I have a question regarding the Vaccum hose that connects from the intercooler piping and then hooks up with the bleed valve then goes to the wastegate actucator. May sound like a stupid question but is it better drill a hole and to run the vaccum hose before the intercooler(between the turbo and the intercooler) or after the intercooler(between the intercooler and the plenum)?
Does it have much effect on the way the bleed valve will work considering there is a slight pressure drop after the compressed air goes through the intercooler and then into the engine?
I would have thaught after the i/c would be better, you want the w/g to see the pressure the engine gets(remembering your boost gauge is also after the i/c so you can see the pressure your engine gets). i think the pressure before the i/c is irrelevant But i could be wrong.
Why does it matter what pressure the wastegate is seeing compared to the engine? Thats why you have the gauge tapped closest to the engine so you can adjust with that.
Why do aftermarket Electronic boost controllers have a seperate sensor for the guage..?
The wastegate needs good response.. so taking it as close to the turbo as possible would make sense to me? Why alse would factory wastegates get there pressure from right off the turbo compressor housing?
I may be wrong here.. it is probably not too major where you take the pressure from. Seems to work well either way.. ?
Stock GTS-T takes it from the turbo compressor. Stock GTR takes it from after the throttles..
R32 gtst's have the nipple on the turbo compressor housing instead of the intercooler pipe like the R33's.
I agree with the above in that it should be taken as close to the turbo as possible.
Ditto, keep the hoses short, air compresses and you get more dampening the longer the hose is. That means slower response.:P
The thing is, you don't want the wastegate opening prematurely. If you activate the wastegate off the back of the compressor, then the wastegate opens when the compressor "spikes". Also, you get more wastegate creep having the "signal" close to the wastegate.
If you run the wastegate off the back of the compressor, then the engine "sees" wastegate setting minus pressure drop. If you run the wastegate off the plenum, then the engine "sees" wastegate setting. I know which one I'd rather be running.
I thaught the r33 gtst from factory took it from the plenum after the i/c and the r32 gtst from the compressor. now your probably right about which way is better but if the factory is the grounds for your argument tell me why did the factor have it at the comp for r32 then change to the plenum for its next more advanced model the r33!
The R33 has a solenoid the R32 doesn't:cheers:
For a bleed valve this is probably the case, for a good EBC.. this should not be a problem.
With an EBC the settings are changed from what the engine sees as this is where the gauge part is plumbed, so it really matters not what the wastegate sees as long as it gets a fast responsive signal.
I would rather a spike cause underboosting than overboosting also. With the signal taken futher down the track, with a long pipe to the gate.. the spike will cause a boost spike (bad) But with a good EBC none of that should happen.
otto.. I think the main difference is to do with the boost control systems on the GTR and R33 etc as it is a basic bleed valve in a way.
Just throwing ideas around here as I recently had the same ideas from both sides of this discussion.. :)
I then looked at the apexi installation for external wastegate, and decided to go with this.. it made sense to me and they probably know best for their product..
I have never had any spikes or problems running either way though to be honest..
What difference does it make? I set the IEBC to open the wastegate at the boost I want,. I don't care which piece of air I use to open the wastegate, it's all air. I juts want short hoses so the response is fast, not dampened by a couple of metres of hose.:)
PS; faster response = less time for boost spikes
They could still have hooked it up to the comp if they wanted to regardless but they decided not to. an ebc has a soilinoid does this mean the ebc would be better hooked to the plenum?? is it better to run a bit more hose and have the solinoid in a cooler place or run it short and have it be fried by the turbo. anyhow most of the time its closer to hook it to the plenum when you start to install ebc/ bleeder or whatever.
    • No idea about the remote start part. If the V37 nav is anything like other Nissan JDM vehicles, you can't get the factory Japanese nav working in australia, a card from a different car almost certainly won't work, those cards are usually matched to the serial number of the DCU.  You could be possibly swap out the components from a AuDM Q50 to get it working, but if this is a new model (2021+) 400R, then you will lose the newer features like ACP/AA.  That said, if you have ACP/AA, just use google maps.. I assume a band expander would be required to get the local radio stations, but don't forget the Japanese FM band is narrower than ours, so you still might not be able to receive all Australian stations. I can't see any reason the tyre pressure sensors won't work here, there is the sensor unit inside the rim and the receiver nearby in the wheel well.  I have never had to change the batteries on my 2015 Q50, so I assume they last quite a while.  A straight battery change shouldn't need them to be re-registered as they are the same unit, that should only be required if you replace a sensor with a new one.   Word of warning, if you ever go into the 'secret' diagnostics mode on the main screen, DO NOT EVER do a 'reset' in this menu, it will erase all of your model specific data in the DCU and you will need a trip to a dealer to re-program it all, which would be particularly painful being an import.  This applies to the AuDM Q50 too.
    • There is a known issue with the mix door motor on the Q50 which causes these symptoms, not sure if it is common on the Y51 though.
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
