I have a question regarding the Vaccum hose that connects from the intercooler piping and then hooks up with the bleed valve then goes to the wastegate actucator. May sound like a stupid question but is it better drill a hole and to run the vaccum hose before the intercooler(between the turbo and the intercooler) or after the intercooler(between the intercooler and the plenum)?
Does it have much effect on the way the bleed valve will work considering there is a slight pressure drop after the compressed air goes through the intercooler and then into the engine?
I would have thaught after the i/c would be better, you want the w/g to see the pressure the engine gets(remembering your boost gauge is also after the i/c so you can see the pressure your engine gets). i think the pressure before the i/c is irrelevant But i could be wrong.
Why does it matter what pressure the wastegate is seeing compared to the engine? Thats why you have the gauge tapped closest to the engine so you can adjust with that.
Why do aftermarket Electronic boost controllers have a seperate sensor for the guage..?
The wastegate needs good response.. so taking it as close to the turbo as possible would make sense to me? Why alse would factory wastegates get there pressure from right off the turbo compressor housing?
I may be wrong here.. it is probably not too major where you take the pressure from. Seems to work well either way.. ?
Stock GTS-T takes it from the turbo compressor. Stock GTR takes it from after the throttles..
R32 gtst's have the nipple on the turbo compressor housing instead of the intercooler pipe like the R33's.
I agree with the above in that it should be taken as close to the turbo as possible.
Ditto, keep the hoses short, air compresses and you get more dampening the longer the hose is. That means slower response.:P
The thing is, you don't want the wastegate opening prematurely. If you activate the wastegate off the back of the compressor, then the wastegate opens when the compressor "spikes". Also, you get more wastegate creep having the "signal" close to the wastegate.
If you run the wastegate off the back of the compressor, then the engine "sees" wastegate setting minus pressure drop. If you run the wastegate off the plenum, then the engine "sees" wastegate setting. I know which one I'd rather be running.
I thaught the r33 gtst from factory took it from the plenum after the i/c and the r32 gtst from the compressor. now your probably right about which way is better but if the factory is the grounds for your argument tell me why did the factor have it at the comp for r32 then change to the plenum for its next more advanced model the r33!
The R33 has a solenoid the R32 doesn't:cheers:
For a bleed valve this is probably the case, for a good EBC.. this should not be a problem.
With an EBC the settings are changed from what the engine sees as this is where the gauge part is plumbed, so it really matters not what the wastegate sees as long as it gets a fast responsive signal.
I would rather a spike cause underboosting than overboosting also. With the signal taken futher down the track, with a long pipe to the gate.. the spike will cause a boost spike (bad) But with a good EBC none of that should happen.
otto.. I think the main difference is to do with the boost control systems on the GTR and R33 etc as it is a basic bleed valve in a way.
Just throwing ideas around here as I recently had the same ideas from both sides of this discussion.. :)
I then looked at the apexi installation for external wastegate, and decided to go with this.. it made sense to me and they probably know best for their product..
I have never had any spikes or problems running either way though to be honest..
What difference does it make? I set the IEBC to open the wastegate at the boost I want,. I don't care which piece of air I use to open the wastegate, it's all air. I juts want short hoses so the response is fast, not dampened by a couple of metres of hose.:)
PS; faster response = less time for boost spikes
They could still have hooked it up to the comp if they wanted to regardless but they decided not to. an ebc has a soilinoid does this mean the ebc would be better hooked to the plenum?? is it better to run a bit more hose and have the solinoid in a cooler place or run it short and have it be fried by the turbo. anyhow most of the time its closer to hook it to the plenum when you start to install ebc/ bleeder or whatever.
    • So, I've been a little busy on this car. I replaced the bonnet struts which is always satisfying but very confusing that nobody else on the planet seems to do this. Its just my routine first thing I do on any car I buy. The boot struts for both the tailgate and the separately opening glass window was a bastard. And, I found a fair bit of rust in the strut cavity. I filled it with rust converter and cleaned up as much of the dirt as I could. There was so much dirt. One piece of the trim was barely hanging on and so I've left it off. I'll try to get a replacement. You can see how disgusting and dirty it all was in this thread; I had to remove the little clips that hold the struts on the ball. The ones I took off had no clips and it was impossible to get them on with them in place. Fingers crossed they stay put. So, I turned my attention to the headlights, they were in a bad way and likely would stop rego. I took the headlights out and found the adjusters were all just loose. So, I fixed those and unclipped the lenses to clean them up. Couldn't believe how easy it was to take all this apart compared to the E90.   I also cleaned up the stockies which was awesome, these are super cool with lug nut covers. They're in good nic but the tyres are shot. I was going to use these for rego but in the end got a fresh pair of rubber for the 17's on the front of the car instead. The front bar of this car is from a late(r) model one. I don't think it's quite LCI but who knows. I'll need to find out. Anyway, the bar was missing the fog lights and the wiring and plugs were for the original ones so I got new plugs and some cheap fogs. I wasn't sure if missing original equipment would hamper my blue slip attempts. Had a couple of these little fellas helping out. But not Ben who got stuck behind the pool heater .... How embarressment.  I ordered new speed sensors for all corners because I knew one was out. I just got cheapies and will replace them with Bosch items when I can find Bosch items. Again, this was just for rego. Alas, it seems the blue speed sensors are not the same as the grey ones. Back they went and replacements ordered. In the end, with my new scan tool, it was just rear left that was shot. Replaced it and cleared the codes. All good now. Lastly, my aux (thermo) fan is being a bit odd. Its powering up at strange times and NOT powering up when I think it should (100C). While this can be caused by a few things, the most likely (for me) is the ambient temp sensor. Given mine reads -40.0C regardless of the temp, I figured it would be good to replace it. In the end, the sensor wiring was abysmal with (terrible) attempts made by somebody to fix it.   I fixed this all up but the sensor is only attached using pins into the wires. The plug is not there. Despite trying and trying to connect it securely it wouldn't work so a replacement sensor and plug is on the way. Oh, I also ordered a replacement piece of trim for the part missing here at the bottom. Ordered from Latvia for $70 delivered. I took a bit of a leap of faith because I didn't have the exact part number and, as usual, there were eleventy billion pieces of trim that looked to fit. Nailed it. Well, its not totally perfect but I think its more a 28 y/o car problem than a trim problem. And, as of today ..... I have bought the workshop manuals 2nd hand off a guy in tassie. 1000+ pages of E39 goodness, hopefully it helps me with the fan. I also have a new temp switch on the way incase its the problem. Stoked.
    • I don't even know that you want an M2 Competition as a track car. My rule for a track car is only risk as much as you're willing to completely total out. Clean stock C5 Z06 Corvettes out here are cheap. Buying someone else's already ruined track car is even cheaper. Maybe I'm just not that good a driver but even a Fiesta ST on the Nordschleife felt like as much car as I could realistically handle.
    • I've already gone over the cam. A new one is going in. An old one is coming out! The new one is smaller, with less overlap. It has way more lift, but it will be more mild mannered (hopefully, probably very minorly) I'm also measuring for two more mufflers, with the goal of having four mufflers in my car. But that probably will be done by an exhaust shop in a drive in, measure, buy parts, install parts later kind of deal.
    • Mine is not even a GTR and I've been resisting the urge to make it a power monster for the last 25 years. And as a consequence, I have driven it to work nearly every day across that span of time.
    • Since the motor is out, I suggest pop in a nice dirty LS chop cam. MOAR of this please:
