R33Gts-t Posted May 20, 2005 Share Posted May 20, 2005 hello can anyone tell me if the nissan fan is the same as the vl? in other words would a vl fan fit on a r 33 gts-t , i am talking about the clutch fan at the radiotor and does anyone know where i can get them from ? and how much they are? Link to comment https://www.sau.com.au/forums/topic/74220-nissan-fan-same-as-a-vl/ Share on other sites More sharing options...
Marlin Posted May 20, 2005 Share Posted May 20, 2005 There not the same. There should be heaps @ importers 2nd hand. Expect to pay $200 incl fan. Link to comment https://www.sau.com.au/forums/topic/74220-nissan-fan-same-as-a-vl/#findComment-1364295 Share on other sites More sharing options...
Cubes Posted May 22, 2005 Share Posted May 22, 2005 There not the same but do fit. The VL fan sits closer to the motor and is very very close to fouling the harmonic balancer. I've been running one on my R32 basically since I got the Rb30DET in. Its only temporary as I'm going to bolt up a set of new EL twin thermo's, they are $190 bran new. New the clutch assembly can be picked up for $140 odd. Simply unbolt the fan and bolt it on the new clutch and your off. I bought a second hand clutch & fan from a jap importer for $70, it only lasted a year before it began leaking and not locking correctly. Link to comment https://www.sau.com.au/forums/topic/74220-nissan-fan-same-as-a-vl/#findComment-1366105 Share on other sites More sharing options...
sdm33 Posted May 23, 2005 Share Posted May 23, 2005 I have had a vl fan on my 33 for 2 years no dramas. But I swapped the 33 fan blades from my stuffed clutch unit onto the vl unit. I bought it from repco, paid 150 for it brand new. Link to comment https://www.sau.com.au/forums/topic/74220-nissan-fan-same-as-a-vl/#findComment-1367509 Share on other sites More sharing options...
Cubes Posted May 23, 2005 Share Posted May 23, 2005 You must have what they call the R31/VL Turbo clutch. Apparently the VLT & R31 clutch is the same as the R32/R33. Its listed as the same on the packaging. The normal N/A VL clutch is different (smaller) you will be unable to simply swap over the blade/fan. Link to comment https://www.sau.com.au/forums/topic/74220-nissan-fan-same-as-a-vl/#findComment-1367602 Share on other sites More sharing options...
sdm33 Posted May 23, 2005 Share Posted May 23, 2005 Yes thats right, sorry when you were talking vls I assumed turbo for some reason. Link to comment https://www.sau.com.au/forums/topic/74220-nissan-fan-same-as-a-vl/#findComment-1367888 Share on other sites More sharing options...
natho Posted May 23, 2005 Share Posted May 23, 2005 its strange how the aftermarket fan clutch manufacturers seem to think the VL turbo's have the bigger clutch/fan unit. i've only ever seen vl's with the smaller 7 blade fan. i've never seen this, and considering that the std vl (same as n/a) one is only about 10mm at most from the bottom of the radiator shroud, i dont see how anything bigger can fit on a vlt? weird... Link to comment https://www.sau.com.au/forums/topic/74220-nissan-fan-same-as-a-vl/#findComment-1368727 Share on other sites More sharing options...
TTT Posted May 24, 2005 Share Posted May 24, 2005 I have a new Clutch at home somewhere in the garage. bought it for $150 but never used it. willing to sell for $100 if anyone needs one. It is identical to the unit that was on my R32 gtst Link to comment https://www.sau.com.au/forums/topic/74220-nissan-fan-same-as-a-vl/#findComment-1369033 Share on other sites More sharing options...
DOUGMO Posted May 25, 2005 Share Posted May 25, 2005 the aftermarket clutches that I have found list vl turbo and non turbo as the same. and r32/3 as different to the vl type Link to comment https://www.sau.com.au/forums/topic/74220-nissan-fan-same-as-a-vl/#findComment-1371779 Share on other sites More sharing options...
Cubes Posted May 25, 2005 Share Posted May 25, 2005 Not on the Davis Craig clutch fans. It lists the VLT, R32, R33 and R31 as the same. The VL is under a different part number. Link to comment https://www.sau.com.au/forums/topic/74220-nissan-fan-same-as-a-vl/#findComment-1372622 Share on other sites More sharing options...
natho Posted May 25, 2005 Share Posted May 25, 2005 just curious which one you have? 5001 or 5265? also look here and select skyline.. weird how it specifies using the GM fan blades on an R31!! Link to comment https://www.sau.com.au/forums/topic/74220-nissan-fan-same-as-a-vl/#findComment-1372713 Share on other sites More sharing options...
DOUGMO Posted May 27, 2005 Share Posted May 27, 2005 5265 I think Link to comment https://www.sau.com.au/forums/topic/74220-nissan-fan-same-as-a-vl/#findComment-1377585 Share on other sites More sharing options...
