramp it up more slowly than in a manual) and also by shifting up at 6,000 even in sports mode instead of the indicated redline of 7,000 Still, on a hot day it made 240rwkw at 16psi which seems about right for 300kw (400hp) through an auto at the wheels.  The shape of the curve is not quite right because it was not full throttle to about 4,500 to stop it kicking down, but until I can get a tune on the auto trans control this was the best we could do.....full boost will be well below 5,000 once that is sorted, I'll get some data logs when I can to confirm For comparison, the R32 made 255 at 12psi (at 4,500) on the same dyno with tune, n1 turbos, cam gears, big exhaust but otherwise all standard so the v37 is likely a little better out of the box. One thing that is very clear is that the standard water to air intercoolers are not up to sustained use at full throttle in warm ambient temps. After about 5 runs (so only a few minutes full throttle), it was pulling boost and timing and dropping 10-15% power. Unfortunately I didn't get that printout and the Unigroup guys are away at the moment, will try and get hold of it on their return. So, looks like a healthy engine to start modifying and the only real area of concern is the w2a heat exchangers which the aftermarket has plenty of solutions for
    • I maintain it actually looked really nice in person. So much so that I thought "No, this is illegal" but there it was, clear as day. I think we can easily call the wing and wheels/height to be transformative. Not saying it's better than the GR Whatever, or the 86, or the WRX STI or anything of that sort (the internet says it all bolts up so you can buy best of all worlds?) but it's still at least a thing and not nearly AS bad as people say.
    • That's less offensive than the previous gen.....except for all that ugly black tupperware around the edges. Blerck!
    • I leant out the window recently and took a picture of this new WRX. It looked real damn fine in person. It's faster around a track (stock) than a (stock) GR Yaris. It's much more practical despite being heavier. It's significantly cheaper. This gen tunes really well, much better than others. .... I think they're probably a lot better than people expect.
