I have a question regarding the Vaccum hose that connects from the intercooler piping and then hooks up with the bleed valve then goes to the wastegate actucator. May sound like a stupid question but is it better drill a hole and to run the vaccum hose before the intercooler(between the turbo and the intercooler) or after the intercooler(between the intercooler and the plenum)?
Does it have much effect on the way the bleed valve will work considering there is a slight pressure drop after the compressed air goes through the intercooler and then into the engine?
I would have thaught after the i/c would be better, you want the w/g to see the pressure the engine gets(remembering your boost gauge is also after the i/c so you can see the pressure your engine gets). i think the pressure before the i/c is irrelevant But i could be wrong.
Why does it matter what pressure the wastegate is seeing compared to the engine? Thats why you have the gauge tapped closest to the engine so you can adjust with that.
Why do aftermarket Electronic boost controllers have a seperate sensor for the guage..?
The wastegate needs good response.. so taking it as close to the turbo as possible would make sense to me? Why alse would factory wastegates get there pressure from right off the turbo compressor housing?
I may be wrong here.. it is probably not too major where you take the pressure from. Seems to work well either way.. ?
Stock GTS-T takes it from the turbo compressor. Stock GTR takes it from after the throttles..
R32 gtst's have the nipple on the turbo compressor housing instead of the intercooler pipe like the R33's.
I agree with the above in that it should be taken as close to the turbo as possible.
Ditto, keep the hoses short, air compresses and you get more dampening the longer the hose is. That means slower response.:P
The thing is, you don't want the wastegate opening prematurely. If you activate the wastegate off the back of the compressor, then the wastegate opens when the compressor "spikes". Also, you get more wastegate creep having the "signal" close to the wastegate.
If you run the wastegate off the back of the compressor, then the engine "sees" wastegate setting minus pressure drop. If you run the wastegate off the plenum, then the engine "sees" wastegate setting. I know which one I'd rather be running.
I thaught the r33 gtst from factory took it from the plenum after the i/c and the r32 gtst from the compressor. now your probably right about which way is better but if the factory is the grounds for your argument tell me why did the factor have it at the comp for r32 then change to the plenum for its next more advanced model the r33!
The R33 has a solenoid the R32 doesn't:cheers:
For a bleed valve this is probably the case, for a good EBC.. this should not be a problem.
With an EBC the settings are changed from what the engine sees as this is where the gauge part is plumbed, so it really matters not what the wastegate sees as long as it gets a fast responsive signal.
I would rather a spike cause underboosting than overboosting also. With the signal taken futher down the track, with a long pipe to the gate.. the spike will cause a boost spike (bad) But with a good EBC none of that should happen.
otto.. I think the main difference is to do with the boost control systems on the GTR and R33 etc as it is a basic bleed valve in a way.
Just throwing ideas around here as I recently had the same ideas from both sides of this discussion.. :)
I then looked at the apexi installation for external wastegate, and decided to go with this.. it made sense to me and they probably know best for their product..
I have never had any spikes or problems running either way though to be honest..
What difference does it make? I set the IEBC to open the wastegate at the boost I want,. I don't care which piece of air I use to open the wastegate, it's all air. I juts want short hoses so the response is fast, not dampened by a couple of metres of hose.:)
PS; faster response = less time for boost spikes
They could still have hooked it up to the comp if they wanted to regardless but they decided not to. an ebc has a soilinoid does this mean the ebc would be better hooked to the plenum?? is it better to run a bit more hose and have the solinoid in a cooler place or run it short and have it be fried by the turbo. anyhow most of the time its closer to hook it to the plenum when you start to install ebc/ bleeder or whatever.
    • Solid update, got all the downforces now.  You going to be running aus time attack again? love the jacking solution, spend the dollars on what makes it go fast is best way.
    • Back in January, I noticed my car felt noticeably weak. I had the injectors cleaned, which seemed to solve the problem -- until now. Recently, the car suddenly lost power again while driving. Suspecting the injectors, I brought it to the mechanic. He recommended replacing them entirely, saying the current ones were getting unreliable and fiddly to work with. I could not find a direct replacement for my current injectors. The closest match I found were 440cc injectors. This led me to look into the possibility of upgrading -- and of course, that would mean remapping the ECU. From my research I found: The OEM Part numbers are 16600-72L20 and 16600-72L21 Both the RB20DE and RB20DET use the same 270cc injectors. There are much better options out there over the old OEM injectors. Nistune could be a viable tuning option. While the RB20DE isn’t explicitly listed on their site, the ECU is essentially the same as the GTS-T version - just with a different map. The ECU code on mine is listed as supported. One concern is finding a tuner who works with Nistune. Aftermarket ECU like Haltech and Link, but this would be the most expensive choice (and possibly overkill for a mostly stock RB20DE) I admit that I am very new to the tuning scene and would appreciate any insight or recommendations regarding this.   These are some SAU links where I got some of my information from for reference: https://www.sau.com.au/forums/topic/380324-rb20de-injectors/ https://www.sau.com.au/forums/topic/477396-factory-270cc-injectors/
    • The inspectors are not forensic by any means but if you forge your documents and/or badgings on vehicle parts and are found out, the consequences are just far bigger than if you just run illegal parts. And their job quite literally is to cross reference what parts you got installed and what your papers say you got. Something as silly as your suspension being 1mm too low will fail you. Nonetheless I asked if someone knew the damn pipe and I certainly did not ask for smartassery or underhanded comments, no idea why you need to be told this. Great way to waste both our time.
    • As useful as you explaining what forgery is... But then again, I wasn't aware your inspectors were also forensic experts and inspect nameplates on each component to confirm everything is original. They must inspect roughly 3 cars a year at that rate. You're right though, my comment doesn't help you in anyway, so I'll go talk to my wall now. Cheers.
    • Say that to the guy that is going to fail your inspection or tow your car for illegal exhaust modifications. If you have anything else useful to say, please go tell your wall.
