Anyone know of a bodyshop that sells Top Secret Bodykits?
By PotatoCake · Posted
Brand new and unused, accidently bought the wrong kit for my setup, so i ended up getting a custom intake made instead by Js Performance instead. Did end up using the pod filters. So its the entire setup minus the pod filters. Everything else is still brand new factory sealed. Purchased from RHD Japan with full receipts for $585 + around $250 in shipping & import taxes. $350 Pickup from Kilsyth 3137 or can post for $30 Brand: APEXi Product: Super Suction Kit 80mm MAF - BCNR33 BNR34 Part Number: 538-N061 SPECIFICATIONS: Pipe Material: Cast Aluminum PRODUCT NOTES: - Z32 Airflow meter coupler included -
Just a question. You removed the notch and turned the squirters so they don't hit the piston. All well there. Isn't the notch there to make sure the hole in the banjo bolt and the oil feed hole in the squirter align? Doesn't turning the squirter mean these two won't align now and there will be no oil flow through the squirter?
The availability of e85 won't matter with a flex tune. Can mix and match and never have range anxiety again. Only thing will change is your ethanol %.
Jamie does know his stuff , you might just want to give them a call and ask - here is their FB page - https://www.facebook.com/profile.php/?id=100063506985512 - you will find the number to call them on.
Do you think the guys in Penrith are install the E85 Kit?
