I have a question regarding the Vaccum hose that connects from the intercooler piping and then hooks up with the bleed valve then goes to the wastegate actucator. May sound like a stupid question but is it better drill a hole and to run the vaccum hose before the intercooler(between the turbo and the intercooler) or after the intercooler(between the intercooler and the plenum)?
Does it have much effect on the way the bleed valve will work considering there is a slight pressure drop after the compressed air goes through the intercooler and then into the engine?
I would have thaught after the i/c would be better, you want the w/g to see the pressure the engine gets(remembering your boost gauge is also after the i/c so you can see the pressure your engine gets). i think the pressure before the i/c is irrelevant But i could be wrong.
Why does it matter what pressure the wastegate is seeing compared to the engine? Thats why you have the gauge tapped closest to the engine so you can adjust with that.
Why do aftermarket Electronic boost controllers have a seperate sensor for the guage..?
The wastegate needs good response.. so taking it as close to the turbo as possible would make sense to me? Why alse would factory wastegates get there pressure from right off the turbo compressor housing?
I may be wrong here.. it is probably not too major where you take the pressure from. Seems to work well either way.. ?
Stock GTS-T takes it from the turbo compressor. Stock GTR takes it from after the throttles..
R32 gtst's have the nipple on the turbo compressor housing instead of the intercooler pipe like the R33's.
I agree with the above in that it should be taken as close to the turbo as possible.
Ditto, keep the hoses short, air compresses and you get more dampening the longer the hose is. That means slower response.:P
The thing is, you don't want the wastegate opening prematurely. If you activate the wastegate off the back of the compressor, then the wastegate opens when the compressor "spikes". Also, you get more wastegate creep having the "signal" close to the wastegate.
If you run the wastegate off the back of the compressor, then the engine "sees" wastegate setting minus pressure drop. If you run the wastegate off the plenum, then the engine "sees" wastegate setting. I know which one I'd rather be running.
I thaught the r33 gtst from factory took it from the plenum after the i/c and the r32 gtst from the compressor. now your probably right about which way is better but if the factory is the grounds for your argument tell me why did the factor have it at the comp for r32 then change to the plenum for its next more advanced model the r33!
The R33 has a solenoid the R32 doesn't:cheers:
For a bleed valve this is probably the case, for a good EBC.. this should not be a problem.
With an EBC the settings are changed from what the engine sees as this is where the gauge part is plumbed, so it really matters not what the wastegate sees as long as it gets a fast responsive signal.
I would rather a spike cause underboosting than overboosting also. With the signal taken futher down the track, with a long pipe to the gate.. the spike will cause a boost spike (bad) But with a good EBC none of that should happen.
otto.. I think the main difference is to do with the boost control systems on the GTR and R33 etc as it is a basic bleed valve in a way.
Just throwing ideas around here as I recently had the same ideas from both sides of this discussion.. :)
I then looked at the apexi installation for external wastegate, and decided to go with this.. it made sense to me and they probably know best for their product..
I have never had any spikes or problems running either way though to be honest..
What difference does it make? I set the IEBC to open the wastegate at the boost I want,. I don't care which piece of air I use to open the wastegate, it's all air. I juts want short hoses so the response is fast, not dampened by a couple of metres of hose.:)
PS; faster response = less time for boost spikes
They could still have hooked it up to the comp if they wanted to regardless but they decided not to. an ebc has a soilinoid does this mean the ebc would be better hooked to the plenum?? is it better to run a bit more hose and have the solinoid in a cooler place or run it short and have it be fried by the turbo. anyhow most of the time its closer to hook it to the plenum when you start to install ebc/ bleeder or whatever.
    • I had absolutely no symptoms whatsoever that anything was wrong.... I'm very happy it was all spotto'd and re-bled and re-torqued and aligned though. Will be picking it up tomorrow and undoubtedly be like "Oh, that clunk is gone" "Oh, the car really wants to drive straight" "Oh, that pedal feels better" "Oh, it feels like I've gained 25hp" "Oh, the handbrake works now" It should have been a sign that the new Project Mu shoes had 3mm of pad depth on them out of the box, and the OEM ones from 25 years ago that we took out also had 3mm of pad depth, implying the issue was not, and never was the shoes, but we put that down to it not being adjusted correctly. It wasn't, but it wasn't even adjustable at all given one side was boned and the T Junction of the cables was on a 45 degree angle, the non-working side being the one on the massive angle. Obviously when I had adjusted it and reset it and re-tensioned it I had either got it stuck or something along those lines. Oh well. Live and learn and absolutely could have been catastrophically worse so I'm rationalizing it as a win, kinda. I also got the chance to measure the distance between rear rim and the suspension arm/shocks and found a 30mm rubber block only just doesn't fit there. Which is great to know before ordering wheels, when I assumed 30mm was easy. The man with the Porsche adapters has rims that use 23.9mm of that space, so it's safe to assume I have between 23.9 and 29.9mm of space there to play with on the inside. The wheels looked pretty stupidly pokey with the 20mm spacers on the rear, only for me to find that the studs come out another 12mm and the wheel doesn't actually sit flush with the hub because you're supposed to cut your original studs. The wheels do have cutouts that kinda accomodate it, but not fully. So my 20mm spacer was anywhere between 25mm and 35mm. ~25mm and send it will determine on where the wheels sit with the spacers on. When I put the pads in for the track day I will mess around with spacers (with wheels that do not clear studs properly when mounted to spacers) and do more math, for the last time, for the 7th time.
    • Lucky pick up Best to find these things before something horrible happened to the yoke flange thingies I would hate to think what would happen if it dropped the tailshaft  Hopefully the holes are not flogged out in the yokes and it was just the bolts that got munted  As for the hand brake.....ouch, look like the disc got rather hot, and I assume smokey, I recall when I had a front caliper seize on the Commodore, there was lots of smoke and the disc was glowing cherry red when I was able to eventually stop and have a look, and stopping a big heavy car, going down a big hill with some rather high RPM down shifts and some hand brake action is something that makes you think hard about life
    • One of the things that never seemed right was the handbrake. Put in some nice new Project Mu shoes. We figured the rears were out, so why not. We're right there. My handbrake never worked well anyway. Well, this is them, 15km later. 67fdcf94-9763-4522-97a4-8f04b2ad0826.mp4 Keen eyes would note the difference in this picture too:   And this picture: Also, this was my Tailshaft bolts: 4ad3c7dd-51d0-4577-8e72-ba8bc82f6e87.mp4 It turns out my suspicions that one side of the handbrake cable was stretched all along were pretty accurate, as was my intuition that I didn't want to drop the tailshaft to swap them on jack stands and wasn't entirely sure about bolt torque. I have since bought the handbrake cables which have gone in. I'm very glad that I went to my mechanic friend who owns an alignment machine to get an alignment before the track day, because his eyes spotted these various levels of "WHAT THE f**k IS GOING ON HERE?". Turns out the alignment wasn't that bad, considering we changed the adjustable castor arms out for un-adjustable castor arms, and messed with the heights. Car drove pretty good with one side of the handbrake stuck on, unbleedable rear brakes, alignment screwy, and the tailshaft about to go flying and generally being a death trap waiting to happen! (I did have covid) (I maintain I adjusted the handbrake correctly, but movement caused shennanigans and/or I dislodged the spring on the problem side somewhat, or god knows what). G R E G G E D
    • Very interesting, im not sure how all those complications fit in to running a haltech instead of a stock ecu but I'm starting to think I'm a bit out of my league.
    • I just put 2 and 2 together. This is a Neo converted R32. The Neo ECU (in concert with the R34's AC controller) runs the AC quite differently to how the R32 ECU and AC controller do it. If you just drop it all in, it won't work. There is some tricky wiring required, including changing to the pressure switch that the Neo controllers want to see. I don't know what it is, because mine was done by a guru. It was a year or so after I did that transplant before he worked out what needed to be done.
